I installed the latest SDK on Jetpack 4.4 and tried running the python application deepstream_imagedata_multistream.py and got the following error: libnvds_meta.so: cannot open shared object file: No such file or directory. The same error shows when I try running other python apps, something that was not an issue in the previous Deepstream/Jetpack version. I ran setup.py in the libraries folder and the error persists. Is there anything I could try?
You may refer this:
I tried changing the import pyds line in the script to bindings.jetson import pyds, and I am getting pretty much the same error, i.e. 'ModuleNotFoundError: No module named ‘bindings’. I am running the examples from the deepstream installation path just like the comment in the forum you referred.
please provide your setup info
Hi salmannadeem1997,
i am facing same issue, this is happening inside container Deepstream:5.1-21.02-devel
File “multi_stream_people_tracker.py”, line 40, in
import pyds
ModuleNotFoundError: No module named ‘pyds’
Hi thaha1,
Please help to open a new topic for your issue. Thanks
