Failed to create .engine File
• Hardware Platform (Jetson / GPU) : Jetson Xavier NX
• DeepStream Version :6 .0
• JetPack Version (valid for Jetson only) : Jetpack 4.6 (32.6.1)
• TensorRT Version : 8.0.6.1
• Issue Type( questions, new requirements, bugs) - Question
Hello Everyone,
I have a deepstream application with 4 input video file sources. In the pgie_config.txt file, I am using an efficientdet0 model. When I set the batch size to 1, the engine file is created successfully. However, when I put the batch size to 4 it fails to create the engine file and gives the following error:
ERROR: [TRT]: 4: [shapeCompiler.cpp::evaluateShapeChecks::822]
Error Code 4: Internal Error (kOPT values for profile 0 violate shape constraints: reshape would change volume. IShuffleLayer block1a_se_squeeze/Mean_Squeeze__3549: reshaping failed for tensor: block1a_se_squeeze/Mean:0)
ERROR: Build engine failed from config file
Segmentation fault
Following is my pgie_config.txt file:
[property]
labelfile-path= ../../models/people_net_model/labels.txt
enable-dla=0
use-dla-core=0
infer-dims=3;544;960
gpu-id=0
gie-unique-id=1
model-color-format=0
network-mode=1      ## 0=FP32, 1=INT8, 2=FP16 mode
maintain-aspect-ratio=1
#batch-size=1
network-input-order=1
net-scale-factor=1.0
offsets=0;0;0
is-classifier=0
cluster-mode=4
int8-calib-file=../../models/people_net_model/efficientdet_d0.cal
tlt-encoded-model = ../../models/people_net_model/det0_int8.etlt
tlt-model-key=nvidia_tlt
uff-input-blob-name=image_arrays:0
output-blob-names=num_detections;detection_boxes;detection_scores;detection_classes
parse-bbox-func-name=NvDsInferParseCustomEfficientDetTAO
custom-lib-path = /home/nvidia/deepstream_tao_apps/post_processor/libnvds_infercustomparser_tao.so
num-detected-classes=1
interval=2
[class-attrs-all]
pre-cluster-threshold=0.15
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Can you tell me how to create the engine file for 4 or more sources?
Looking forward to your replies
The pretrained model’s max batch size is 1. Please re-train the model with bigger batch size. EfficientDet — TAO Toolkit 3.22.05 documentation (nvidia.com)
Hello @Fiona.Chen,
Thank you for your reply. Can you tell me how to specify this max batch size while training?
I was not able to find the option.
I am looking forward to your reply.
@Morganh Can you help @anshul12256 to figure out how to modify the batch size of efficientdet0?
@anshul12256
User can set train_batch_size during training. See EfficientDet — TAO Toolkit 3.22.05 documentation
But it does not make sense when you “put the batch size to 4 it fails to create the engine file and gives the following error” . Please share the full command and full log.
Moving to TAO forum.
Hello @Morganh,
The train_batch_size parameter is used to set the batch size of the training dataset for training the model.
I want to create an engine file from the .etlt model file for 4 input sources.
These are two different things.
In my pgie_config file, I set the path to the etlt model and when I launch my deepstream application I get the following messages on the terminal
nvidia@nvidia-desktop:~/embeddedvision$ ./embedded_vision
PIPELINE 1 = streammux -> pgie -> nvtracker -> tiler -> nvosd
nvosd -> tee
tee -> output_sink_bin
greenMenu
Get Video Handle
Starting...
Using winsys: x11
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
0:00:00.756406906 29730   0x5597d72c90 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 97) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 208) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 211) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 309) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 312) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 316) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 319) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 326) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 333) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 339) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 351) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 356) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 362) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 374) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 379) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 385) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 397) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 402) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 408) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 420) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 423) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 430) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 442) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 445) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 448) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 456) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 468) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 471) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 474) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 482) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 494) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 497) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 500) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 508) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 520) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 525) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 531) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 543) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 548) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 554) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 566) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 571) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 577) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 589) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 594) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 600) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 612) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 615) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 622) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 634) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 637) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 640) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 648) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 660) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 663) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 666) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 674) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 686) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 689) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 692) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 700) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 712) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 717) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 723) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 735) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 740) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 746) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 758) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 763) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 769) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 781) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 786) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 792) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 807) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 821) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 854) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 876) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 909) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 931) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 964) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 986) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
ERROR: [TRT]: 4: [shapeCompiler.cpp::evaluateShapeChecks::822] Error Code 4: Internal Error (kOPT values for profile 0 violate shape constraints: reshape would change volume. IShuffleLayer block1a_se_squeeze/Mean_Squeeze__3549: reshaping failed for tensor: block1a_se_squeeze/Mean:0)
Segmentation fault
What is the “embedded_vision”?
Hello @Morganh,
That is the name of my deepstream application.
Could you please try default official deepstream application?
