Zygislu
September 30, 2023, 8:59am
1
GPU
• DeepStream Version
6.2
535
Bugs
• How to reproduce the issue?
I have setup DeepStream 6.2 and installed python bindings for it. I’m using USE_NEW_NVSTREAMMUX=yes and have modified deepstream-imagedata-multistream python script to use New Streammux as such:
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
if is_live:
print("Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property('width', STREAMMUX_WIDTH)
streammux.set_property('height', STREAMMUX_HEIGHT)
streammux.set_property('batched-push-timeout', 40000)
streammux.set_property('batch-size', number_sources)
pgie.set_property('config-file-path', "inference_config.txt")
and modified this code part aswell:
if not is_aarch64():
# Use CUDA unified memory in the pipeline so frames
# can be easily accessed on CPU in Python.
mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
streammux.set_property("nvbuf-memory-type", mem_type)
nvvidconv.set_property("nvbuf-memory-type", mem_type)
nvvidconv1.set_property("nvbuf-memory-type", mem_type)
tiler.set_property("nvbuf-memory-type", mem_type)
So now when i don’t use New Streammux everything works as intended, however if I set USE_NEW_NVSTREAMMUX to yes then the pipeline doesn’t work and sources don’t get processed. I suspect it’s because of not using nvbuf-memory-type with New Streammux, or maybe it’s something else?
Zygislu:
nvbuf-memory-type
Should be other reason as nvbuf-memory-type doesn’t exist in the new streammux. (refer the comparation here: Gst-nvstreammux New — DeepStream 6.3 Release documentation (nvidia.com) )
You can set GST_DEBUG=3 to get more information before the issue happens.
I have set GST_DEBUG=3 and this is what i get when i run the pipeline:
deepstream-python | 0:00:06.235296306 1 0x7fd5a00674c0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
deepstream-python | 0:00:06.250728709 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250763256 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
deepstream-python | 0:00:06.250771312 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250778342 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
deepstream-python | 0:00:06.250815328 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250822672 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat AV10
deepstream-python | 0:00:06.250828807 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250836709 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat AV10
deepstream-python | 0:00:06.250852199 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250885063 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX5
deepstream-python | 0:00:06.250891687 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250898792 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX5
deepstream-python | 0:00:06.250918528 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250935246 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX4
deepstream-python | 0:00:06.250961846 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.250979191 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX4
deepstream-python | 0:00:06.251011225 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251043500 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
deepstream-python | 0:00:06.251050352 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251057649 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
deepstream-python | 0:00:06.251070342 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251078831 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
deepstream-python | 0:00:06.251085505 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251092834 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
deepstream-python | 0:00:06.251106423 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251114912 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
deepstream-python | 0:00:06.251121884 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251129550 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
deepstream-python | 0:00:06.251141244 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251148874 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
deepstream-python | 0:00:06.251155639 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251165011 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
deepstream-python | 0:00:06.251194881 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251213401 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
deepstream-python | 0:00:06.251221056 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251228902 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
deepstream-python | 0:00:06.251242939 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251261926 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
deepstream-python | 0:00:06.251289747 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.251324932 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
deepstream-python | 0:00:06.252196724 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.252228989 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
deepstream-python | 0:00:06.252262626 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
deepstream-python | 0:00:06.252277025 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
deepstream-python | 0:00:06.252316156 1 0x7fd5a0067de0 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7fd598019ff0 Failed to determine interlace mode
deepstream-python | 0:00:06.256055046 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.368502102 1 0x7fd5a0067de0 WARN nvstreammux gstnvstreammux.cpp:1051:configure_module:<Stream-muxer> No config-file provided; falling back to default streammux config 1
deepstream-python |
deepstream-python | 0:00:06.372027769 1 0x7fd5a0067de0 WARN v4l2videodec gstv4l2videodec.c:1836:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
deepstream-python | 0:00:06.372114377 1 0x7fd5a0067de0 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
deepstream-python | 0:00:06.372505305 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.373082126 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.373202620 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.373293192 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.488436676 1 0x7fd598027c00 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
deepstream-python | 0:00:06.488553900 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.489604991 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.490558220 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.490755246 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.491985916 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.492204384 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.492520567 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
deepstream-python | 0:00:06.492856508 1 0x7fd5a0067de0 FIXME h265parse gsth265parse.c:1850:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
fanzh
October 8, 2023, 6:33am
5
sorry for the late reply.
what do you mean about “sources don’t get processed”?
what is your start commandline?
fanzh
October 8, 2023, 7:20am
6
using the same code, I can’t reproduce the issue on T4+DS6.2. here are the code and log.
deepstream_imagedata-multistream.py (17.5 KB)
log.txt (6.5 KB)
Thanks for the reply, your code works, thanks for it as well.
In the main question I forgot to mention that I’m using additionally these lines to crop ROI from input source:
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
nvvidconv_crop = Gst.ElementFactory.make("nvvideoconvert", f'nvvideoconvert{i}')
nvvidconv_crop.set_property('src-crop', '14:26:819:288')
pipeline.add(source_bin)
pipeline.add(nvvidconv_crop)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
nvvidconv_srcpad = nvvidconv_crop.get_static_pad("src")
nvvidconv_sinkpad = nvvidconv_crop.get_static_pad("sink")
srcpad.link(nvvidconv_sinkpad)
nvvidconv_srcpad.link(sinkpad)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
When I comment them out, everything works, however when I enable them, the pipeline doesn’t work.
Maybe you have an example or suggestion how I could fix this, so that ROI cropping would work with new streammux, because with old it works.
fanzh
October 10, 2023, 9:13am
8
you can work around by adding a NV12 capsfilter after nvvideoconvert. please refer to this code
1.diff (7.1 KB)
Thank you for all the help and the code above, the pipeline runs now. However when i save frames in tiler_sink_pad_buffer_probe function, more specifically when I save n_frame it saves it at the same resolution as my video, e.g. 1920x1080, but not cropped, e.g. 416x256.
What other changes should I make so that I could save n_frame as cropped?
fanzh
October 15, 2023, 2:47pm
10
please refer to this sample test, the resolution of 7.jpeg is still 720p.
gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg ! jpegdec ! ‘video/x-raw,format=I420’ ! nvvideoconvert src-crop=“0:0:300:300” ! jpegenc ! filesink location=7.jpeg
Zygislu
October 17, 2023, 4:37am
11
Yeah you are right. Is there anything I can add to maybe the end of the pipeline so that the output image would be the same resolution as the crop?
Or should I use something else instead of nvvideoconvert src-crop?
fanzh
October 17, 2023, 6:32am
12
please refer to this command, the output resolution is the same with crop’s.
gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg ! jpegdec ! ‘video/x-raw,format=I420’ ! nvvideoconvert ! ‘video/x-raw,format=I420,width=300,height=300’ ! jpegenc ! filesink location=7.jpeg
