ONNX to TensorRT Python module doesn't generate dynamic batch size engine
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.2.5.1
GPU Type: x86 RTX-3060
Nvidia Driver Version: 525.125.06
CUDA Version: 11.6.1
CUDNN Version: 8.2.4
Operating System + Version: Ubuntu-20.04
Python Version (if applicable): 3.8.10
TensorFlow Version (if applicable): n/A
PyTorch Version (if applicable): N/A
Baremetal or Container (if container which image + tag): n/A
Relevant Files
# Copyright 2019 NVIDIA Corporation
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import os
import sys
import glob
import math
import logging
import argparse
import tensorrt as trt
#sys.path.remove('/opt/ros/kinetic/lib/python2.7/dist-packages')
TRT_LOGGER = trt.Logger()
logging.basicConfig(level=logging.DEBUG,
                    format="%(asctime)s - %(name)s - %(levelname)s - %(message)s",
                    datefmt="%Y-%m-%d %H:%M:%S")
logger = logging.getLogger(__name__)
def add_profiles(config, inputs, opt_profiles):
    logger.debug("=== Optimization Profiles ===")
    for i, profile in enumerate(opt_profiles):
        for inp in inputs:
            _min, _opt, _max = profile.get_shape(inp.name)
            logger.debug("{} - OptProfile {} - Min {} Opt {} Max {}".format(inp.name, i, _min, _opt, _max))
        config.add_optimization_profile(profile)
def mark_outputs(network):
    # Mark last layer's outputs if not already marked
    # NOTE: This may not be correct in all cases
    last_layer = network.get_layer(network.num_layers-1)
    if not last_layer.num_outputs:
        logger.error("Last layer contains no outputs.")
        return
    for i in range(last_layer.num_outputs):
        network.mark_output(last_layer.get_output(i))
def check_network(network):
    if not network.num_outputs:
        logger.warning("No output nodes found, marking last layer's outputs as network outputs. Correct this if wrong.")
    inputs = [network.get_input(i) for i in range(network.num_inputs)]
    outputs = [network.get_output(i) for i in range(network.num_outputs)]
    max_len = max([len(inp.name) for inp in inputs] + [len(out.name) for out in outputs])
    logger.debug("=== Network Description ===")
    for i, inp in enumerate(inputs):
        logger.debug("Input  {0} | Name: {1:{2}} | Shape: {3}".format(i, inp.name, max_len, inp.shape))
    for i, out in enumerate(outputs):
        logger.debug("Output {0} | Name: {1:{2}} | Shape: {3}".format(i, out.name, max_len, out.shape))
def get_batch_sizes(max_batch_size):
    # Returns powers of 2, up to and including max_batch_size
    max_exponent = math.log2(max_batch_size)
    for i in range(int(max_exponent)+1):
        batch_size = 2**i
        yield batch_size
    if max_batch_size != batch_size:
        yield max_batch_size
# TODO: This only covers dynamic shape for batch size, not dynamic shape for other dimensions
def create_optimization_profiles(builder, inputs, batch_sizes=[1,8,16,32,64]):
    # Check if all inputs are fixed explicit batch to create a single profile and avoid duplicates
    if all([inp.shape[0] > -1 for inp in inputs]):
        profile = builder.create_optimization_profile()
        for inp in inputs:
            fbs, shape = inp.shape[0], inp.shape[1:]
            profile.set_shape(inp.name, min=(fbs, *shape), opt=(fbs, *shape), max=(fbs, *shape))
            return [profile]
    # Otherwise for mixed fixed+dynamic explicit batch inputs, create several profiles
    profiles = {}
    for bs in batch_sizes:
        if not profiles.get(bs):
            profiles[bs] = builder.create_optimization_profile()
        for inp in inputs:
            shape = inp.shape[1:]
            # Check if fixed explicit batch
            if inp.shape[0] > -1:
                bs = inp.shape[0]
            profiles[bs].set_shape(inp.name, min=(bs, *shape), opt=(bs, *shape), max=(bs, *shape))
    return list(profiles.values())
def main():
    parser = argparse.ArgumentParser(description="Creates a TensorRT engine from the provided ONNX file.\n")
    parser.add_argument("--onnx", required=True, help="The ONNX model file to convert to TensorRT")
    parser.add_argument("-o", "--output", type=str, default="model.engine", help="The path at which to write the engine")
    parser.add_argument("-b", "--max-batch-size", type=int, help="The max batch size for the TensorRT engine input")
    parser.add_argument("-v", "--verbosity", action="count", help="Verbosity for logging. (None) for ERROR, (-v) for INFO/WARNING/ERROR, (-vv) for VERBOSE.")
