Alright, I added the -p and ran the tao-converter, but I’m still seeing the same thing (e.g. the shape does not match). I’m wondering if there is something going on that is forcing the model to get converted with 3 channels and as a fp32? It seems like no matter what I specify in the tao-converter, I always get a 3 channel, fp32 engine file.
Below is all of the output.
Tao-Converter:
$ ./tao-converter -k nvidia_tlt -p image_arrays:0,1x1376x1024x1,8x1376x1024x1,16x1376x1024x1 -c /opt/nvidia/deepstream/deepstream-6.0/samples/models/test_model/grayscale_efficientdet/model.step-325832.cal -e /opt/nvidia/deepstream/deepstream-6.0/samples/models/test_model/grayscale_efficientdet/model.engine -b 2 -t int8 /opt/nvidia/deepstream/deepstream-6.0/samples/models/test_model/grayscale_efficientdet/model.etlt
[INFO] [MemUsageChange] Init CUDA: CPU +353, GPU +0, now: CPU 371, GPU 5777 (MiB)
[INFO] ----------------------------------------------------------------
[INFO] Input filename: /tmp/fileXP3R1y
[INFO] ONNX IR version: 0.0.7
[INFO] Opset version: 13
[INFO] Producer name:
[INFO] Producer version:
[INFO] Domain:
[INFO] Model version: 0
[INFO] Doc string:
[WARNING] onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[INFO] No importer registered for op: EfficientNMS_TRT. Attempting to import as plugin.
[INFO] Searching for plugin: EfficientNMS_TRT, plugin_version: 1, plugin_namespace:
[INFO] Successfully created plugin: EfficientNMS_TRT
[INFO] Detected input dimensions from the model: (1, 1376, 1024, 3)
[INFO] Model has no dynamic shape.
[INFO] [MemUsageSnapshot] Builder begin: CPU 395 MiB, GPU 5840 MiB
[INFO] Reading Calibration Cache for calibrator: EntropyCalibration2
[INFO] Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
[INFO] To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 97) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 208) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 211) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 309) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 312) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 316) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 319) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 326) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 333) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 339) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 351) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 356) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 362) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 374) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 379) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 385) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 397) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 402) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 408) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 420) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 423) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 430) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 442) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 445) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 448) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 456) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 468) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 471) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 474) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 482) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 494) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 497) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 500) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 508) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 520) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 525) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 531) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 543) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 548) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 554) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 566) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 571) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 577) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 589) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 594) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 600) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 612) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 615) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 622) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 634) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 637) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 640) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 648) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 660) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 663) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 666) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 674) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 686) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 689) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 692) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 700) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 712) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 717) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 723) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 735) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 740) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 746) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 758) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 763) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 769) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 781) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 786) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 792) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 807) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 821) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 854) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 876) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 909) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 931) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 964) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor (Unnamed Layer* 986) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[INFO] ---------- Layers Running on DLA ----------
[INFO] ---------- Layers Running on GPU ----------
[INFO] [GpuLayer] preprocessor/transpose
[INFO] [GpuLayer] preprocessor/scale_value:0 + preprocessor/scale + preprocessor/mean_value:0 + preprocessor/mean
[INFO] [GpuLayer] stem_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(stem_activation/Sigmoid), stem_activation/mul)
[INFO] [GpuLayer] block1a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block1a_activation/Sigmoid), block1a_activation/mul)
[INFO] [GpuLayer] block1a_se_squeeze/Mean
[INFO] [GpuLayer] block1a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block1a_se_reduce/Sigmoid), block1a_se_reduce/mul)
[INFO] [GpuLayer] block1a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block1a_se_expand/Sigmoid), block1a_se_excite/mul)
[INFO] [GpuLayer] block1a_project_conv/Conv2D
[INFO] [GpuLayer] block2a_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block2a_expand_activation/Sigmoid), block2a_expand_activation/mul)
[INFO] [GpuLayer] block2a_dwconv_pad/Pad + block2a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block2a_activation/Sigmoid), block2a_activation/mul)
[INFO] [GpuLayer] block2a_se_squeeze/Mean
[INFO] [GpuLayer] block2a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block2a_se_reduce/Sigmoid), block2a_se_reduce/mul)
[INFO] [GpuLayer] block2a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block2a_se_expand/Sigmoid), block2a_se_excite/mul)
[INFO] [GpuLayer] block2a_project_conv/Conv2D
[INFO] [GpuLayer] block2b_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block2b_expand_activation/Sigmoid), block2b_expand_activation/mul)
[INFO] [GpuLayer] block2b_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block2b_activation/Sigmoid), block2b_activation/mul)
[INFO] [GpuLayer] block2b_se_squeeze/Mean
[INFO] [GpuLayer] block2b_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block2b_se_reduce/Sigmoid), block2b_se_reduce/mul)
[INFO] [GpuLayer] block2b_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block2b_se_expand/Sigmoid), block2b_se_excite/mul)
[INFO] [GpuLayer] block2b_project_conv/Conv2D + block2b_add/add
[INFO] [GpuLayer] block3a_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block3a_expand_activation/Sigmoid), block3a_expand_activation/mul)
[INFO] [GpuLayer] block3a_dwconv_pad/Pad + block3a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block3a_activation/Sigmoid), block3a_activation/mul)
[INFO] [GpuLayer] block3a_se_squeeze/Mean
[INFO] [GpuLayer] block3a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block3a_se_reduce/Sigmoid), block3a_se_reduce/mul)
[INFO] [GpuLayer] block3a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block3a_se_expand/Sigmoid), block3a_se_excite/mul)
[INFO] [GpuLayer] block3a_project_conv/Conv2D
[INFO] [GpuLayer] block3b_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block3b_expand_activation/Sigmoid), block3b_expand_activation/mul)
[INFO] [GpuLayer] block3b_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block3b_activation/Sigmoid), block3b_activation/mul)
[INFO] [GpuLayer] block3b_se_squeeze/Mean
[INFO] [GpuLayer] block3b_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block3b_se_reduce/Sigmoid), block3b_se_reduce/mul)
[INFO] [GpuLayer] block3b_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block3b_se_expand/Sigmoid), block3b_se_excite/mul)
[INFO] [GpuLayer] block3b_project_conv/Conv2D + block3b_add/add
[INFO] [GpuLayer] bifpn0_0_8_0/BiasAdd || block4a_expand_conv/Conv2D
[INFO] [GpuLayer] bifpn0_0_8_0_bn/FusedBatchNormV3__1956
[INFO] [GpuLayer] PWN(PWN(block4a_expand_activation/Sigmoid), block4a_expand_activation/mul)
[INFO] [GpuLayer] weighted_fusion_3_0/strided_slice__990:0 + (Unnamed Layer* 98) [Shuffle] + weighted_fusion_3_0/mul
[INFO] [GpuLayer] weighted_fusion_3_0/Sum/input_Unsqueeze__1958
[INFO] [GpuLayer] block4a_dwconv_pad/Pad + block4a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block4a_activation/Sigmoid), block4a_activation/mul)
[INFO] [GpuLayer] block4a_se_squeeze/Mean
[INFO] [GpuLayer] block4a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4a_se_reduce/Sigmoid), block4a_se_reduce/mul)
[INFO] [GpuLayer] block4a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4a_se_expand/Sigmoid), block4a_se_excite/mul)
[INFO] [GpuLayer] block4a_project_conv/Conv2D
[INFO] [GpuLayer] block4b_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block4b_expand_activation/Sigmoid), block4b_expand_activation/mul)
[INFO] [GpuLayer] block4b_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block4b_activation/Sigmoid), block4b_activation/mul)
[INFO] [GpuLayer] block4b_se_squeeze/Mean
[INFO] [GpuLayer] block4b_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4b_se_reduce/Sigmoid), block4b_se_reduce/mul)
[INFO] [GpuLayer] block4b_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4b_se_expand/Sigmoid), block4b_se_excite/mul)
[INFO] [GpuLayer] block4b_project_conv/Conv2D + block4b_add/add
[INFO] [GpuLayer] block4c_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block4c_expand_activation/Sigmoid), block4c_expand_activation/mul)
[INFO] [GpuLayer] block4c_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block4c_activation/Sigmoid), block4c_activation/mul)
[INFO] [GpuLayer] block4c_se_squeeze/Mean
[INFO] [GpuLayer] block4c_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4c_se_reduce/Sigmoid), block4c_se_reduce/mul)
[INFO] [GpuLayer] block4c_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block4c_se_expand/Sigmoid), block4c_se_excite/mul)
[INFO] [GpuLayer] block4c_project_conv/Conv2D + block4c_add/add
[INFO] [GpuLayer] block5a_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block5a_expand_activation/Sigmoid), block5a_expand_activation/mul)
[INFO] [GpuLayer] block5a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block5a_activation/Sigmoid), block5a_activation/mul)
[INFO] [GpuLayer] block5a_se_squeeze/Mean
[INFO] [GpuLayer] block5a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5a_se_reduce/Sigmoid), block5a_se_reduce/mul)
[INFO] [GpuLayer] block5a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5a_se_expand/Sigmoid), block5a_se_excite/mul)
[INFO] [GpuLayer] block5a_project_conv/Conv2D
[INFO] [GpuLayer] block5b_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block5b_expand_activation/Sigmoid), block5b_expand_activation/mul)
[INFO] [GpuLayer] block5b_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block5b_activation/Sigmoid), block5b_activation/mul)
[INFO] [GpuLayer] block5b_se_squeeze/Mean
[INFO] [GpuLayer] block5b_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5b_se_reduce/Sigmoid), block5b_se_reduce/mul)
[INFO] [GpuLayer] block5b_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5b_se_expand/Sigmoid), block5b_se_excite/mul)
[INFO] [GpuLayer] block5b_project_conv/Conv2D + block5b_add/add
[INFO] [GpuLayer] block5c_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block5c_expand_activation/Sigmoid), block5c_expand_activation/mul)
[INFO] [GpuLayer] block5c_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block5c_activation/Sigmoid), block5c_activation/mul)
[INFO] [GpuLayer] block5c_se_squeeze/Mean
[INFO] [GpuLayer] block5c_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5c_se_reduce/Sigmoid), block5c_se_reduce/mul)
[INFO] [GpuLayer] block5c_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block5c_se_expand/Sigmoid), block5c_se_excite/mul)
