Deepstream python test1-rtsp-out with uridecodebin
I have modifed above example with the uridecodebin as the source in order to play .mp4s or other rtsp src, it won’t work straightway. I understand that I should only demux the h264 stream after the uridecodebin then it might be working, but I dont know how to do it. Can you please help?
Regards,
Kai
• DeepStream Version
• TensorRT Version
Are you familiar with gstreamer programming? GStreamer: open source multimedia framework
Yes. I am able to play a bit but not expert.
My pipeline is like
        source_bin = create_source_bin(i, uri_name)
        assert source_bin is not None
        pipeline.add(source_bin)
        sink_pad = streammux.get_request_pad("sink_%u" % i)
        assert sink_pad is not None
        src_pad = source_bin.get_static_pad("src")
        assert src_pad is not None
        src_pad.link(sink_pad)
   streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(sgie_color)
    sgie_color.link(sgie_type)
    sgie_type.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(tee)
    tee_msg_pad = tee.get_request_pad('src_%u')
    assert tee_msg_pad is not None
    sink_pad_q1 = queue1.get_static_pad("sink")
    tee_msg_pad.link(sink_pad_q1)
    tee_render_pad = tee.get_request_pad("src_%u")
    assert tee_render_pad is not None
    sink_pad_q2 = queue2.get_static_pad("sink")
    tee_render_pad.link(sink_pad_q2)
    queue1.link(msgconv)
    msgconv.link(msgbroker)
    queue2.link(nvvidconv_postosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(udpsink)
The problem is that I want to use uridecodebin as the source, but it always seems hangs up at the Frame Number = 3
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f83a9b0a8 (GstCapsFeatures at 0x7ec403b220)>
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Frame Number = 0 Vehicle Count = 0 Person Count = 0
Frame Number = 1 Vehicle Count = 0 Person Count = 0
Frame Number = 2 Vehicle Count = 0 Person Count = 0
Frame Number = 3 Vehicle Count = 1 Person Count = 3
H264: Profile = 66, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
Gstreamer is totally open source. For uridecodebin usage, you can find many resources in internet. Such as An Example for GStreamer Dynamic Pad (Decodebin) · GitHub
In deepstream, you can refer to deepstream-test3 sample code. C/C++ Sample Apps Source Details — DeepStream 6.1.1 Release documentation
From the log, it seems the uridecodebin has successfully created following elements which are almost identical to the test1-rtsp-out example, which is filesrc->h264parse->capsfilter->nvv4l2decoder. The example works for the .h264file, but when I change the source to uridecodebin , it jus hangs at frame3.
I will try to play more to see what is the problem
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
Can you upload your code? The behaviour depends on the details of the whole pipeline but not just piece of code.
ds-traffic-perception.py (29.3 KB)
Please help looking into it, thanks!
I managed to pin point the problem:
At the end of the pipeline, I have added a overlay sink
sink = Gst.ElementFactory.make("nvoverlaysink", "nvvideo-renderer")
    sink.set_property('sync', 0)
howevver, it is never linked in the pipeline, instead, a updsink is linked at the end of the pileline. Once I removed the overlaysink from the pipeline, it started to work.
I don’t know why but this seems to be the fix…
You never link the sink element to the pipeline. There is already a udpsink in your pipeline. You must make sure your pipeline before you coding.
What pipeline on earth do you want?
Please refer to deepstream-test3 sample for how to link sink to the pipeline. deepstream_python_apps/deepstream_test_3.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