    parser.add_argument("--explicit-batch", action='store_true', help="Set trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH.")
    parser.add_argument("--explicit-precision", action='store_true', help="Set trt.NetworkDefinitionCreationFlag.EXPLICIT_PRECISION.")
    parser.add_argument("--gpu-fallback", action='store_true', help="Set trt.BuilderFlag.GPU_FALLBACK.")
    parser.add_argument("--refittable", action='store_true', help="Set trt.BuilderFlag.REFIT.")
    parser.add_argument("--debug", action='store_true', help="Set trt.BuilderFlag.DEBUG.")
    parser.add_argument("--strict-types", action='store_true', help="Set trt.BuilderFlag.STRICT_TYPES.")
    parser.add_argument("--fp16", action="store_true", help="Attempt to use FP16 kernels when possible.")
    parser.add_argument("--int8", action="store_true", help="Attempt to use INT8 kernels when possible. This should generally be used in addition to the --fp16 flag. \
                                                             ONLY SUPPORTS RESNET-LIKE MODELS SUCH AS RESNET50/VGG16/INCEPTION/etc.")
    parser.add_argument("--calibration-cache", help="(INT8 ONLY) The path to read/write from calibration cache.", default="calibration.cache")
    parser.add_argument("--calibration-data", help="(INT8 ONLY) The directory containing {*.jpg, *.jpeg, *.png} files to use for calibration. (ex: Imagenet Validation Set)", default=None)
    parser.add_argument("--calibration-batch-size", help="(INT8 ONLY) The batch size to use during calibration.", type=int, default=128)
    parser.add_argument("--max-calibration-size", help="(INT8 ONLY) The max number of data to calibrate on from --calibration-data.", type=int, default=2048)
    parser.add_argument("-s", "--simple", action="store_true", help="Use SimpleCalibrator with random data instead of ImagenetCalibrator for INT8 calibration.")
    args, _ = parser.parse_known_args()
    print(args)
    # Adjust logging verbosity
    if args.verbosity is None:
        TRT_LOGGER.min_severity = trt.Logger.Severity.ERROR
    # -v
    elif args.verbosity == 1:
        TRT_LOGGER.min_severity = trt.Logger.Severity.INFO
    # -vv
    else:
        TRT_LOGGER.min_severity = trt.Logger.Severity.VERBOSE
    logger.info("TRT_LOGGER Verbosity: {:}".format(TRT_LOGGER.min_severity))
    # Network flags
    network_flags = 0
    if args.explicit_batch:
        network_flags |= 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
    if args.explicit_precision:
        network_flags |= 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_PRECISION)
    builder_flag_map = {
            'gpu_fallback': trt.BuilderFlag.GPU_FALLBACK,
            'refittable': trt.BuilderFlag.REFIT,
            'debug': trt.BuilderFlag.DEBUG,
            'strict_types': trt.BuilderFlag.STRICT_TYPES,
            'fp16': trt.BuilderFlag.FP16,
            'int8': trt.BuilderFlag.INT8,
    # Building engine
    with trt.Builder(TRT_LOGGER) as builder, \
         builder.create_network(network_flags) as network, \
         builder.create_builder_config() as config, \
         trt.OnnxParser(network, TRT_LOGGER) as parser:
        config.max_workspace_size = 2**30 # 1GiB
        # Set Builder Config Flags
        for flag in builder_flag_map:
            if getattr(args, flag):
                logger.info("Setting {}".format(builder_flag_map[flag]))
                config.set_flag(builder_flag_map[flag])
        # Fill network atrributes with information by parsing model
        with open(args.onnx, "rb") as f:
            if not parser.parse(f.read()):
                print('ERROR: Failed to parse the ONNX file: {}'.format(args.onnx))
                for error in range(parser.num_errors):
                    print(parser.get_error(error))
                sys.exit(1)
        # Display network info and check certain properties
            # Add optimization profiles
            batch_sizes = [1, 8, 16, 32, 64]
            opt_profiles = create_optimization_profiles(builder, inputs, batch_sizes)
        # Implicit Batch Network
        else:
            builder.max_batch_size = args.max_batch_size
            opt_profiles = []
        # Precision flags
        if args.fp16 and not builder.platform_has_fast_fp16:
            logger.warning("FP16 not supported on this platform.")