[INFO] [GpuLayer] block5c_project_conv/Conv2D + block5c_add/add
[INFO] [GpuLayer] bifpn0_1_9_0/BiasAdd || bifpn0_1_7_0/BiasAdd || block6a_expand_conv/Conv2D
[INFO] [GpuLayer] bifpn0_1_9_0_bn/FusedBatchNormV3__1921
[INFO] [GpuLayer] bifpn0_1_7_0_bn/FusedBatchNormV3__1925
[INFO] [GpuLayer] PWN(PWN(block6a_expand_activation/Sigmoid), block6a_expand_activation/mul)
[INFO] [GpuLayer] weighted_fusion_4_0/strided_slice__957:0 + (Unnamed Layer* 209) [Shuffle] + weighted_fusion_4_0/mul
[INFO] [GpuLayer] weighted_fusion_2_0/strided_slice__1023:0 + (Unnamed Layer* 212) [Shuffle] + weighted_fusion_2_0/mul
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1977
[INFO] [GpuLayer] weighted_fusion_2_0/Sum/input_Unsqueeze__1927
[INFO] [GpuLayer] block6a_dwconv_pad/Pad + block6a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block6a_activation/Sigmoid), block6a_activation/mul)
[INFO] [GpuLayer] block6a_se_squeeze/Mean
[INFO] [GpuLayer] block6a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6a_se_reduce/Sigmoid), block6a_se_reduce/mul)
[INFO] [GpuLayer] block6a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6a_se_expand/Sigmoid), block6a_se_excite/mul)
[INFO] [GpuLayer] block6a_project_conv/Conv2D
[INFO] [GpuLayer] block6b_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block6b_expand_activation/Sigmoid), block6b_expand_activation/mul)
[INFO] [GpuLayer] block6b_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block6b_activation/Sigmoid), block6b_activation/mul)
[INFO] [GpuLayer] block6b_se_squeeze/Mean
[INFO] [GpuLayer] block6b_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6b_se_reduce/Sigmoid), block6b_se_reduce/mul)
[INFO] [GpuLayer] block6b_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6b_se_expand/Sigmoid), block6b_se_excite/mul)
[INFO] [GpuLayer] block6b_project_conv/Conv2D + block6b_add/add
[INFO] [GpuLayer] block6c_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block6c_expand_activation/Sigmoid), block6c_expand_activation/mul)
[INFO] [GpuLayer] block6c_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block6c_activation/Sigmoid), block6c_activation/mul)
[INFO] [GpuLayer] block6c_se_squeeze/Mean
[INFO] [GpuLayer] block6c_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6c_se_reduce/Sigmoid), block6c_se_reduce/mul)
[INFO] [GpuLayer] block6c_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6c_se_expand/Sigmoid), block6c_se_excite/mul)
[INFO] [GpuLayer] block6c_project_conv/Conv2D + block6c_add/add
[INFO] [GpuLayer] block6d_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block6d_expand_activation/Sigmoid), block6d_expand_activation/mul)
[INFO] [GpuLayer] block6d_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block6d_activation/Sigmoid), block6d_activation/mul)
[INFO] [GpuLayer] block6d_se_squeeze/Mean
[INFO] [GpuLayer] block6d_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6d_se_reduce/Sigmoid), block6d_se_reduce/mul)
[INFO] [GpuLayer] block6d_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block6d_se_expand/Sigmoid), block6d_se_excite/mul)
[INFO] [GpuLayer] block6d_project_conv/Conv2D + block6d_add/add
[INFO] [GpuLayer] block7a_expand_conv/Conv2D
[INFO] [GpuLayer] PWN(PWN(block7a_expand_activation/Sigmoid), block7a_expand_activation/mul)
[INFO] [GpuLayer] block7a_dwconv/depthwise
[INFO] [GpuLayer] PWN(PWN(block7a_activation/Sigmoid), block7a_activation/mul)
[INFO] [GpuLayer] block7a_se_squeeze/Mean
[INFO] [GpuLayer] block7a_se_reduce/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block7a_se_reduce/Sigmoid), block7a_se_reduce/mul)
[INFO] [GpuLayer] block7a_se_expand/BiasAdd
[INFO] [GpuLayer] PWN(PWN(block7a_se_expand/Sigmoid), block7a_se_excite/mul)
[INFO] [GpuLayer] block7a_project_conv/Conv2D
[INFO] [GpuLayer] p6/BiasAdd || bifpn0_2_6_0/BiasAdd || bifpn0_2_10_0/BiasAdd
[INFO] [GpuLayer] max_pooling2d/MaxPool
[INFO] [GpuLayer] bifpn0_2_6_0_bn/FusedBatchNormV3__1886
[INFO] [GpuLayer] bifpn0_2_10_0_bn/FusedBatchNormV3__1917
[INFO] [GpuLayer] max_pooling2d_1/MaxPool
[INFO] [GpuLayer] Transpose__3595
[INFO] [GpuLayer] weighted_fusion_1_0/strided_slice__1056:0 + (Unnamed Layer* 310) [Shuffle] + weighted_fusion_1_0/mul
[INFO] [GpuLayer] weighted_fusion_5_0/strided_slice__909:0 + (Unnamed Layer* 313) [Shuffle] + weighted_fusion_5_0/mul
[INFO] [GpuLayer] Transpose__3046
[INFO] [GpuLayer] Resize__1855
[INFO] [GpuLayer] weighted_fusion_6_0/strided_slice__861:0 + (Unnamed Layer* 317) [Shuffle] + weighted_fusion_6_0/mul
[INFO] [GpuLayer] weighted_fusion_0_0/strided_slice__1089:0 + (Unnamed Layer* 320) [Shuffle] + weighted_fusion_0_0/mul
[INFO] [GpuLayer] weighted_fusion_1_0/Sum/input_Unsqueeze__1888
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__1998
[INFO] [GpuLayer] weighted_fusion_7_0/strided_slice__813:0 + (Unnamed Layer* 327) [Shuffle] + weighted_fusion_7_0/mul
[INFO] [GpuLayer] image_resize_layer/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2019
[INFO] [GpuLayer] weighted_fusion_0_0/Sum/input_Unsqueeze__1857
[INFO] [GpuLayer] weighted_fusion_7_0/Sum/input_Unsqueeze__2040
[INFO] [GpuLayer] weighted_fusion_0_0/strided_slice_1__1084:0 + (Unnamed Layer* 334) [Shuffle] + weighted_fusion_0_0/mul_1
[INFO] [GpuLayer] weighted_fusion_0_0/Sum/input_Unsqueeze__1859
[INFO] [GpuLayer] weighted_fusion_0_0/Sum/input_Unsqueeze__1857:0 copy
[INFO] [GpuLayer] weighted_fusion_0_0/Sum/input_Unsqueeze__1859:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_0_0/add:0 + (Unnamed Layer* 340) [Shuffle], weighted_fusion_0_0/truediv), PWN(PWN(activation/Sigmoid), activation/mul))
[INFO] [GpuLayer] after_combine_dw_conv_0_0/separable_conv2d/depthwise__1864
[INFO] [GpuLayer] after_combine_dw_conv_0_0/BiasAdd
[INFO] [GpuLayer] Transpose__3047
[INFO] [GpuLayer] Resize__1882
[INFO] [GpuLayer] weighted_fusion_6_0/strided_slice_1__856:0 + (Unnamed Layer* 352) [Shuffle] + weighted_fusion_6_0/mul_1
[INFO] [GpuLayer] image_resize_layer_1/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2021
[INFO] [GpuLayer] weighted_fusion_1_0/strided_slice_1__1051:0 + (Unnamed Layer* 357) [Shuffle] + weighted_fusion_1_0/mul_1
[INFO] [GpuLayer] weighted_fusion_1_0/Sum/input_Unsqueeze__1890
[INFO] [GpuLayer] weighted_fusion_1_0/Sum/input_Unsqueeze__1888:0 copy
[INFO] [GpuLayer] weighted_fusion_1_0/Sum/input_Unsqueeze__1890:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_1_0/add:0 + (Unnamed Layer* 363) [Shuffle], weighted_fusion_1_0/truediv), PWN(PWN(activation_1/Sigmoid), activation_1/mul))
[INFO] [GpuLayer] after_combine_dw_conv_1_0/separable_conv2d/depthwise__1895
[INFO] [GpuLayer] after_combine_dw_conv_1_0/BiasAdd
[INFO] [GpuLayer] Transpose__3050
[INFO] [GpuLayer] Resize__1913
[INFO] [GpuLayer] weighted_fusion_5_0/strided_slice_1__904:0 + (Unnamed Layer* 375) [Shuffle] + weighted_fusion_5_0/mul_1
[INFO] [GpuLayer] image_resize_layer_2/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__2000
[INFO] [GpuLayer] weighted_fusion_2_0/strided_slice_1__1018:0 + (Unnamed Layer* 380) [Shuffle] + weighted_fusion_2_0/mul_1
