deepstream-plugins for real time video on Xavier
Hi
I have install Jetpack4.1.1, DeepStream3.0 and deepstream-plugins successfully on Xavier,
(deepstream-plugins: https://github.com/vat-nvidia/deepstream-plugins)
run deepstream-app -c /home/nvidia/deepstream_sdk_on_jetson/samples/configs/deepstream-app/source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt OK,
run deepstream-yolo-app Tegra /home/nvidia/deepstream_sdk_on_jetson/samples/streams/sample_720p.h264 config/yolov3.txt OK,
but, run deepstream-yolo-app Tegra /dev/video0 config/yolov3.txt fail,
Could I run deepstream-yolo-app with real time video?
Since it is open source code. Please try to add v4l2src as the source in the code.
I’m able to run the yolo app. How to show the video output ? Is it in the ds-yolo-pipeline pipeline? What change would that be ?
deepstream-yolo-app Tegra ~/Tools/deepstream_sdk_on_jetson/samples/streams/sample_720p.h264 config/yolov3.txt
Thank you.
The code is here.
It seems that nvosd should have the On Screen Display with the bboxes, but it’s not showing when running on the Xavier.
gst_element_link_many (source, h264parser, decoder, filter1, nvvidconv,
filter2, yolo, nvosd, sink, NULL);
As anyone used the deepstream-yolo-app and added On Screen Display with the bboxes ?
MIT License
Copyright (c) 2018 NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#include <glib.h>
#include <gst/gst.h>
#include "gstnvdsmeta.h"
/* As defined in the yolo plugins header*/
#define YOLO_UNIQUE_ID 15
gint frame_number = 0;
/* osd_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and get a count of objects of interest */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstMeta *gst_meta = NULL;
  NvDsMeta *nvdsmeta = NULL;
  gpointer state = NULL;
  static GQuark _nvdsmeta_quark = 0;
  GstBuffer *buf = (GstBuffer *) info->data;
  NvDsFrameMeta *frame_meta = NULL;
  guint num_rects = 0, rect_index = 0;
  NvDsObjectParams *obj_meta = NULL;
  guint car_count = 0;
  guint person_count = 0;
  guint bicycle_count = 0;
  guint truck_count = 0;
  if (!_nvdsmeta_quark)
    _nvdsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
  while ((gst_meta = gst_buffer_iterate_meta (buf, &state))) {
    if (gst_meta_api_type_has_tag (gst_meta->info->api, _nvdsmeta_quark)) {
      nvdsmeta = (NvDsMeta *) gst_meta;
      /* We are interested only in intercepting Meta of type
       * "NVDS_META_FRAME_INFO" as they are from our infer elements. */
      if (nvdsmeta->meta_type == NVDS_META_FRAME_INFO) {
        frame_meta = (NvDsFrameMeta *) nvdsmeta->meta_data;
        if (frame_meta == NULL) {
          g_print ("NvDS Meta contained NULL meta \n");
          return GST_PAD_PROBE_OK;
        num_rects = frame_meta->num_rects;
        /* This means we have num_rects in frame_meta->obj_params.
