I am unable to install Deepstream SDK 6.4
Hardware GTX1650
CUDA: 12.2
Driver: NVIDIA-SMI 535.104.12
TensorRT : 10.0.0.6-1+cuda12.4
Please follow the installation guide here: Quickstart Guide — DeepStream documentation 6.4 documentation
I exactly followed the same documentation and the steps in it.
Just the difference was i downloaded tensorRT 10 directly through tensorRT documentation as the version mentioned on the deepstream page was throwing an error of version mismatch.
I’m not sure if all the steps in the installation guides are done correctly, but the TensorRT version you listed is not the correct version for DeepStream 6.4, refer the dependencies as below:
- Ubuntu 22.04
- GStreamer 1.20.3
- NVIDIA driver 535.104.12
- CUDA 12.2
- TensorRT 8.6.1.6
May be you can start from " Remove all previous DeepStream installations" and install again.
or I could simply use docker containers.
That would be as flexible as installing DS locally on my system right?
I am using docker now.
I get this error :
root@utkarsh:/opt/nvidia/deepstream/deepstream-6.4# deepstream-app -c /samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:112): GStreamer-WARNING **: 22:37:37.242: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:116): GStreamer-WARNING **: 22:37:37.282: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:116): GStreamer-WARNING **: 22:37:37.324: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:116): GStreamer-WARNING **: 22:37:37.359: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:116): GStreamer-WARNING **: 22:37:37.363: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:116): GStreamer-WARNING **: 22:37:37.368: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
** ERROR: <parse_config_file:774>: parse_config_file failed
** ERROR: main:687: Failed to parse config file ‘/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt’
Quitting
App run failed
Quitting
App run failed
Quitting
App run failed
It should be deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt, this is not an absolute path.
These are some GPL plugins that are not included in docker, you can install them using user_additional_install.sh
- when i do
output:
root@utkarsh:/opt/nvidia/deepstream/deepstream-6.4# deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:927): GStreamer-WARNING **: 06:21:15.848: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
Authorization required, but no authorization protocol specified
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
App run failed
- I have also installed additional packages by
/opt/nvidia/deepstream/deepstream/user_additional_install.sh
What is the command you used to start docker? Run xhost + before starting docker
(base) utkarsh@utkarsh:~$ xhost +
access control disabled, clients can connect from any host
(base) utkarsh@utkarsh:~$ sudo docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.4 nvcr.io/nvidia/deepstream:6.4-gc-triton-devel
[sudo] password for utkarsh:
DeepStreamSDK 6.4.0
*** LICENSE AGREEMENT ***
By using this software you agree to fully comply with the terms and conditions
of the License Agreement. The License Agreement is located at
/opt/nvidia/deepstream/deepstream/LicenseAgreement.pdf. If you do not agree
to the terms and conditions of the License Agreement do not use the software.
== Triton Inference Server ==
NVIDIA Release 23.08 (build 66820947)
Triton Server Version 2.37.0
Copyright (c) 2018-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
(gst-plugin-scanner:111): GStreamer-WARNING **: 06:53:24.372: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:115): GStreamer-WARNING **: 06:53:24.437: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:115): GStreamer-WARNING **: 06:53:24.491: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:115): GStreamer-WARNING **: 06:53:24.528: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:115): GStreamer-WARNING **: 06:53:24.531: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:115): GStreamer-WARNING **: 06:53:24.536: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine open error
0:00:04.798942168 110 0x5607405c2f30 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine failed
0:00:04.871840945 110 0x5607405c2f30 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine failed, try rebuild
0:00:04.871861833 110 0x5607405c2f30 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 5]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
WARNING: [TRT]: Missing scale and zero-point for tensor conv1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor bn_conv1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor predictions/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor predictions/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
and it’s stuck at this point only.
This is normal, it will take some time to convert the model, just wait until it is completed.
Yes it did work.
But would it take this much of time to start usually?
It depends on the performance of the GPU
Alright, thanks for the help.