        if args.int8 and not builder.platform_has_fast_int8:
            logger.warning("INT8 not supported on this platform.")
        if args.int8:
                from calibrator import ImageCalibrator, get_int8_calibrator # local module
                config.int8_calibrator = get_int8_calibrator(args.calibration_cache,
                                                             args.calibration_data,
                                                             args.max_calibration_size,
                                                             args.calibration_batch_size,
                                                             use_cv2=True)
        logger.info("Building Engine...")
        with builder.build_engine(network, config) as engine, open(args.output, "wb") as f:
            logger.info("Serializing engine to file: {:}".format(args.output))
            f.write(engine.serialize())
if __name__ == "__main__":
    main()
Steps To Reproduce
python3 onnx_to_tensorrt.py --onnx weights/onnx/yolo.onnx -o weights/tensorrt/yolo/1/model.plan -b 4 --explicit-batch
After running above module getting below output,
2023-10-19 22:59:43 - __main__ - INFO - TRT_LOGGER Verbosity: Severity.ERROR
2023-10-19 22:59:44 - __main__ - INFO - Setting BuilderFlag.DEBUG
2023-10-19 22:59:44 - __main__ - DEBUG - === Network Description ===
2023-10-19 22:59:44 - __main__ - DEBUG - Input  0 | Name: images   | Shape: (1, 3, 640, 640)
2023-10-19 22:59:44 - __main__ - DEBUG - Output 0 | Name: num_dets | Shape: (1, 1)
2023-10-19 22:59:44 - __main__ - DEBUG - Output 1 | Name: bboxes   | Shape: (1, 100, 4)
2023-10-19 22:59:44 - __main__ - DEBUG - Output 2 | Name: scores   | Shape: (1, 100)
2023-10-19 22:59:44 - __main__ - DEBUG - Output 3 | Name: labels   | Shape: (1, 100)
2023-10-19 22:59:44 - __main__ - DEBUG - === Optimization Profiles ===
[<tensorrt.tensorrt.IOptimizationProfile object at 0x7f65c0ed9370>]
2023-10-19 22:59:44 - __main__ - DEBUG - images - OptProfile 0 - Min (1, 3, 640, 640) Opt (1, 3, 640, 640) Max (1, 3, 640, 640)
As it can be seen the optimization profile with explicit batch producing engine with batch size =1 for Min,opt, Max. hence while using the serialized model with deepstream pipeline for inference it works fine with batch size 1 but when given batch size more than 1 it’s giving below error.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 5
0   INPUT  kFLOAT images          3x640x640
1   OUTPUT kINT32 num_dets        1
2   OUTPUT kFLOAT bboxes          100x4
3   OUTPUT kFLOAT scores          100
4   OUTPUT kINT32 labels          100
0:00:01.577760094 210682 0x558ffb09ac30 WARN                 nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1832> [UID = 1]: Backend has maxBatchSize 1 whereas 4 has been requested
0:00:01.577828584 210682 0x558ffb09ac30 WARN                 nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2009> [UID = 1]: deserialized backend context :/home/swap/ultraanalytics/Video-Analytics/weights/tensorrt/yolo/1/model.plan failed to match config params, trying rebuild
0:00:01.587609677 210682 0x558ffb09ac30 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:860 failed to build network since there is no model file matched.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:799 failed to build network.
0:00:01.818346447 210682 0x558ffb09ac30 ERROR                nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:01.830573491 210682 0x558ffb09ac30 ERROR                nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:01.830606726 210682 0x558ffb09ac30 ERROR                nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:01.831121799 210682 0x558ffb09ac30 WARN                 nvinfer gstnvinfer.cpp:846:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
Any help on this would be appreciated,
Thank You!
(1) Is there a reason that you are not using later versions of TensorRT? Later versions give much better support of dynamic batch size.
(2) Does your onnx have dynamic axis? Sometimes it is because you are using static-batch onnx, so TRT is not able to build dynamic batch size engine. It is better to share ONNX(especially the IO shape)
Can you try running your model with trtexec command, and share the “”–verbose"" log in case if the issue persist
You can refer below link for all the supported operators list, in case any operator is not supported you need to create a custom plugin to support that operation
Also, request you to share your model and script if not shared already so that we can help you better.
Meanwhile, for some common errors and queries please refer to below link:
