Description
I had to convert rexnet pytorch model into TensorRT to use it with Deepstream 6.0 on Jetson Nano, but I ended with errors below:
# deepstream-app -t -c config.txt
... (after object appears and secondary-gie starts to infer)
ERROR: [TRT]: [shapeMachine.cpp::execute::565] Error Code 7: Internal Error (Slice_28: ISliceLayer has out of bounds access on axis 0
out of bounds access for slice
Instruction: CHECK_SLICE 2 0 16 1
ERROR: [TRT]: [executionContext.cpp::enqueueInternal::360] Error Code 2: Internal Error (Could not resolve slots: )
ERROR: Failed to enqueue trt inference batch
ERROR: Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
0:07:31.852496379 144 0x55a00d40f0 WARN nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<secondary_gie_0> error: Failed to queue input batch for inferencing
ERROR from secondary_gie_0: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1324): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstNvInfer:secondary_gie_0
Quitting
[NvMultiObjectTracker] De-initialized
(deepstream-app:144): GLib-GObject-CRITICAL **: 03:22:14.558: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
App run failed
Full log below:
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /workspace/rexnet.engine open error
0:00:01.416849455 144 0x55a054d550 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 2]: deserialize engine from file :/workspace/rexnet.engine failed
0:00:01.416999302 144 0x55a054d550 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 2]: deserialize backend context from engine from file :/workspace/rexnet.engine failed, try rebuild
0:00:01.417051178 144 0x55a054d550 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 2]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
WARNING: [TRT]: Min value of this profile is not valid
0:07:13.644605812 144 0x55a054d550 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 2]: serialize cuda engine to file: /workspace/rexnet.onnx_b16_gpu0_fp16.engine successfully
INFO: [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT images 3x224x224 min: 1x3x224x224 opt: 16x3x224x224 Max: 16x3x224x224
1 OUTPUT kFLOAT output 3 min: 0 opt: 0 Max: 0
0:07:13.804415333 144 0x55a054d550 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0> [UID 2]: Load new model:/workspace/secondary/config_infer_secondary.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:07:14.378722694 144 0x55a054d550 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/workspace/primary.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT images 3x768x768
1 OUTPUT kFLOAT output 12096x7
0:07:14.378848166 144 0x55a054d550 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /workspace/primary.engine
0:07:14.390004525 144 0x55a054d550 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/workspace/primary/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:180>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
**PERF: 30.59 (28.88)
**PERF: 29.16 (29.50)
**PERF: 29.11 (29.09)
**PERF: 29.09 (29.32)
**PERF: 29.12 (29.12)
Quitting
App run failed
but I could mitigate this problem by change forward()
on model from:
def forward(self, x):
out = self.out(x)
if self.use_shortcut:
out[:, 0:self.in_channels] += x # self.in_channels won't change during inference
return out
to:
feature = self.out(x)
fB, fC, fH, fW = list(feature.shape)
x_ext = torch.concat([x, torch.zeros(fB, fC - self.in_channels, fH, fW)], axis=1)
feature = feature + x_ext
return feature
I’ve create separate git repository for rexnet model and created commit #1 and #2, You also can look around there.
Though problem has gone, I wondered if this was a TensorRT-related bug or model code’s bug. Is there anyone facing same issue?
Thank you.
Environment (PC - for converting PyTorch model to ONNX)
TensorRT Version: v8.0.3
GPU Type: NVIDIA RTX 3060 12GB
Nvidia Driver Version: 495.44
CUDA Version: 11.5.50
CUDNN Version: 8.3.0.96
Operating System + Version: Ubuntu Linux 20.04.3 LTS
Python Version (if applicable): 3.8.12
PyTorch Version (if applicable): 1.11.0a0+b6df043
Baremetal or Container (if container which image + tag): Containerized (nvcr.io/nvidia/pytorch:21.11-py3
Environment (Jetson Nano - for converting ONNX to TensorRT)
TensorRT Version: v8.0.1.6
GPU Type: Jetson Nano (128-core Maxwell)
Nvidia Driver Version: NVIDIA Jetson Jetpack 4.6 (L4T 32.6.1)
CUDA Version: 10.2.300
CUDNN Version: 8.2.1.32
Operating System + Version: NVIDIA L4T 32.6.1 (Ubuntu Linux 18.04.6 LTS)
Baremetal or Container (if container which image + tag): Containerized (nvcr.io/nvidia/deepstream-l4t:6.0-triton
Relevant Files
I’ve uploaded ONNX file at Google Drive for convenience (model has uninitialized weight): Google Drive Link
- Original exported ONNX file (after Step 2 -
onnxsim
):rexnetv1_1.0_before_forward_hack_b16_noweight.onnx
- Mitigation-applied exported ONNX file:
rexnetv1_1.0_after_forward_hack_b16_noweight.onnx
Deepstream 6.0 configuration file below:
config.txt
[application] enable-perf-measurement=1 perf-measurement-interval-sec=3 [tiled-display] enable=1 rows=1 columns=1 width=1920 height=1080 gpu-id=0 #(0): nvbuf-mem-default - Default memory allocated, specific to particular platform #(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla #(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla #(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla #(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson nvbuf-memory-type=0 [source0] enable=1 #Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP type=3 uri=file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4 num-sources=1 drop-frame-interval=0 gpu-id=0 # (0): memtype_device - Memory type Device # (1): memtype_pinned - Memory type Host Pinned # (2): memtype_unified - Memory type Unified cudadec-memtype=0 [sink0] enable=1 #Type - 1=FakeSink 2=EglSink 3=File type=1 sync=0 source-id=0 gpu-id=0 qos=0 nvbuf-memory-type=0 overlay-id=1 [sink1] enable=1 #Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming type=4 #1=h264 2=h265 codec=1 #encoder type 0=Hardware 1=Software enc-type=0 sync=0 bitrate=4000000 #H264 Profile - 0=Baseline 2=Main 4=High #H265 Profile - 0=Main 1=Main10 profile=0 # set below properties in case of RTSPStreaming rtsp-port=8554 udp-port=5400 [osd] enable=1 gpu-id=0 border-width=1 text-size=15 text-color=1;1;1;1; text-bg-color=0.3;0.3;0.3;1 font=Serif show-clock=0 clock-x-offset=800 clock-y-offset=820 clock-text-size=12 clock-color=1;0;0;0 nvbuf-memory-type=0 [streammux] gpu-id=0 ##Boolean property to inform muxer that sources are live live-source=0 batch-size=1 ##time out in usec, to wait after the first buffer is available ##to push the batch even if the complete batch is not formed batched-push-timeout=40000 ## Set muxer output width and height width=1920 height=1080 ##Enable to maintain aspect ratio wrt source, and allow black borders, works ##along with width, height properties enable-padding=1 nvbuf-memory-type=0 ## If set to TRUE, system timestamp will be attached as ntp timestamp ## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached # attach-sys-ts-as-ntp=1 [primary-gie] enable=1 gpu-id=0 #Required by the app for OSD, not a plugin property bbox-border-color0=1;0;0;1 bbox-border-color1=0;1;1;1 bbox-border-color2=0;0;1;1 bbox-border-color3=0;1;0;1 interval=4 gie-unique-id=1 nvbuf-memory-type=0 config-file=config_infer_primary.txt [tracker] enable=1 # For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively tracker-width=640 tracker-height=384 ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so # ll-config-file required to set different tracker types ll-config-file=tracker_configs/config_tracker_IOU.yml # ll-config-file=tracker_configs/config_tracker_NvDCF_max_perf.yml # ll-config-file=tracker_configs/config_tracker_NvDCF_perf.yml # ll-config-file=tracker_configs/config_tracker_NvDCF_accuracy.yml # ll-config-file=tracker_configs/config_tracker_DeepSORT.yml gpu-id=0 enable-batch-process=1 enable-past-frame=1 display-tracking-id=1 [secondary-gie0] enable=1 gpu-id=0 gie-unique-id=2 operate-on-gie-id=1 operate-on-class-ids=0; config-file=config_infer_secondary.txt [tests] file-loop=0
[property] gpu-id=0 net-scale-factor=0.00390625 onnx-file=rexnet.onnx model-engine-file=rexnet.engine batch-size=16 output-blob-names=output # 0=FP32, 1=INT8, 2=FP16 mode network-mode=2 labelfile-path=labels.txt force-implicit-batch-dim=0 model-color-format=0 # 1 - primary, 2 - secondary process-mode=2 is-classifier=1 classifier-async-mode=0 classifier-threshold=0.5 input-object-min-width=32 input-object-min-height=32 operate-on-gie-id=1 operate-on-class-ids=0; # NvBufSurfTransformInter_Bilinear scaling-filter=1 scaling-compute-hw=0 parse-classifier-func-name=NvDsInferClassiferParseCustomClassifier custom-lib-path=nvdsinfer_custom_impl_classifier/libnvdsinfer_custom_impl_classifier.so
Steps To Reproduce
I’ve created TensorRT model with those process:
Convert ReXNet model into ONNX model as below:
import torch from rexnetv1 import ReXNetV1 model = ReXNetV1().eval() batch_size = 16 torch.onnx._export( rexnet_model, torch.randn(batch_size, 3, 224, 224), ONNX_OUTPUT_PATH, input_names=['images'], output_names=['output'], dynamic_axes=None, opset_version=11 )
Simplify ONNX using daquexian/onnx-simplifier:
from onnxsim import simplify onnx_model = onnx.load(ONNX_OUTPUT_PATH) model_simp, check = simplify(onnx_model, dynamic_input_shape=False, input_shapes=None)
Set
ONNX_OUTPUT_PATH
to Deepstream 6.0deepstream-app
sample configuration file:
