I deploy my TAO Faster RCNN model trained on 80 class COCO dataset using Deepstream with tracker. I want the tracker to only track person class. Therefore, I set the pre-cluster-threshold=1.0
for all the classes in the Deepstream_config file frccn_res50_test_pgie_config.txt
except the person class which is class_number 49 as per labels2.txt
(see attached files).
However, this works for all the classes except class-0. If I set the pre_cluster_threshold=1.0
for class-0 (aeroplanes), deepstream does not generate any bbox. If I comment this line out, it works fine but it also detects + tracks aeroplanes which I do not want. From my understanding, the threshold value for class-49 (person class) and class-0 (aeroplane) seem to somehow getting linked.
- Hardware (Quadro RTX 6000)
- Network Type (Faster_rcnn)
- TAO Version (docker_tag = v3.21.08-py3 )
- Deepstream (docker_image = nvcr.io/nvidia/deepstream:5.1-21.02-devel)
frcnn_res50_test_pgie_config.txt (7.3 KB)
labels2.txt (617 Bytes)