[INFO] [GpuLayer] weighted_fusion_2_0/Sum/input_Unsqueeze__1929
[INFO] [GpuLayer] weighted_fusion_2_0/Sum/input_Unsqueeze__1927:0 copy
[INFO] [GpuLayer] weighted_fusion_2_0/Sum/input_Unsqueeze__1929:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_2_0/add:0 + (Unnamed Layer* 386) [Shuffle], weighted_fusion_2_0/truediv), PWN(PWN(activation_2/Sigmoid), activation_2/mul))
[INFO] [GpuLayer] after_combine_dw_conv_2_0/separable_conv2d/depthwise__1934
[INFO] [GpuLayer] after_combine_dw_conv_2_0/BiasAdd
[INFO] [GpuLayer] Transpose__3052
[INFO] [GpuLayer] Resize__1952
[INFO] [GpuLayer] weighted_fusion_4_0/strided_slice_1__952:0 + (Unnamed Layer* 398) [Shuffle] + weighted_fusion_4_0/mul_1
[INFO] [GpuLayer] image_resize_layer_3/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1979
[INFO] [GpuLayer] weighted_fusion_3_0/strided_slice_1__985:0 + (Unnamed Layer* 403) [Shuffle] + weighted_fusion_3_0/mul_1
[INFO] [GpuLayer] weighted_fusion_3_0/Sum/input_Unsqueeze__1960
[INFO] [GpuLayer] weighted_fusion_3_0/Sum/input_Unsqueeze__1958:0 copy
[INFO] [GpuLayer] weighted_fusion_3_0/Sum/input_Unsqueeze__1960:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_3_0/add:0 + (Unnamed Layer* 409) [Shuffle], weighted_fusion_3_0/truediv), PWN(PWN(activation_3/Sigmoid), activation_3/mul))
[INFO] [GpuLayer] after_combine_dw_conv_3_0/separable_conv2d/depthwise__1965
[INFO] [GpuLayer] after_combine_dw_conv_3_0/BiasAdd
[INFO] [GpuLayer] max_pooling2d_2/MaxPool
[INFO] [GpuLayer] Transpose__3053
[INFO] [GpuLayer] max_pooling2d_2/MaxPool__1975
[INFO] [GpuLayer] weighted_fusion_3_1/strided_slice__979:0 + (Unnamed Layer* 421) [Shuffle] + weighted_fusion_3_1/mul
[INFO] [GpuLayer] weighted_fusion_4_0/strided_slice_2__947:0 + (Unnamed Layer* 424) [Shuffle] + weighted_fusion_4_0/mul_2
[INFO] [GpuLayer] weighted_fusion_3_1/Sum/input_Unsqueeze__2148
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1981
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1977:0 copy
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1979:0 copy
[INFO] [GpuLayer] weighted_fusion_4_0/Sum/input_Unsqueeze__1981:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_4_0/add:0 + (Unnamed Layer* 431) [Shuffle], weighted_fusion_4_0/truediv), PWN(PWN(activation_4/Sigmoid), activation_4/mul))
[INFO] [GpuLayer] after_combine_dw_conv_4_0/separable_conv2d/depthwise__1986
[INFO] [GpuLayer] after_combine_dw_conv_4_0/BiasAdd
[INFO] [GpuLayer] max_pooling2d_3/MaxPool
[INFO] [GpuLayer] Transpose__3603
[INFO] [GpuLayer] max_pooling2d_3/MaxPool__1996
[INFO] [GpuLayer] weighted_fusion_4_1/strided_slice__941:0 + (Unnamed Layer* 443) [Shuffle] + weighted_fusion_4_1/mul
[INFO] [GpuLayer] weighted_fusion_2_1/strided_slice__1012:0 + (Unnamed Layer* 446) [Shuffle] + weighted_fusion_2_1/mul
[INFO] [GpuLayer] weighted_fusion_5_0/strided_slice_2__899:0 + (Unnamed Layer* 449) [Shuffle] + weighted_fusion_5_0/mul_2
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2167
[INFO] [GpuLayer] weighted_fusion_2_1/Sum/input_Unsqueeze__2121
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__2002
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__1998:0 copy
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__2000:0 copy
[INFO] [GpuLayer] weighted_fusion_5_0/Sum/input_Unsqueeze__2002:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_5_0/add:0 + (Unnamed Layer* 457) [Shuffle], weighted_fusion_5_0/truediv), PWN(PWN(activation_5/Sigmoid), activation_5/mul))
[INFO] [GpuLayer] after_combine_dw_conv_5_0/separable_conv2d/depthwise__2007
[INFO] [GpuLayer] after_combine_dw_conv_5_0/BiasAdd
[INFO] [GpuLayer] max_pooling2d_4/MaxPool
[INFO] [GpuLayer] Transpose__3599
[INFO] [GpuLayer] max_pooling2d_4/MaxPool__2017
[INFO] [GpuLayer] weighted_fusion_5_1/strided_slice__893:0 + (Unnamed Layer* 469) [Shuffle] + weighted_fusion_5_1/mul
[INFO] [GpuLayer] weighted_fusion_1_1/strided_slice__1045:0 + (Unnamed Layer* 472) [Shuffle] + weighted_fusion_1_1/mul
[INFO] [GpuLayer] weighted_fusion_6_0/strided_slice_2__851:0 + (Unnamed Layer* 475) [Shuffle] + weighted_fusion_6_0/mul_2
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2188
[INFO] [GpuLayer] weighted_fusion_1_1/Sum/input_Unsqueeze__2094
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2023
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2019:0 copy
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2021:0 copy
[INFO] [GpuLayer] weighted_fusion_6_0/Sum/input_Unsqueeze__2023:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_6_0/add:0 + (Unnamed Layer* 483) [Shuffle], weighted_fusion_6_0/truediv), PWN(PWN(activation_6/Sigmoid), activation_6/mul))
[INFO] [GpuLayer] after_combine_dw_conv_6_0/separable_conv2d/depthwise__2028
[INFO] [GpuLayer] after_combine_dw_conv_6_0/BiasAdd
[INFO] [GpuLayer] max_pooling2d_5/MaxPool
[INFO] [GpuLayer] Transpose__3605
[INFO] [GpuLayer] max_pooling2d_5/MaxPool__2038
[INFO] [GpuLayer] weighted_fusion_6_1/strided_slice__845:0 + (Unnamed Layer* 495) [Shuffle] + weighted_fusion_6_1/mul
[INFO] [GpuLayer] weighted_fusion_0_1/strided_slice__1078:0 + (Unnamed Layer* 498) [Shuffle] + weighted_fusion_0_1/mul
[INFO] [GpuLayer] weighted_fusion_7_0/strided_slice_1__808:0 + (Unnamed Layer* 501) [Shuffle] + weighted_fusion_7_0/mul_1
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2209
[INFO] [GpuLayer] weighted_fusion_0_1/Sum/input_Unsqueeze__2067
[INFO] [GpuLayer] weighted_fusion_7_0/Sum/input_Unsqueeze__2042
[INFO] [GpuLayer] weighted_fusion_7_0/Sum/input_Unsqueeze__2040:0 copy
[INFO] [GpuLayer] weighted_fusion_7_0/Sum/input_Unsqueeze__2042:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_7_0/add:0 + (Unnamed Layer* 509) [Shuffle], weighted_fusion_7_0/truediv), PWN(PWN(activation_7/Sigmoid), activation_7/mul))
[INFO] [GpuLayer] after_combine_dw_conv_7_0/separable_conv2d/depthwise__2047
[INFO] [GpuLayer] after_combine_dw_conv_7_0/BiasAdd
[INFO] [GpuLayer] Transpose__3065
[INFO] [GpuLayer] Resize__2065
[INFO] [GpuLayer] weighted_fusion_7_1/strided_slice__802:0 + (Unnamed Layer* 521) [Shuffle] + weighted_fusion_7_1/mul
[INFO] [GpuLayer] image_resize_layer_4/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_7_1/Sum/input_Unsqueeze__2230
[INFO] [GpuLayer] weighted_fusion_0_1/strided_slice_1__1073:0 + (Unnamed Layer* 526) [Shuffle] + weighted_fusion_0_1/mul_1
[INFO] [GpuLayer] weighted_fusion_0_1/Sum/input_Unsqueeze__2069
[INFO] [GpuLayer] weighted_fusion_0_1/Sum/input_Unsqueeze__2067:0 copy
[INFO] [GpuLayer] weighted_fusion_0_1/Sum/input_Unsqueeze__2069:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_0_1/add:0 + (Unnamed Layer* 532) [Shuffle], weighted_fusion_0_1/truediv), PWN(PWN(activation_8/Sigmoid), activation_8/mul))
[INFO] [GpuLayer] after_combine_dw_conv_0_1/separable_conv2d/depthwise__2074
[INFO] [GpuLayer] after_combine_dw_conv_0_1/BiasAdd
[INFO] [GpuLayer] Transpose__3067
[INFO] [GpuLayer] Resize__2092
[INFO] [GpuLayer] weighted_fusion_6_1/strided_slice_1__840:0 + (Unnamed Layer* 544) [Shuffle] + weighted_fusion_6_1/mul_1
[INFO] [GpuLayer] image_resize_layer_5/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2211
[INFO] [GpuLayer] weighted_fusion_1_1/strided_slice_1__1040:0 + (Unnamed Layer* 549) [Shuffle] + weighted_fusion_1_1/mul_1
[INFO] [GpuLayer] weighted_fusion_1_1/Sum/input_Unsqueeze__2096
[INFO] [GpuLayer] weighted_fusion_1_1/Sum/input_Unsqueeze__2094:0 copy
[INFO] [GpuLayer] weighted_fusion_1_1/Sum/input_Unsqueeze__2096:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_1_1/add:0 + (Unnamed Layer* 555) [Shuffle], weighted_fusion_1_1/truediv), PWN(PWN(activation_9/Sigmoid), activation_9/mul))
[INFO] [GpuLayer] after_combine_dw_conv_1_1/separable_conv2d/depthwise__2101
[INFO] [GpuLayer] after_combine_dw_conv_1_1/BiasAdd
[INFO] [GpuLayer] Transpose__3069
[INFO] [GpuLayer] Resize__2119
[INFO] [GpuLayer] weighted_fusion_5_1/strided_slice_1__888:0 + (Unnamed Layer* 567) [Shuffle] + weighted_fusion_5_1/mul_1
[INFO] [GpuLayer] image_resize_layer_6/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2190
[INFO] [GpuLayer] weighted_fusion_2_1/strided_slice_1__1007:0 + (Unnamed Layer* 572) [Shuffle] + weighted_fusion_2_1/mul_1
[INFO] [GpuLayer] weighted_fusion_2_1/Sum/input_Unsqueeze__2123
[INFO] [GpuLayer] weighted_fusion_2_1/Sum/input_Unsqueeze__2121:0 copy
[INFO] [GpuLayer] weighted_fusion_2_1/Sum/input_Unsqueeze__2123:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_2_1/add:0 + (Unnamed Layer* 578) [Shuffle], weighted_fusion_2_1/truediv), PWN(PWN(activation_10/Sigmoid), activation_10/mul))
[INFO] [GpuLayer] after_combine_dw_conv_2_1/separable_conv2d/depthwise__2128
[INFO] [GpuLayer] after_combine_dw_conv_2_1/BiasAdd
[INFO] [GpuLayer] Transpose__3071
[INFO] [GpuLayer] Resize__2146
[INFO] [GpuLayer] weighted_fusion_4_1/strided_slice_1__936:0 + (Unnamed Layer* 590) [Shuffle] + weighted_fusion_4_1/mul_1
[INFO] [GpuLayer] image_resize_layer_7/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2169
[INFO] [GpuLayer] weighted_fusion_3_1/strided_slice_1__974:0 + (Unnamed Layer* 595) [Shuffle] + weighted_fusion_3_1/mul_1
[INFO] [GpuLayer] weighted_fusion_3_1/Sum/input_Unsqueeze__2150
[INFO] [GpuLayer] weighted_fusion_3_1/Sum/input_Unsqueeze__2148:0 copy
[INFO] [GpuLayer] weighted_fusion_3_1/Sum/input_Unsqueeze__2150:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_3_1/add:0 + (Unnamed Layer* 601) [Shuffle], weighted_fusion_3_1/truediv), PWN(PWN(activation_11/Sigmoid), activation_11/mul))
[INFO] [GpuLayer] after_combine_dw_conv_3_1/separable_conv2d/depthwise__2155
[INFO] [GpuLayer] after_combine_dw_conv_3_1/BiasAdd
[INFO] [GpuLayer] max_pooling2d_6/MaxPool
[INFO] [GpuLayer] Transpose__3072
[INFO] [GpuLayer] max_pooling2d_6/MaxPool__2165
[INFO] [GpuLayer] weighted_fusion_3_2/strided_slice__968:0 + (Unnamed Layer* 613) [Shuffle] + weighted_fusion_3_2/mul
[INFO] [GpuLayer] weighted_fusion_4_1/strided_slice_2__931:0 + (Unnamed Layer* 616) [Shuffle] + weighted_fusion_4_1/mul_2
[INFO] [GpuLayer] weighted_fusion_3_2/Sum/input_Unsqueeze__2338
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2171
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2167:0 copy
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2169:0 copy
[INFO] [GpuLayer] weighted_fusion_4_1/Sum/input_Unsqueeze__2171:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_4_1/add:0 + (Unnamed Layer* 623) [Shuffle], weighted_fusion_4_1/truediv), PWN(PWN(activation_12/Sigmoid), activation_12/mul))
[INFO] [GpuLayer] after_combine_dw_conv_4_1/separable_conv2d/depthwise__2176
[INFO] [GpuLayer] after_combine_dw_conv_4_1/BiasAdd
[INFO] [GpuLayer] max_pooling2d_7/MaxPool
[INFO] [GpuLayer] Transpose__3607
[INFO] [GpuLayer] max_pooling2d_7/MaxPool__2186
[INFO] [GpuLayer] weighted_fusion_4_2/strided_slice__925:0 + (Unnamed Layer* 635) [Shuffle] + weighted_fusion_4_2/mul
[INFO] [GpuLayer] weighted_fusion_2_2/strided_slice__1001:0 + (Unnamed Layer* 638) [Shuffle] + weighted_fusion_2_2/mul
[INFO] [GpuLayer] weighted_fusion_5_1/strided_slice_2__883:0 + (Unnamed Layer* 641) [Shuffle] + weighted_fusion_5_1/mul_2
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2357
[INFO] [GpuLayer] weighted_fusion_2_2/Sum/input_Unsqueeze__2311
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2192
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2188:0 copy
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2190:0 copy
[INFO] [GpuLayer] weighted_fusion_5_1/Sum/input_Unsqueeze__2192:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_5_1/add:0 + (Unnamed Layer* 649) [Shuffle], weighted_fusion_5_1/truediv), PWN(PWN(activation_13/Sigmoid), activation_13/mul))
[INFO] [GpuLayer] after_combine_dw_conv_5_1/separable_conv2d/depthwise__2197
[INFO] [GpuLayer] after_combine_dw_conv_5_1/BiasAdd
[INFO] [GpuLayer] max_pooling2d_8/MaxPool
[INFO] [GpuLayer] Transpose__3597
[INFO] [GpuLayer] max_pooling2d_8/MaxPool__2207
[INFO] [GpuLayer] weighted_fusion_5_2/strided_slice__877:0 + (Unnamed Layer* 661) [Shuffle] + weighted_fusion_5_2/mul
[INFO] [GpuLayer] weighted_fusion_1_2/strided_slice__1034:0 + (Unnamed Layer* 664) [Shuffle] + weighted_fusion_1_2/mul
[INFO] [GpuLayer] weighted_fusion_6_1/strided_slice_2__835:0 + (Unnamed Layer* 667) [Shuffle] + weighted_fusion_6_1/mul_2
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2378
[INFO] [GpuLayer] weighted_fusion_1_2/Sum/input_Unsqueeze__2284
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2213
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2209:0 copy
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2211:0 copy
[INFO] [GpuLayer] weighted_fusion_6_1/Sum/input_Unsqueeze__2213:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_6_1/add:0 + (Unnamed Layer* 675) [Shuffle], weighted_fusion_6_1/truediv), PWN(PWN(activation_14/Sigmoid), activation_14/mul))
[INFO] [GpuLayer] after_combine_dw_conv_6_1/separable_conv2d/depthwise__2218
[INFO] [GpuLayer] after_combine_dw_conv_6_1/BiasAdd
[INFO] [GpuLayer] max_pooling2d_9/MaxPool
[INFO] [GpuLayer] Transpose__3601
[INFO] [GpuLayer] max_pooling2d_9/MaxPool__2228
[INFO] [GpuLayer] weighted_fusion_6_2/strided_slice__829:0 + (Unnamed Layer* 687) [Shuffle] + weighted_fusion_6_2/mul
[INFO] [GpuLayer] weighted_fusion_0_2/strided_slice__1067:0 + (Unnamed Layer* 690) [Shuffle] + weighted_fusion_0_2/mul
[INFO] [GpuLayer] weighted_fusion_7_1/strided_slice_1__797:0 + (Unnamed Layer* 693) [Shuffle] + weighted_fusion_7_1/mul_1
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2399
[INFO] [GpuLayer] weighted_fusion_0_2/Sum/input_Unsqueeze__2257
[INFO] [GpuLayer] weighted_fusion_7_1/Sum/input_Unsqueeze__2232
[INFO] [GpuLayer] weighted_fusion_7_1/Sum/input_Unsqueeze__2230:0 copy
[INFO] [GpuLayer] weighted_fusion_7_1/Sum/input_Unsqueeze__2232:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_7_1/add:0 + (Unnamed Layer* 701) [Shuffle], weighted_fusion_7_1/truediv), PWN(PWN(activation_15/Sigmoid), activation_15/mul))
[INFO] [GpuLayer] after_combine_dw_conv_7_1/separable_conv2d/depthwise__2237
[INFO] [GpuLayer] after_combine_dw_conv_7_1/BiasAdd