Hello @Morganh, I tried the default official tao application but even that worked with only a batch size of 1. However, I solved the problem by using the following command in the efficientdet jupyter notebook
!mkdir -p $LOCAL_EXPERIMENT_DIR/export_int8
# Uncomment to remove existing etlt file
# !rm $LOCAL_EXPERIMENT_DIR/experiment_dir_retrain/model.step-0.etlt
!tao efficientdet export -m $USER_EXPERIMENT_DIR/experiment_dir_retrain/model.step-$NUM_STEP.tlt \
                         -o $USER_EXPERIMENT_DIR/experiment_dir_retrain/model_int8.step-$NUM_STEP.etlt \
                         -k $KEY \
                         -e $SPECS_DIR/efficientdet_d1_retrain.txt \
                         --batch_size 4 \
                         --data_type int8 \
                         --cal_image_dir $DATA_DOWNLOAD_DIR/training_v6_coco_crowd/images_testing \
                         --batches 10 \
                         --max_batch_size 4  \
                         --cal_cache_file $USER_EXPERIMENT_DIR/export_int8/efficientdet_d0.cal
Here the max_batch_size parameter enabled to create the .etlt model with a batch size of 4.
However, now I have another question.
When I provided the above .etlt model with a batch size of 4 in the pgie_config.txt file, the resulting engine file created by the system is of 27.2 MB. My .etlt model is 9.3 MB. Since the engine file is huge, I get very poor performance (6-15 FPS) for 4 streams.
To verify this, I also used the tao-converter on the XNX with the following command:
./tao-converter -k nvidia_tlt -d 544,960,3 -c /home/nvidia/embeddedvision/models/people_net_model/efficientdet_d2.cal -m 4 -t int8 /home/nvidia/embeddedvision/models/people_net_model/model_int8.step-562500.etlt
The resulting engine file created is also around the same size of 26.2 MB.
I would like to know why the int8 engine is nearly 3X bigger than the model?
Because when I used detectnetv2 with resnet34 as the backbone architecture the etlt model was 10.4 MB and the resulting int8 engine file was 5.8 MB
Looking forward to your response
Hello @Morganh,
Would like to ask, were you able to get the solution to the above question?
How about the fp16 engine’s size and its fps?
More, usually, the fps is related to trainable parameters.
Hello @Morganh,
For the FP16 the engine size was 19.3 MB with 17-20 FPS for 1 stream. I couldn’t check for 4 streams because I had exported the model with a max batch size of 1.
I find this a bit surprising that an FP16 engine is smaller than an INT8 engine!
Would like to know your opinion !!
I need to reproduce firstly.
Hi @Morganh,
Thanks for your reply. Looking forward to your findings !!
I am using efficientdet-d2 as the model name and b2 as the backbone architecture.
How did you run against 4 streams? Can you share the steps?
Hello @Morganh,
For int8 i had exported the etlt model with a batch size of 4 using the command in the earlier post.
For fp16 there should be a parameter I suppose which would help to export the etlt model with a batch size of 4
For running on 4 Streams, I have a custom deepstream application. Its pipeline is as follows
filesrc(source=0, .mp4) -> qtdemux -> h264parse -> nvv4l2decoder -> videorate -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM), format=(string)RGBA) -> nvstreammux
filesrc(source=1, .mp4) -> qtdemux -> h264parse -> nvv4l2decoder -> videorate -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM), format=(string)RGBA) -> nvstreammux
filesrc(source=2, .mp4) -> qtdemux -> h264parse -> nvv4l2decoder -> videorate -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM), format=(string)RGBA) -> nvstreammux
filesrc(source=3, .mp4) -> qtdemux -> h264parse -> nvv4l2decoder -> videorate -> capsfilter(caps=video/x-raw(memory:NVMM)) -> nvvideoconvert -> capsfilter(caps=video/x-raw(memory:NVMM), format=(string)RGBA) -> nvstreammux
nvstreammux -> nvinfer -> nvmultistreamtiler -> nvdsosd -> nvegltransform -> nveglglessink
I cannot reproduce the result official .etlt file and cal file.
$ ./tao-converter -k nvidia_tlt -d 544,960,3 d0_avlp_544_960.etlt -t fp16 -e fp16.engine
$ ./tao-converter -k nvidia_tlt -d 544,960,3 d0_avlp_544_960.etlt -t int8 -c d0_avlp_544_960.cal -e int8.engine
Or login 22.05 tf15.5 docker,
# converter -k nvidia_tlt -d 544,960,3 d0_avlp_544_960.etlt -t int8 -c d0_avlp_544_960.cal -e int8.engine
# converter -k nvidia_tlt -d 544,960,3 d0_avlp_544_960.etlt -t fp16 -e fp16.engine
Actually you can focus on the pruning ratio. For better fps, please prune to a smaller one and retrain it.
Hello @Morganh,
what are the sizes of the engine file that you created from the official etlt model ?
