Hi, I’m running the same software environment. How did you get CUDA10 to work with Deepstream? I ran the sample deepstream-app and it just gave me the following error:
(gst-plugin-scanner:25243): GStreamer-WARNING **: 18:22:45.131: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvosd.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
Hi there,
Actually running trt example does not require DeepStream framework.
But to be honest, I also occurred the problem you mentioned when trying DeepStream on CUDA 10.