[INFO] [GpuLayer] Transpose__3083
[INFO] [GpuLayer] Resize__2255
[INFO] [GpuLayer] weighted_fusion_7_2/strided_slice__791:0 + (Unnamed Layer* 713) [Shuffle] + weighted_fusion_7_2/mul
[INFO] [GpuLayer] image_resize_layer_8/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_7_2/Sum/input_Unsqueeze__2420
[INFO] [GpuLayer] weighted_fusion_0_2/strided_slice_1__1062:0 + (Unnamed Layer* 718) [Shuffle] + weighted_fusion_0_2/mul_1
[INFO] [GpuLayer] weighted_fusion_0_2/Sum/input_Unsqueeze__2259
[INFO] [GpuLayer] weighted_fusion_0_2/Sum/input_Unsqueeze__2257:0 copy
[INFO] [GpuLayer] weighted_fusion_0_2/Sum/input_Unsqueeze__2259:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_0_2/add:0 + (Unnamed Layer* 724) [Shuffle], weighted_fusion_0_2/truediv), PWN(PWN(activation_16/Sigmoid), activation_16/mul))
[INFO] [GpuLayer] after_combine_dw_conv_0_2/separable_conv2d/depthwise__2264
[INFO] [GpuLayer] after_combine_dw_conv_0_2/BiasAdd
[INFO] [GpuLayer] Transpose__3085
[INFO] [GpuLayer] Resize__2282
[INFO] [GpuLayer] weighted_fusion_6_2/strided_slice_1__824:0 + (Unnamed Layer* 736) [Shuffle] + weighted_fusion_6_2/mul_1
[INFO] [GpuLayer] image_resize_layer_9/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2401
[INFO] [GpuLayer] weighted_fusion_1_2/strided_slice_1__1029:0 + (Unnamed Layer* 741) [Shuffle] + weighted_fusion_1_2/mul_1
[INFO] [GpuLayer] weighted_fusion_1_2/Sum/input_Unsqueeze__2286
[INFO] [GpuLayer] weighted_fusion_1_2/Sum/input_Unsqueeze__2284:0 copy
[INFO] [GpuLayer] weighted_fusion_1_2/Sum/input_Unsqueeze__2286:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_1_2/add:0 + (Unnamed Layer* 747) [Shuffle], weighted_fusion_1_2/truediv), PWN(PWN(activation_17/Sigmoid), activation_17/mul))
[INFO] [GpuLayer] after_combine_dw_conv_1_2/separable_conv2d/depthwise__2291
[INFO] [GpuLayer] after_combine_dw_conv_1_2/BiasAdd
[INFO] [GpuLayer] Transpose__3087
[INFO] [GpuLayer] Resize__2309
[INFO] [GpuLayer] weighted_fusion_5_2/strided_slice_1__872:0 + (Unnamed Layer* 759) [Shuffle] + weighted_fusion_5_2/mul_1
[INFO] [GpuLayer] image_resize_layer_10/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2380
[INFO] [GpuLayer] weighted_fusion_2_2/strided_slice_1__996:0 + (Unnamed Layer* 764) [Shuffle] + weighted_fusion_2_2/mul_1
[INFO] [GpuLayer] weighted_fusion_2_2/Sum/input_Unsqueeze__2313
[INFO] [GpuLayer] weighted_fusion_2_2/Sum/input_Unsqueeze__2311:0 copy
[INFO] [GpuLayer] weighted_fusion_2_2/Sum/input_Unsqueeze__2313:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_2_2/add:0 + (Unnamed Layer* 770) [Shuffle], weighted_fusion_2_2/truediv), PWN(PWN(activation_18/Sigmoid), activation_18/mul))
[INFO] [GpuLayer] after_combine_dw_conv_2_2/separable_conv2d/depthwise__2318
[INFO] [GpuLayer] after_combine_dw_conv_2_2/BiasAdd
[INFO] [GpuLayer] Transpose__3090
[INFO] [GpuLayer] Resize__2336
[INFO] [GpuLayer] weighted_fusion_4_2/strided_slice_1__920:0 + (Unnamed Layer* 782) [Shuffle] + weighted_fusion_4_2/mul_1
[INFO] [GpuLayer] image_resize_layer_11/ResizeNearestNeighbor
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2359
[INFO] [GpuLayer] weighted_fusion_3_2/strided_slice_1__963:0 + (Unnamed Layer* 787) [Shuffle] + weighted_fusion_3_2/mul_1
[INFO] [GpuLayer] weighted_fusion_3_2/Sum/input_Unsqueeze__2340
[INFO] [GpuLayer] weighted_fusion_3_2/Sum/input_Unsqueeze__2338:0 copy
[INFO] [GpuLayer] weighted_fusion_3_2/Sum/input_Unsqueeze__2340:0 copy
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_3_2/add:0 + (Unnamed Layer* 793) [Shuffle], weighted_fusion_3_2/truediv), PWN(PWN(activation_19/Sigmoid), activation_19/mul))
[INFO] [GpuLayer] after_combine_dw_conv_3_2/separable_conv2d/depthwise__2345
[INFO] [GpuLayer] after_combine_dw_conv_3_2/BiasAdd
[INFO] [GpuLayer] max_pooling2d_10/MaxPool
[INFO] [GpuLayer] class-0/separable_conv2d/depthwise
[INFO] [GpuLayer] box-0/separable_conv2d/depthwise
[INFO] [GpuLayer] max_pooling2d_10/MaxPool__2355
[INFO] [GpuLayer] class-0/BiasAdd
[INFO] [GpuLayer] box-0/BiasAdd
[INFO] [GpuLayer] weighted_fusion_4_2/strided_slice_2__915:0 + (Unnamed Layer* 808) [Shuffle] + weighted_fusion_4_2/mul_2
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2361
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2357:0 copy
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2359:0 copy
[INFO] [GpuLayer] weighted_fusion_4_2/Sum/input_Unsqueeze__2361:0 copy
[INFO] [GpuLayer] PWN(PWN(activation_24/Sigmoid), activation_24/mul)
[INFO] [GpuLayer] PWN(PWN(activation_39/Sigmoid), activation_39/mul)
[INFO] [GpuLayer] class-1/separable_conv2d/depthwise
[INFO] [GpuLayer] box-1/separable_conv2d/depthwise
[INFO] [GpuLayer] class-1/BiasAdd
[INFO] [GpuLayer] box-1/BiasAdd
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_4_2/add:0 + (Unnamed Layer* 822) [Shuffle], weighted_fusion_4_2/truediv), PWN(PWN(activation_20/Sigmoid), activation_20/mul))
[INFO] [GpuLayer] after_combine_dw_conv_4_2/separable_conv2d/depthwise__2366
[INFO] [GpuLayer] PWN(PWN(activation_25/Sigmoid), activation_25/mul)
[INFO] [GpuLayer] PWN(PWN(activation_40/Sigmoid), activation_40/mul)
[INFO] [GpuLayer] class-2/separable_conv2d/depthwise
[INFO] [GpuLayer] box-2/separable_conv2d/depthwise
[INFO] [GpuLayer] after_combine_dw_conv_4_2/BiasAdd
[INFO] [GpuLayer] class-2/BiasAdd
[INFO] [GpuLayer] box-2/BiasAdd
[INFO] [GpuLayer] max_pooling2d_11/MaxPool
[INFO] [GpuLayer] class-0_1/separable_conv2d/depthwise
[INFO] [GpuLayer] box-0_1/separable_conv2d/depthwise
[INFO] [GpuLayer] max_pooling2d_11/MaxPool__2376
[INFO] [GpuLayer] class-0_1/BiasAdd
[INFO] [GpuLayer] box-0_1/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_26/Sigmoid), activation_26/mul)
[INFO] [GpuLayer] PWN(PWN(activation_41/Sigmoid), activation_41/mul)
[INFO] [GpuLayer] weighted_fusion_5_2/strided_slice_2__867:0 + (Unnamed Layer* 855) [Shuffle] + weighted_fusion_5_2/mul_2
[INFO] [GpuLayer] class-predict/separable_conv2d/depthwise
[INFO] [GpuLayer] box-predict/separable_conv2d/depthwise
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2382
[INFO] [GpuLayer] class-predict/BiasAdd
[INFO] [GpuLayer] box-predict/BiasAdd
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2378:0 copy
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2380:0 copy
[INFO] [GpuLayer] weighted_fusion_5_2/Sum/input_Unsqueeze__2382:0 copy
[INFO] [GpuLayer] PWN(PWN(activation_27/Sigmoid), activation_27/mul)
[INFO] [GpuLayer] PWN(PWN(activation_42/Sigmoid), activation_42/mul)
[INFO] [GpuLayer] class-1_1/separable_conv2d/depthwise
[INFO] [GpuLayer] box-1_1/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict/BiasAdd__2785 + Reshape
[INFO] [GpuLayer] box-predict/BiasAdd__2829 + Reshape_1
[INFO] [GpuLayer] class-1_1/BiasAdd
[INFO] [GpuLayer] box-1_1/BiasAdd
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_5_2/add:0 + (Unnamed Layer* 877) [Shuffle], weighted_fusion_5_2/truediv), PWN(PWN(activation_21/Sigmoid), activation_21/mul))
[INFO] [GpuLayer] after_combine_dw_conv_5_2/separable_conv2d/depthwise__2387
[INFO] [GpuLayer] PWN(PWN(activation_28/Sigmoid), activation_28/mul)
