Uridecodebin for single source
• DeepStream Version Deepstream 6.2
• TensorRT Version
I went through test examples in deepstream_python_app, in every examples of uridecodebin, it consider multiple input and are coded in this way
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=", gstname)
    if gstname.find("video") != -1:
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=", features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write(
                    "Failed to link decoder src pad to source bin ghost pad\n"
        else:
            sys.stderr.write(
                " Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
def create_source_bin(index, uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri", uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(
        Gst.GhostPad.new_no_target(
            "src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = args[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
Is it necessary to code like this even if we have only one source? When I replaced the filesrc , decoder, h264parser with uridecodebin in the test example 1, I got an error that srcpad doesn’t have an attribute link
       source = Gst.ElementFactory.make("uridecodebin", "uridecodebin")
       streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
        source.set_property("uri", input_path)
        if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes':  # Only set these properties if not using new gst-nvstreammux
            streammux.set_property('width', 1920)
            streammux.set_property('height', 1080)
            streammux.set_property('batched-push-timeout', 4000000)
        streammux.set_property('batch-size', 1)
        pipeline.add(self.source)
        pipeline.add(.streammux)
        pipeline.add(.pgie)
        sinkpad = self.streammux.get_request_pad("sink_0")
        srcpad = source.get_static_pad("src")
        srcpad.link(sinkpad)
AttributeError: ‘NoneType’ object has no attribute ‘link’
Can you confirm if you have successfully got the pad?
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
i got sinkpad but not the srcpad
You can try to use create_source_bin to create source bin.
