I created to converted my custom model to ONNX and now try to use it with NvInfer plugin in Deepstream.
I’m using deepstream-test-1 sample application for testing.
I’ve attached config file for nvinfer plugin.
dstest1_pgie_config.txt (3.6 KB)
• Hardware Platform : Jetson Nano
• DeepStream Version : 5.0
• JetPack Version : 4.4DP
• TensorRT Version : 7.0
0:00:04.476397255 21074 0x559618b2a0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/home/Username/Downloads/model_custom.onnx_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 8
0 INPUT kFLOAT input_1:0 218x1025x3
1 OUTPUT kFLOAT dense_7/Softmax:0 33
2 OUTPUT kFLOAT dense_6/Softmax:0 33
3 OUTPUT kFLOAT dense_5/Softmax:0 33
4 OUTPUT kFLOAT dense_4/Softmax:0 33
5 OUTPUT kFLOAT dense_3/Softmax:0 33
6 OUTPUT kFLOAT dense_2/Softmax:0 33
7 OUTPUT kFLOAT dense_1/Softmax:0 33
0:00:04.476670490 21074 0x559618b2a0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /home/Username/Downloads/model_custom.onnx_b1_gpu0_fp16.engine
0:00:04.476719449 21074 0x559618b2a0 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:783> [UID = 1]: RGB/BGR input format specified but network input channels is not 3
ERROR: Infer Context prepare preprocessing resource failed., nvinfer error:NVDSINFER_CONFIG_FAILED
0:00:04.478723917 21074 0x559618b2a0 WARN nvinfer gstnvinfer.cpp:781:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:04.478784803 21074 0x559618b2a0 WARN nvinfer gstnvinfer.cpp:781:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(781): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