[INFO] [GpuLayer] PWN(PWN(activation_43/Sigmoid), activation_43/mul)
[INFO] [GpuLayer] class-2_1/separable_conv2d/depthwise
[INFO] [GpuLayer] box-2_1/separable_conv2d/depthwise
[INFO] [GpuLayer] after_combine_dw_conv_5_2/BiasAdd
[INFO] [GpuLayer] class-2_1/BiasAdd
[INFO] [GpuLayer] box-2_1/BiasAdd
[INFO] [GpuLayer] max_pooling2d_12/MaxPool
[INFO] [GpuLayer] class-0_2/separable_conv2d/depthwise
[INFO] [GpuLayer] box-0_2/separable_conv2d/depthwise
[INFO] [GpuLayer] max_pooling2d_12/MaxPool__2397
[INFO] [GpuLayer] class-0_2/BiasAdd
[INFO] [GpuLayer] box-0_2/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_29/Sigmoid), activation_29/mul)
[INFO] [GpuLayer] PWN(PWN(activation_44/Sigmoid), activation_44/mul)
[INFO] [GpuLayer] weighted_fusion_6_2/strided_slice_2__819:0 + (Unnamed Layer* 910) [Shuffle] + weighted_fusion_6_2/mul_2
[INFO] [GpuLayer] class-predict_1/separable_conv2d/depthwise
[INFO] [GpuLayer] box-predict_1/separable_conv2d/depthwise
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2403
[INFO] [GpuLayer] class-predict_1/BiasAdd
[INFO] [GpuLayer] box-predict_1/BiasAdd
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2399:0 copy
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2401:0 copy
[INFO] [GpuLayer] weighted_fusion_6_2/Sum/input_Unsqueeze__2403:0 copy
[INFO] [GpuLayer] PWN(PWN(activation_30/Sigmoid), activation_30/mul)
[INFO] [GpuLayer] PWN(PWN(activation_45/Sigmoid), activation_45/mul)
[INFO] [GpuLayer] class-1_2/separable_conv2d/depthwise
[INFO] [GpuLayer] box-1_2/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict_1/BiasAdd__2707 + Reshape_2
[INFO] [GpuLayer] box-predict_1/BiasAdd__2746 + Reshape_3
[INFO] [GpuLayer] class-1_2/BiasAdd
[INFO] [GpuLayer] box-1_2/BiasAdd
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_6_2/add:0 + (Unnamed Layer* 932) [Shuffle], weighted_fusion_6_2/truediv), PWN(PWN(activation_22/Sigmoid), activation_22/mul))
[INFO] [GpuLayer] after_combine_dw_conv_6_2/separable_conv2d/depthwise__2408
[INFO] [GpuLayer] PWN(PWN(activation_31/Sigmoid), activation_31/mul)
[INFO] [GpuLayer] PWN(PWN(activation_46/Sigmoid), activation_46/mul)
[INFO] [GpuLayer] class-2_2/separable_conv2d/depthwise
[INFO] [GpuLayer] box-2_2/separable_conv2d/depthwise
[INFO] [GpuLayer] after_combine_dw_conv_6_2/BiasAdd
[INFO] [GpuLayer] class-2_2/BiasAdd
[INFO] [GpuLayer] box-2_2/BiasAdd
[INFO] [GpuLayer] max_pooling2d_13/MaxPool
[INFO] [GpuLayer] class-0_3/separable_conv2d/depthwise
[INFO] [GpuLayer] box-0_3/separable_conv2d/depthwise
[INFO] [GpuLayer] max_pooling2d_13/MaxPool__2418
[INFO] [GpuLayer] class-0_3/BiasAdd
[INFO] [GpuLayer] box-0_3/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_32/Sigmoid), activation_32/mul)
[INFO] [GpuLayer] PWN(PWN(activation_47/Sigmoid), activation_47/mul)
[INFO] [GpuLayer] weighted_fusion_7_2/strided_slice_1__786:0 + (Unnamed Layer* 965) [Shuffle] + weighted_fusion_7_2/mul_1
[INFO] [GpuLayer] class-predict_2/separable_conv2d/depthwise
[INFO] [GpuLayer] box-predict_2/separable_conv2d/depthwise
[INFO] [GpuLayer] weighted_fusion_7_2/Sum/input_Unsqueeze__2422
[INFO] [GpuLayer] class-predict_2/BiasAdd
[INFO] [GpuLayer] box-predict_2/BiasAdd
[INFO] [GpuLayer] weighted_fusion_7_2/Sum/input_Unsqueeze__2420:0 copy
[INFO] [GpuLayer] weighted_fusion_7_2/Sum/input_Unsqueeze__2422:0 copy
[INFO] [GpuLayer] PWN(PWN(activation_33/Sigmoid), activation_33/mul)
[INFO] [GpuLayer] PWN(PWN(activation_48/Sigmoid), activation_48/mul)
[INFO] [GpuLayer] class-1_3/separable_conv2d/depthwise
[INFO] [GpuLayer] box-1_3/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict_2/BiasAdd__2629 + Reshape_4
[INFO] [GpuLayer] box-predict_2/BiasAdd__2668 + Reshape_5
[INFO] [GpuLayer] class-1_3/BiasAdd
[INFO] [GpuLayer] box-1_3/BiasAdd
[INFO] [GpuLayer] PWN(PWN(weighted_fusion_7_2/add:0 + (Unnamed Layer* 987) [Shuffle], weighted_fusion_7_2/truediv), PWN(PWN(activation_23/Sigmoid), activation_23/mul))
[INFO] [GpuLayer] after_combine_dw_conv_7_2/separable_conv2d/depthwise__2427
[INFO] [GpuLayer] PWN(PWN(activation_34/Sigmoid), activation_34/mul)
[INFO] [GpuLayer] PWN(PWN(activation_49/Sigmoid), activation_49/mul)
[INFO] [GpuLayer] class-2_3/separable_conv2d/depthwise
[INFO] [GpuLayer] box-2_3/separable_conv2d/depthwise
[INFO] [GpuLayer] after_combine_dw_conv_7_2/BiasAdd
[INFO] [GpuLayer] class-2_3/BiasAdd
[INFO] [GpuLayer] box-2_3/BiasAdd
[INFO] [GpuLayer] class-0_4/separable_conv2d/depthwise
[INFO] [GpuLayer] box-0_4/separable_conv2d/depthwise
[INFO] [GpuLayer] class-0_4/BiasAdd
[INFO] [GpuLayer] box-0_4/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_35/Sigmoid), activation_35/mul)
[INFO] [GpuLayer] PWN(PWN(activation_50/Sigmoid), activation_50/mul)
[INFO] [GpuLayer] class-predict_3/separable_conv2d/depthwise
[INFO] [GpuLayer] box-predict_3/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict_3/BiasAdd
[INFO] [GpuLayer] box-predict_3/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_36/Sigmoid), activation_36/mul)
[INFO] [GpuLayer] PWN(PWN(activation_51/Sigmoid), activation_51/mul)
[INFO] [GpuLayer] class-1_4/separable_conv2d/depthwise
[INFO] [GpuLayer] box-1_4/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict_3/BiasAdd__2551 + Reshape_6
[INFO] [GpuLayer] box-predict_3/BiasAdd__2590 + Reshape_7
[INFO] [GpuLayer] class-1_4/BiasAdd
[INFO] [GpuLayer] box-1_4/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_37/Sigmoid), activation_37/mul)
[INFO] [GpuLayer] PWN(PWN(activation_52/Sigmoid), activation_52/mul)
[INFO] [GpuLayer] class-2_4/separable_conv2d/depthwise
[INFO] [GpuLayer] box-2_4/separable_conv2d/depthwise
[INFO] [GpuLayer] class-2_4/BiasAdd
[INFO] [GpuLayer] box-2_4/BiasAdd
[INFO] [GpuLayer] PWN(PWN(activation_38/Sigmoid), activation_38/mul)
[INFO] [GpuLayer] PWN(PWN(activation_53/Sigmoid), activation_53/mul)
[INFO] [GpuLayer] class-predict_4/separable_conv2d/depthwise
[INFO] [GpuLayer] box-predict_4/separable_conv2d/depthwise
[INFO] [GpuLayer] class-predict_4/BiasAdd
[INFO] [GpuLayer] box-predict_4/BiasAdd
[INFO] [GpuLayer] class-predict_4/BiasAdd__2473 + Reshape_8
[INFO] [GpuLayer] box-predict_4/BiasAdd__2512 + Reshape_9
[INFO] [GpuLayer] Reshape:0 copy
[INFO] [GpuLayer] Reshape_2:0 copy
[INFO] [GpuLayer] Reshape_4:0 copy
[INFO] [GpuLayer] Reshape_6:0 copy
[INFO] [GpuLayer] Reshape_8:0 copy
[INFO] [GpuLayer] Reshape_1:0 copy
[INFO] [GpuLayer] Reshape_3:0 copy
[INFO] [GpuLayer] Reshape_5:0 copy
[INFO] [GpuLayer] Reshape_7:0 copy
[INFO] [GpuLayer] Reshape_9:0 copy
[INFO] [GpuLayer] nms/anchors:0
[INFO] [GpuLayer] nms/non_maximum_suppression
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +226, GPU +194, now: CPU 626, GPU 6035 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +307, GPU +310, now: CPU 933, GPU 6345 (MiB)
[WARNING] Detected invalid timing cache, setup a local cache instead
[ERROR] Tactic Device request: 2193MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2193 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2193 detected for tactic 0.
