Deepstream python api Multiplex detection
**• Hardware Platform (Jetson / GPU):dGPU**
**• DeepStream Version:5.1**
**• JetPack Version (valid for Jetson only)**
**• TensorRT Version:7.2.3**
**• NVIDIA GPU Driver Version (valid for GPU only):11.1**
**• Issue Type( questions, new requirements, bugs):questions**
**• deepstream python api Multiplex detection,sample deepstream-test3 run out no vidio of lables?
excuse me ,How can I add a label to a box?
Are you sure that the label.txt file is in the correct position shown below?
Thank you of reminding me
Hello friend, sample deepstream-test2 how to print the vehicle type and tracker ID on the console?
Output the value of each target
You can print object_id and object_label