         * Now lets iterate through them and count the number of cars,
         * trucks, persons and bicycles in each frame */
        for (rect_index = 0; rect_index < num_rects; rect_index++) {
          obj_meta = (NvDsObjectParams *) & frame_meta->obj_params[rect_index];
          if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
                  "car"))
            car_count++;
          else if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
                  "person"))
            person_count++;
                  "bicycle"))
            bicycle_count++;
                  "truck"))
            truck_count++;
  g_print ("Frame Number = %d Number of objects = %d "
      "Car Count = %d Person Count = %d "
      "Bicycle Count = %d Truck Count = %d \n",
      frame_number, num_rects, car_count, person_count, bicycle_count,
      truck_count);
  frame_number++;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n", GST_OBJECT_NAME (msg->src),
          error->message);
      g_free (debug);
      g_printerr ("Error: %s\n", error->message);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL, *decoder =
      NULL, *sink = NULL, *nvvidconv = NULL, *nvosd = NULL, *filter1 =
      NULL, *filter2 = NULL, *yolo = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstCaps *caps1 = NULL, *caps2 = NULL;
  gulong osd_probe_id = 0;
  GstPad *osd_sink_pad = NULL;
  /* Check input arguments */
  if (argc != 4) {
    g_printerr
        ("Usage: %s <Platform-Telsa/Tegra> <H264 filename> <yolo-plugin config file> \n",
        argv[0]);
    return -1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("ds-yolo-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("filesrc", "file-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264/omxh264dec for hardware accelerated decode on GPU */
  if (!g_strcmp0 ("Tesla", argv[1])) {
    decoder = gst_element_factory_make ("nvdec_h264", "nvh264-decoder");
  } else if (!g_strcmp0 ("Tegra", argv[1])) {
    decoder = gst_element_factory_make ("omxh264dec", "openmax-decoder");
  } else {
    g_printerr ("Incorrect platform. Choose between Telsa/Tegra. Exiting.\n");
    return -1;
  /* Use convertor to convert from NV12 to RGBA as required by nvosd and yolo plugins */
  nvvidconv = gst_element_factory_make ("nvvidconv", "nvvideo-converter");
  /* Use yolo to run inference instead of pgie */
  yolo = gst_element_factory_make ("nvyolo", "yolo-inference-engine");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvosd", "nv-onscreendisplay");
  /* Finally render the osd output */
    sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
    sink = gst_element_factory_make ("nvoverlaysink", "nvvideo-renderer");
  } else {
    return -1;
  /* caps filter for nvvidconv to convert NV12 to RGBA as nvosd expects input
   * in RGBA format */
  filter1 = gst_element_factory_make ("capsfilter", "filter1");
  filter2 = gst_element_factory_make ("capsfilter", "filter2");
  if (!pipeline || !source || !h264parser || !decoder || !filter1 || !nvvidconv
      || !filter2 || !nvosd || !sink || !yolo) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* we set the input filename to the source element */
  g_object_set (G_OBJECT (source), "location", argv[2], NULL);
  g_object_set (G_OBJECT (yolo), "config-file-path", argv[3], NULL);
  /* we set the osd properties here */
  g_object_set (G_OBJECT (nvosd), "font-size", 15, NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline), source, h264parser, decoder, filter1,
      nvvidconv, filter2, yolo, nvosd, sink, NULL);
  caps1 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12");
  g_object_set (G_OBJECT (filter1), "caps", caps1, NULL);
  gst_caps_unref (caps1);
  caps2 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=RGBA");
  g_object_set (G_OBJECT (filter2), "caps", caps2, NULL);
  gst_caps_unref (caps2);
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder ->
   * filter1 -> nvvidconv -> filter2 -> yolo -> nvosd -> video-renderer */
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    osd_probe_id = gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing: %s\n", argv[2]);
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
@DaneLLL,
Wehn I execute deepstream-app -c config.txt, while its content has flowing paragraph:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
num-sources=1
gpu-id=0
the stream came from usb camera can be display on console of Xavier.(my env. Jetpack4.1.1, DeepStream3.0 and deepstream-plugins).
If I want to execute deepstream-yolo-app Tegra yolov3.txt,need I download v4l2src?
no matter what v4l2src is required to add deepstream-plugins or not,
how to build, add parameters and config to make usb camera stream to feed deepstream-yolo-app and display on console?
deepstream-yolo-app runs the pipeline:
filesrc ! h264parse ! omxh264dec ! nvvidconv ! nvyolo ! nvosd ! nvoverlaysink
For v4l2 source(such as USB cameras), you should run:
v4l2src ! nvvidconv ! nvyolo ! nvosd ! nvoverlaysink
Please refer to source code of deepstream-app and integrate v4l2src into deepstream-yolo-app for your usecase.
Hi desireb,
For clearness, we suggest you start a new post for your issue. This post is more about integrating v4l2src into yolo app.
Also your case is demonstrated in dsexample in deepstream-app. Please refer to it.
@DaneLLL
If I want to execute deepstream-yolo-app to read mp4 file, what names of parser and decoder should I used?
(Will the h264parse and omxh264dec be replaced?)
Please modify the code to run
filesrc ! qtdemux ! h264parse ! omxh264dec ! nvvidconv ! nvyolo ! nvosd ! nvoverlaysink
A reference code of linking qtdemux:
https://stackoverflow.com/questions/17960652/gstreamerdynamically-link-realize
OK, thanks again!!