[WARNING] Internal error: cannot reformat, disabling format. Try decreasing the workspace size with IBuilderConfig::setMaxWorkspaceSize().
[WARNING] Memory requirements of format conversion cannot be satisfied during timing, format rejected.
[ERROR] Tactic Device request: 2128MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2128 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2128 detected for tactic 0.
[ERROR] Tactic Device request: 2580MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2580 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2580 detected for tactic 0.
[ERROR] Tactic Device request: 1548MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1548 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1548 detected for tactic 0.
[ERROR] Tactic Device request: 3096MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 3096 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 3096 detected for tactic 0.
[ERROR] Tactic Device request: 4128MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 4128 detected for tactic 20.
[WARNING] Skipping tactic 1 due to oom error on requested size of 4128 detected for tactic 21.
[WARNING] Skipping tactic 2 due to oom error on requested size of 4128 detected for tactic 22.
[WARNING] Skipping tactic 3 due to oom error on requested size of 4128 detected for tactic 23.
[WARNING] Skipping tactic 4 due to oom error on requested size of 4128 detected for tactic 24.
[WARNING] Skipping tactic 5 due to oom error on requested size of 4128 detected for tactic 25.
[WARNING] Skipping tactic 6 due to oom error on requested size of 4128 detected for tactic 26.
[WARNING] Skipping tactic 7 due to oom error on requested size of 4128 detected for tactic 27.
[WARNING] Skipping tactic 8 due to oom error on requested size of 4128 detected for tactic 30.
[WARNING] Skipping tactic 9 due to oom error on requested size of 4128 detected for tactic 31.
[WARNING] Skipping tactic 0 due to oom error on requested size of 4128 detected for tactic 128.
[WARNING] Skipping tactic 1 due to oom error on requested size of 4128 detected for tactic 256.
[WARNING] Skipping tactic 2 due to oom error on requested size of 4128 detected for tactic 512.
[ERROR] Tactic Device request: 2064MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2064 detected for tactic 10.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2064 detected for tactic 11.
[WARNING] Skipping tactic 2 due to oom error on requested size of 2064 detected for tactic 12.
[WARNING] Skipping tactic 3 due to oom error on requested size of 2064 detected for tactic 13.
[WARNING] Skipping tactic 4 due to oom error on requested size of 2064 detected for tactic 14.
[WARNING] Skipping tactic 5 due to oom error on requested size of 2064 detected for tactic 15.
[WARNING] Skipping tactic 6 due to oom error on requested size of 2064 detected for tactic 16.
[WARNING] Skipping tactic 7 due to oom error on requested size of 2064 detected for tactic 17.
[WARNING] Skipping tactic 8 due to oom error on requested size of 2064 detected for tactic 18.
[WARNING] Skipping tactic 9 due to oom error on requested size of 2064 detected for tactic 19.
[WARNING] Skipping tactic 10 due to oom error on requested size of 2064 detected for tactic 20.
[WARNING] Skipping tactic 11 due to oom error on requested size of 2064 detected for tactic 21.
[WARNING] Skipping tactic 12 due to oom error on requested size of 2064 detected for tactic 22.
[WARNING] Skipping tactic 13 due to oom error on requested size of 2064 detected for tactic 23.
[WARNING] Skipping tactic 14 due to oom error on requested size of 2064 detected for tactic 24.
[WARNING] Skipping tactic 15 due to oom error on requested size of 2064 detected for tactic 25.
[WARNING] Skipping tactic 16 due to oom error on requested size of 2064 detected for tactic 26.
[WARNING] Skipping tactic 17 due to oom error on requested size of 2064 detected for tactic 27.
[WARNING] Skipping tactic 18 due to oom error on requested size of 2064 detected for tactic 29.
[WARNING] Skipping tactic 19 due to oom error on requested size of 2064 detected for tactic 30.
[WARNING] Skipping tactic 20 due to oom error on requested size of 2064 detected for tactic 31.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2064 detected for tactic 128.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2064 detected for tactic 256.
[WARNING] Skipping tactic 2 due to oom error on requested size of 2064 detected for tactic 512.
[WARNING] Skipping tactic 3 due to oom error on requested size of 2064 detected for tactic -32.
[WARNING] Skipping tactic 4 due to oom error on requested size of 2064 detected for tactic -64.
[WARNING] Skipping tactic 5 due to oom error on requested size of 2064 detected for tactic -128.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1548 detected for tactic 20.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1548 detected for tactic 21.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1548 detected for tactic 22.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1548 detected for tactic 23.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1548 detected for tactic 24.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1548 detected for tactic 25.
[WARNING] Skipping tactic 6 due to oom error on requested size of 1548 detected for tactic 26.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1548 detected for tactic 27.
[WARNING] Skipping tactic 8 due to oom error on requested size of 1548 detected for tactic 30.
[WARNING] Skipping tactic 9 due to oom error on requested size of 1548 detected for tactic 31.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1548 detected for tactic 128.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1548 detected for tactic 256.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1548 detected for tactic 512.
[INFO] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[INFO] Detected 1 inputs and 4 output network tensors.
[INFO] Total Host Persistent Memory: 415712
[INFO] Total Device Persistent Memory: 9935360
[INFO] Total Scratch Memory: 15843328
[INFO] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 12 MiB, GPU 1380 MiB
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1467, GPU 7146 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 1467, GPU 7146 (MiB)
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1465, GPU 7146 (MiB)
[INFO] [MemUsageSnapshot] Builder end: CPU 1461 MiB, GPU 7146 MiB
Polygraphy Output:
$ polygraphy inspect model samples/models/test_model/grayscale_efficientdet/model.engine
[I] Loading bytes from /opt/nvidia/deepstream/deepstream-6.0/samples/models/test_model/grayscale_efficientdet/model.engine
[I] ==== TensorRT Engine ====
Name: Unnamed Network 0 | Explicit Batch Engine
---- 1 Engine Input(s) ----
{image_arrays:0 [dtype=float32, shape=(1, 1376, 1024, 3)]}
---- 4 Engine Output(s) ----
{num_detections [dtype=int32, shape=(1, 1)],
detection_boxes [dtype=float32, shape=(1, 100, 4)],
detection_scores [dtype=float32, shape=(1, 100)],
detection_classes [dtype=int32, shape=(1, 100)]}
---- Memory ----
Device Memory: 75507200 bytes
---- 1 Profile(s) (5 Binding(s) Each) ----
- Profile: 0
Binding Index: 0 (Input) [Name: image_arrays:0] | Shapes: min=(1, 1376, 1024, 3), opt=(1, 1376, 1024, 3), max=(1, 1376, 1024, 3)
Binding Index: 1 (Output) [Name: num_detections] | Shape: (1, 1)
Binding Index: 2 (Output) [Name: detection_boxes] | Shape: (1, 100, 4)
Binding Index: 3 (Output) [Name: detection_scores] | Shape: (1, 100)
Binding Index: 4 (Output) [Name: detection_classes] | Shape: (1, 100)
---- 716 Layer(s) ----
