• Hardware Platform (Jetson / GPU) • DeepStream Version 4.0.0 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Could i specify some class-id which i don’t want need to tracke.
i have detected 10 classes in nvinfer and now i just want to track one class in NvDCF, how can i do ?
If you want to filter out some of the object classes, then you can use the per-class configuration in PGIE config file like below, and set threshold to be an infeasibly high number like 100. If so, no object in that class would be qualified, so effectively they will be filtered out. Would that resolve your issue?
## Per class configuration
#[class-attrs-2]
#threshold=0.6
#eps=0.5
#group-threshold=3
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
