Tensorflow object detection api 2.x model in deepstream 6.0
•Hardware Platform (Jetson / GPU): Jetson Xavier
•DeepStream Version: 6.0
•JetPack Version (valid for Jetson only):4.6
•TensorRT Version:8.0.1
•How to reproduce the issue ?
I’ve a trained SSD efficientnet model from TF object detection API 2.x. I’ve converted it to onnx using TensorRT/samples/python/efficientdet at main · NVIDIA/TensorRT · GitHub which gives me BatchedNMS_TRT based layer with 4 output layers which are supported in deepstream using the code create_onnx.py. By taking this onnx model, I converted it to .engine file on my xavier using build_engine.py. I got the .engine file. After that, I created the libnvds_infercustomparser.so plugin as mentioned in the documentation of deepstream for custom model inference.
Following is my config file:
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=0
labelfile-path=/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-ssd-parser/animesh_construction/excavator_class_list.txt
model-engine-file=/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-ssd-parser/animesh_construction/saved_model_using_code_batched_NMS.engine
infer-dims=3;640;640
#uff-input-order=0
#force-implicit-batch-dim=1
maintain-aspect-ratio=1
#uff-input-blob-name=Input
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=4
parse-bbox-func-name = NvDsInferParseCustomTfSSD
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.0/sources/libs/nvdsinfer_customparser/libnvds_infercustomparser.so
output-blob-names=num_detections;detection_scores;detection_classes;detection_boxes
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
[class-attrs-all]
pre-cluster-threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
I’m using this in a python code.
This is my terminal screen :
Creating Pipeline
Creating Source
Creating Video Converter
Creating EGLSink
Playing cam /dev/video0
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
0:00:00.416767011 20569     0x32e718f0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:00.418165461 20569     0x32e718f0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: builtin_op_importers.cpp:4552: Attribute scoreBits not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:02:50.662373034 20569     0x32e718f0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-ssd-parser/animesh_construction/saved_model_using_code_batched_NMS.onnx_b1_gpu0_fp32.engine successfully
INFO: [Implicit Engine Info]: layers num: 5
0   INPUT  kFLOAT input_tensor:0  3x640x640
1   OUTPUT kINT32 num_detections  0
2   OUTPUT kFLOAT detection_boxes 100x4
3   OUTPUT kFLOAT detection_scores 100
4   OUTPUT kFLOAT detection_classes 100
0:02:50.755151792 20569     0x32e718f0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::allocateBuffers() <nvdsinfer_context_impl.cpp:1430> [UID = 1]: Failed to allocate cuda output buffer during context initialization
0:02:50.755272471 20569     0x32e718f0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1280> [UID = 1]: Failed to allocate buffers
0:02:50.840017746 20569     0x32e718f0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary-inference> error: Failed to create NvDsInferContext instance
0:02:50.840110648 20569     0x32e718f0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary-inference> error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-ssd-parser/ssd_efficientnet.txt, NvDsInfer Error: NVDSINFER_CUDA_ERROR
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
What should be done to overcome this issue?
Based on the error, there are some issue when allocating the buffer.
Usually, this is related to the batch size or different NHWC/NCHW format.
Please noted that Deepstream expects NCHW model as input.
When you converting the TensorRT engine, do you generate an NCHW file?
The ONNX conversion process supports both NHWC and NCHW input formats, so if your input source is an NCHW data format, you can use the corresponding input shape, i.e. 1,512,512,3 → 1,3,512,512 .
Hello @AastaLLL , I’ve generated the NCHW file. Here is the netron visualization of my onnx model.
While building the onnx model, the batch size is to be made explicit. Is that causing an issue?
Please try it with batchsize=1 since the model input is created with (1, 3, 640, 640)
