Tf model converted to onnx/trt dimensions missmatch
nvcr.io/nvidia/deepstream:5.1-21.02-devel
I am trying to convert model from tf to onnx/trt and deploy on deepstream-app, so I did these steps:
  1. downloaded saved model from mobilenet_v3 | Kaggle
  2. I used examples from nvidia docs and these notebooks: tf → onnx → trt
  3. I have tried using the created intermediate onnx model with this config:
[property]
gpu-id=0
net-scale-factor=1
labelfile-path=../mobilenet/labels.txt
onnx-file=../mobilenet/mob.onnx
input-dims=3;224;224;0
batch-size=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
network-type=1
num-detected-classes=1001
interval=0
classifier-threshold=0.2
And when running with onnx the output is:
Input filename: /opt/nvidia/deepstream/deepstream-
5.1/sources/apps/main/mobilenet/mob.onnx
ONNX IR version: 0.0.4
Opset version: 9
Producer name: tf2onnx
Producer version: 1.9.2
Domain:
Model version: 0
Doc string:
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 1 output network tensors.
0:02:04.535115865 144 0x7ff1780022d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 2]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/sources/apps/main/mobilenet/mob.onnx_b1_gpu0_fp16.engine successfully
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: StatefulPartitionedCall/StatefulPartitionedCall/predict/MobilenetV3/Logits/Squeeze: reshaping failed for tensor: StatefulPartitionedCall/StatefulPartitionedCall/predict/MobilenetV3/Logits/Conv2d_1c_1x1/BiasAdd:0
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: shapeMachine.cpp (160) - Shape Error in executeReshape: reshape would change volume
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: Instruction: RESHAPE{1 1001 1 1} {8 1001}
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT inputs 224x224x3
1 OUTPUT kFLOAT logits 1001
0:02:04.539625870 144 0x7ff1780022d0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:875> [UID = 2]: RGB/BGR input format specified but network input channels is not 3
ERROR: nvdsinfer_context_impl.cpp:1158 Infer Context prepare preprocessing resource failed., nvinfer error:NVDSINFER_CONFIG_FAILED
And if I use trt generated model as model-engine-file I get something like this
WARNING: nvdsinfer_backend.cpp:162 Backend context bufferIdx(0) request dims:1x3x224x224 is out of range, [min: 8x224x224x3, max: 8x224x224x3]
0:00:00.966294670 193 0x7fbdd80022d0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1659> [UID = 2]: backend can not support dims:3x224x224
Since the examples that I used for convertion does not cover it, I am looking for some help here, how can I deploy tf savedmodel downloaded from the tfhub, how should I convert and what config to use in deepstream?
Could you share the setup information with us first?
• DeepStream Version
• TensorRT Version
I am using nvcr.io/nvidia/deepstream:5.1-21.02-devel docker image on Ubuntu20.04 so my setup is as defined in the docker image:
  • Ubuntu 20.04 (dGPU)
  • Deepstream 5.1
  • TensorRT 7.2.2
  • Nvidia drivers 460.91.03
Also I tried changing config to this:
[property]
gpu-id=0
net-scale-factor=1
onnx-file=../mobilenet/model7.onnx
#model-engine-file=../mobilenet/resnet_engine.trt
network-input-order=0
network-mode=2
network-type=1
num-detected-classes=1000
interval=0
And I get this:
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: inputs: for dimension number 1 in profile 0 does not match network definition (got min=3, opt=3, max=3), expected min=opt=max=224).
Then I tried changing tensorrt to like this in the config:
#onnx-file=../mobilenet/model7.onnx
And the output is:
0:00:00.947075537   612 0x7f52140022d0 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/main/mobilenet/resnet_engine.trt
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
WARNING: nvdsinfer_backend.cpp:162 Backend context bufferIdx(0) request dims:8x3x224x224 is out of range, [min: 8x224x224x3, max: 8x224x224x3]
0:00:00.947192727   612 0x7f52140022d0 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1659> [UID = 2]: backend can not support dims:3x224x224
0:00:00.947199340   612 0x7f52140022d0 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1814> [UID = 2]: deserialized backend context :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/main/mobilenet/resnet_engine.trt failed to match config params, trying rebuild
No matter how I try to convert I cant get it to work. I tried changing:
network-input-order=0 to 1
and
input-dims=3;224;224;0 to 3;224;224;1
To try out a different input order but seems to have no effect.
Based on the above message, it seems that your onnx model is in the NHWC format.
Could you verify this first?
You can visualize the model with this website: https://netron.app/
Yes, the model is in NHCW format.
I converted the model like this (from the docs):
model_path = 'models/mob/'
subprocess.run(['python', '-m', 'tf2onnx.convert', '--saved-model', model_path, '--output', 'temp.onnx'])
onnx_model = onnx.load_model('temp.onnx')
BATCH_SIZE = 8
inputs = onnx_model.graph.input
for input in inputs:
    dim1 = input.type.tensor_type.shape.dim[0]
    dim1.dim_value = BATCH_SIZE
model_name = "model7.onnx"
onnx.save_model(onnx_model, model_name)
Based on your snapshot, the model is NHWC format.
(C indicates channel and N is batchsize)
Since Deepstream expects NCHW format, could you convert the model into NCHW instead?
Please try this with the --inputs_as_nchw config in tf2onnx.
