Deepstream for multi-rtsp stream (Solved)
when i use deepstream in jetson Tx2.
i set the multi-rtsp stream in conifguare
[application]
enable-perf-measurement=1
roi-marking=0
perf-measurement-interval-sec=5
gie-kitti-output-dir=/home/nvidia/kitti1
0 = standalone; 1 = server; 2 = client
app-mode=3
[source0]
#enable=1
Type - 1=CameraCSi 2=CameraV4L2 3=URI
#type=3
camera-width=1920
camera-height=1080
camera-fps-n=25
camera-fps-d=1
camera-csi-sensor-id=0
camera-v4l2-dev-node=0
uri=rtsp://admin:hik12345@192.168.0.102:554/
[source1]
enable=1
#Type - 1=CameraCSi 2=CameraV4L2 3=URI
type=3
camera-width=1920
camera-height=1080
camera-fps-n=25
camera-fps-d=1
uri=rtsp://admin:hik12345@192.168.0.100:554/
[sink0]
enable=1
#Type - 1=FakeSink 2=OverlaySink 3=EglSink 4=XvImageSink 5=File
type=2
display-id=0
offset-x=0
offset-y=0
width=0
height=0
sync=0
overlay-index=1
source-id=0
[sink1]
enable=0
type=5
#1=mp4 2=mkv
container=2
#1=h264 2=h265
codec=1
bitrate=10000000
#1=cbr 2=vbr
rc-mode=2
iframeinterval=30
#1=baseline 2=main 3=high
profile=3
output-file=out.mp4
source-id=0
[osd]
enable=1
osd-mode=2
border-width=3
text-size=10
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0;
#[face-detector]
#enable=1
#mode=0
#unique-id=15
#interval=2
#multi-stream=1
[primary-gie]
enable=1
net-scale-factor=0.0039215697906911373
model-file=file:///home/nvidia/Model/ResNet_18/ResNet_18_threeClass_VGA_pruned.caffemodel
proto-file=file:///home/nvidia/Model/ResNet_18/ResNet_18_threeClass_VGA_deploy_pruned.prototxt
model-cache=file:///home/nvidia/Model/ResNet_18/ResNet_18_threeClass_VGA_pruned.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/ResNet_18/labels.txt
net-stride=16
batch-size=2
#bbox-bg-color0=0;1;0;0.2
#bbox-bg-color1=0;1;1;0.2
#bbox-bg-color2=0;1;1;0.2
#bbox-bg-color3=1;0;0;0.2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
num-classes=3
class-thresholds=0.2;0.2;0.2;0.2
class-eps=0.1;0.1;0.1;0.1
class-group-thresholds=3;3;3;3
color-format=0
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1920;100;1920;1920
detected-max-h=1080;1080;1080;1080
interval=1
-2 for all; -1 for none;
To set multiple class id’s use format as “1;2;0”
detect-color-class-ids=0;
gie-unique-id=1
parse-func=4
is-classifier=0
output-bbox-name=Layer11_bbox
output-blob-names=Layer11_cov
Uncomment below lines for DBSCAN. EPS and minBoxes can be tuned for DBSCAN
#enable-dbscan=1
#class-minBoxes=4;4;4;4
#class-eps=0.7;0.7;0.7;0.7
Bit 0: Model decryption required
crypto-flags=0
[secondary-gie4]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/snapshot_iter_13740.caffemodel
proto-file=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/deploy.prototxt
model-cache=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/snapshot_iter_13740.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/labels.txt
net-stride=16
batch-size=2
num-classes=6
detected-min-w=128
detected-min-h=128
color-format=1
interval=0
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=2;
is-classifier=1
output-blob-names=softmax
offsets=73.00;77.55;88.9
sgie-async-mode=1
sec-class-threshold=0.51
[secondary-gie5]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/CarColorPruned.caffemodel
proto-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/deploy.prototxt
mean-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/mean.ppm
model-cache=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/CarColorPruned.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/labels.txt
net-stride=16
batch-size=2
detected-min-w=128
detected-min-h=128
color-format=1
num-classes=12
interval=0
gie-unique-id=5
operate-on-gie-id=1
is-classifier=1
sgie-async-mode=1
[secondary-gie6]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel
proto-file=file:///home/nvidia/Model/IVASecondary_Make_V1/deploy.prototxt
model-cache=file:///home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel_b2_fp16.cache
mean-file=file:///home/nvidia/Model/IVASecondary_Make_V1/mean.ppm
labelfile-path=file:///home/nvidia/Model/IVASecondary_Make_V1/labels.txt
net-stride=16
batch-size=2
num-classes=24
detected-min-w=128
detected-min-h=128
color-format=1
interval=0
gie-unique-id=6
operate-on-gie-id=1
is-classifier=1
sgie-async-mode=1
crypto-flags=0
[tracker]
enable=1
tracker-width=960
tracker-height=540
[tests]
file-loop-count=0
#0=send overlaps; 1=do not send overlaps
server-overlap-mode=1
#Fixed to 1 for diplay color in GUI mode
color-mode=1
**PERF: FPS (Avg) FPS 0 (Avg) FPS 1 (Avg)
**PERF: nan (nan) nan (nan) nan (nan)
May I know what issue you are facing?
wayne zhu
Hello waynezhu,
I want to support multi-rtsp stream using deepstream. Can you give me a configure to me to test it ?
Hello bingxinhu,
I am sorry to tell you that our tegra version can’t support multimedia stream because some component can’t support batch operation.
It will be supported in next release.
wayne zhu
Is it supported in ds5.0 ? How to create pipline
