Hi, I tried to write the bbox box to file while processing your sample video in samples/streams/sample_72p.h264, by running
./deepstream-yolo-app /home/xxx/samples/streams/sample_720p.h264 /home/xxx/config/yolov2.txt
But no files were written to the foler “testRlt”.
Is there anyway to check whether my yolo2 is running correctly, or debug where the error occurs.
I modified the function as follows
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
gchar *output_path=“/home/xxx/testRlt”;
gchar bbox_file[1024] = { 0 };
FILE *bbox_params_dump_file = NULL;
NvOSD_RectParams *rect_params = NULL;
GstMeta *gst_meta = NULL;
NvDsMeta *nvdsmeta = NULL;
gpointer state = NULL;
static GQuark _nvdsmeta_quark = 0;
GstBuffer *buf = (GstBuffer *) info->data;
NvDsFrameMeta *frame_meta = NULL;
guint num_rects = 0, rect_index = 0;
NvDsObjectParams *obj_meta = NULL;
guint car_count = 0;
guint person_count = 0;
guint bicycle_count = 0;
guint truck_count = 0;
if (!_nvdsmeta_quark)
_nvdsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
while ((gst_meta = gst_buffer_iterate_meta (buf, &state))) {
if (gst_meta_api_type_has_tag (gst_meta->info->api, _nvdsmeta_quark)) {
nvdsmeta = (NvDsMeta *) gst_meta;
/* We are interested only in intercepting Meta of type
* "NVDS_META_FRAME_INFO" as they are from our infer elements. */
if (nvdsmeta->meta_type == NVDS_META_FRAME_INFO) {
frame_meta = (NvDsFrameMeta *) nvdsmeta->meta_data;
if (frame_meta == NULL) {
g_print ("NvDS Meta contained NULL meta \n");
return GST_PAD_PROBE_OK;
else {
g_snprintf (bbox_file, sizeof (bbox_file) - 1, "%s/%06d.txt",
output_path, frame_number);
bbox_params_dump_file = fopen (bbox_file, "w");
num_rects = frame_meta->num_rects;
/* This means we have num_rects in frame_meta->obj_params.
* Now lets iterate through them and count the number of cars,
* trucks, persons and bicycles in each frame */
for (rect_index = 0; rect_index < num_rects; rect_index++) {
obj_meta = (NvDsObjectParams *) & frame_meta->obj_params[rect_index];
if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
"car"))
car_count++;
else if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
"person"))
person_count++;
"bicycle"))
bicycle_count++;
"truck"))
truck_count++;
/* Ouput bbox location as kitti file */
rect_params = &(obj_meta->rect_params);
if (bbox_params_dump_file) {
int left = (int) (rect_params->left);
int top = (int) (rect_params->top);
int right = left + (int) (rect_params->width);
int bottom = top + (int) (rect_params->height);
int class_index = obj_meta->class_id;
char *text = obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label;
fprintf (bbox_params_dump_file,
"%s 0.0 0 0.0 %d.00 %d.00 %d.00 %d.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0\n",
text, left, top, right, bottom);
fclose (bbox_params_dump_file);
g_print ("Frame Number = %d Number of objects = %d "
"Car Count = %d Person Count = %d "
“Bicycle Count = %d Truck Count = %d \n”,
frame_number, num_rects, car_count, person_count, bicycle_count,
truck_count);
frame_number++;
