Reference link
I’ve implemented a REST API service in DeepStream that dynamically adds and updates cameras and Regions of Interest (ROIs) via API calls. Currently, my ROI update endpoint only modifies the ROI rectangles in the backend, but it does not draw the ROI lines on the OSD (On-Screen Display), nor does it count objects crossing these lines. Right now, the ROIs are just lines with no directional arrows and no analytics.
The ROI configurations are similar to the format used in the nvdsanalytics config file, for example:
[line-crossing-stream-0] enable=1 #Label;direction;lc line-crossing-Exit=1248;588;1233;515;780;487;1516;548 line-crossing-Entry=1230;363;1252;414;782;485;1516;548 #line_color=0.75;0.25;0;1 class-id=0 extended=0 mode=balanced
I want to achieve the following:
- Draw the ROI lines, including directional arrows, on the video stream/OSD following the above config.
Count objects (people) crossing these lines using the logic defined in the deepstream_nvdsanalytics_meta.app or equivalent analytics module.
gst_nvmultiurisrcbin_mode (void)
static GType qtype = 0;
if (qtype == 0) {
static const GEnumValue values[] = {
{0, "Mode Video-Only",
"Video streams are muxed together; audio streams are ignored; Default"},
{1, "Mode Audio-Only",
"Audio streams are muxed together; video streams are ignored"},
{0, NULL, NULL}
qtype = g_enum_register_static ("GstNvMultiUriSrcBinModeType2", values);
return qtype;
static GType
gst_video_cudadec_mem_type (void)
if (qtype == 0) {
{0, "Memory type Device", "memtype_device"},
{1, "Memory type Host Pinned", "memtype_pinned"},
{2, "Memory type Unified", "memtype_unified"},
{0, NULL, NULL}
qtype = g_enum_register_static ("GstNvUriSrcBinCudaDecMemType2", values);
return qtype;
static GType
gst_nvdsurisrc_dec_skip_frames (void)
static gsize initialization_value = 0;
static const GEnumValue skip_type[] = {
{DEC_SKIP_FRAMES_TYPE_NONE, "Decode all frames", "decode_all"},
{DEC_SKIP_FRAMES_TYPE_NONREF, "Decode non-ref frames",
"decode_non_ref"},
{DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY, "decode key frames",
"decode_key"},
{0, NULL, NULL}
if (g_once_init_enter (&initialization_value)) {
GType tmp = g_enum_register_static ("SkipFrames2", skip_type);
g_once_init_leave (&initialization_value, tmp);
return (GType) initialization_value;
static GType
gst_nvdsurisrc_rtp_protocol (void)
static const GEnumValue rtp_protocol[] = {
{RTP_PROTOCOL_MULTI, "UDP + UDP Multicast + TCP", "rtp-multi"},
{RTP_PROTOCOL_TCP, "TCP Only", "rtp-tcp"},
{0, NULL, NULL}
GType tmp = g_enum_register_static ("RtpProtocol2", rtp_protocol);
static GType
gst_nvdsurisrc_smart_record_type (void)
static const GEnumValue smart_rec_type[] = {
{SMART_REC_DISABLE, "Disable Smart Record", "smart-rec-disable"},
{SMART_REC_CLOUD, "Trigger Smart Record through cloud messages only",
"smart-rec-cloud"},
{SMART_REC_MULTI, "Trigger Smart Record through cloud and local events",
"smart-rec-multi"},
{0, NULL, NULL}
GType tmp = g_enum_register_static ("SmartRecordType2", smart_rec_type);
static GType
gst_nvdsurisrc_smart_record_mode (void)
static const GEnumValue smart_rec_mode[] = {
{SMART_REC_AUDIO_VIDEO, "Record audio and video if available",
"smart-rec-mode-av"},
{SMART_REC_VIDEO_ONLY, "Record video only if available",
"smart-rec-mode-video"},
{SMART_REC_AUDIO_ONLY, "Record audio only if available",
"smart-rec-mode-audio"},
{0, NULL, NULL}
GType tmp = g_enum_register_static ("SmartRecordMode2", smart_rec_mode);
static GType
gst_nvdsurisrc_smart_record_container (void)
static const GEnumValue smart_rec_container[] = {
{SMART_REC_MP4, "MP4 container", "smart-rec-mp4"},
{SMART_REC_MKV, "MKV container", "smart-rec-mkv"},
{0, NULL, NULL}
GType tmp = g_enum_register_static ("SmartRecordContainerType2",
smart_rec_container);
#define COMMON_AUDIO_CAPS \
"channels = " GST_AUDIO_CHANNELS_RANGE ", " \
"rate = (int) [ 1, MAX ]"
static GstStaticPadTemplate gst_nvmultiurisrc_bin_src_template =
GST_STATIC_PAD_TEMPLATE ("src",
GST_PAD_SRC,
GST_PAD_ALWAYS,
GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE_WITH_FEATURES ("memory:NVMM",
"{ " "NV12, RGBA, I420 }") "; "
"audio/x-raw(memory:NVMM), "
"format = { " "S16LE, F32LE }, "
"layout = (string) interleaved, " COMMON_AUDIO_CAPS));
GST_DEBUG_CATEGORY (gst_ds_nvmultiurisrc_bin_debug);
#define GST_CAT_DEFAULT gst_ds_nvmultiurisrc_bin_debug
/* Define our element type. Standard GObject/GStreamer boilerplate stuff */
#define gst_ds_nvmultiurisrc_bin_parent_class parent_class
#define _do_init \
GST_DEBUG_CATEGORY_INIT (gst_ds_nvmultiurisrc_bin_debug, "nvmultiurisrcbin", 0, "nvmultiurisrcbin element");
G_DEFINE_TYPE_WITH_CODE (GstDsNvMultiUriBin, gst_ds_nvmultiurisrc_bin,
GST_TYPE_BIN, _do_init);
static void gst_ds_nvmultiurisrc_bin_set_property (GObject * object,
guint prop_id, const GValue * value, GParamSpec * spec);
static void gst_ds_nvmultiurisrc_bin_get_property (GObject * object,
guint prop_id, GValue * value, GParamSpec * spec);
static void gst_ds_nvmultiurisrc_bin_finalize (GObject * object);
static GstStateChangeReturn
gst_ds_nvmultiurisrc_bin_change_state (GstElement * element,
GstStateChange transition);
static void
gst_ds_nvmultiurisrc_bin_handle_message (GstBin * bin, GstMessage * message);
static void rest_api_server_start (GstDsNvMultiUriBin * nvmultiurisrcbin);
static void
gst_ds_nvmultiurisrc_bin_class_init (GstDsNvMultiUriBinClass * klass)
GObjectClass *gobject_class;
GstElementClass *gstelement_class;
GstBinClass *gstbin_class;
gobject_class = G_OBJECT_CLASS (klass);
gstelement_class = GST_ELEMENT_CLASS (klass);
gstbin_class = GST_BIN_CLASS (klass);
gobject_class->set_property =
GST_DEBUG_FUNCPTR (gst_ds_nvmultiurisrc_bin_set_property);
gobject_class->get_property =
GST_DEBUG_FUNCPTR (gst_ds_nvmultiurisrc_bin_get_property);
gobject_class->finalize =
GST_DEBUG_FUNCPTR (gst_ds_nvmultiurisrc_bin_finalize);
gstelement_class->change_state =
GST_DEBUG_FUNCPTR (gst_ds_nvmultiurisrc_bin_change_state);
gstbin_class->handle_message =
GST_DEBUG_FUNCPTR (gst_ds_nvmultiurisrc_bin_handle_message);
gst_element_class_add_static_pad_template (gstelement_class,
&gst_nvmultiurisrc_bin_src_template);
//gst_element_class_add_static_pad_template (gstelement_class,
// &gst_nvmultiurisrc_bin_asrc_template);
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_URI_LIST,
g_param_spec_string ("uri-list", "comma separated URI list of sources",
"URI of the file or rtsp source", NULL,
(GParamFlags) (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS |
GST_PARAM_MUTABLE_READY)));
MULTIURIBIN_PROP_SENSOR_ID_LIST, g_param_spec_string ("sensor-id-list",
"comma separated list of source sensor IDs",
"this vector is one to one mapped with the uri-list", NULL,
MULTIURIBIN_PROP_SENSOR_NAME_LIST, g_param_spec_string ("sensor-name-list",
"optional comma separated list of source sensor names",
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_MODE,
g_param_spec_enum ("mode", "Video-only or Audio-only modes available",
"Set Video-only or Audio-only",
GST_TYPE_NVMULTIURISRCBIN_MODE, NVDS_MULTIURISRCBIN_MODE_VIDEO,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_DISABLE_AUDIO,
g_param_spec_boolean ("disable-audio",
"disable-audio",
"Disable audio path at init time",
DEFAULT_DISABLE_AUDIO,
(GParamFlags) (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_HTTP_IP,
g_param_spec_string ("ip-address", "Set REST API HTTP IP Address",
"REST API HTTP Endpoint", DEFAULT_HTTP_IP,
MULTIURIBIN_PROP_DISABLE_PASSTHROUGH,
g_param_spec_boolean ("disable-passthrough", "disable-passthrough",
"Disable passthrough mode at init time, applicable for nvvideoconvert only.",
DEFAULT_DISABLE_PASSTHROUGH,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_HTTP_PORT,
g_param_spec_string ("port",
"Set REST API HTTP Port number",
"REST API HTTP Endpoint; Note: User may pass \"0\" to disable REST API Server",
DEFAULT_HTTP_PORT,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_SEI_UUID,
g_param_spec_string ("sei-uuid",
"Set sei uuid",
"Set sei uuid on decoder.",
DEFAULT_SEI_UUID,
MULTIURIBIN_PROP_MAX_BATCH_SIZE, g_param_spec_uint ("max-batch-size",
"Set the maximum batch size to be used for nvstreammux",
"Maximum number of sources to be supported with this instance of nvmultiurisrcbin",
0, G_MAXUINT, DEFAULT_MAX_BATCH_SIZE,
/** @{ For nvurisrcbin */
MULTIURIBIN_PROP_NUM_EXTRA_SURF, g_param_spec_uint ("num-extra-surfaces",
"Set extra decoder surfaces",
"Number of surfaces in addition to minimum decode surfaces given by the decoder",
0, G_MAXUINT, DEFAULT_NUM_EXTRA_SURFACES,
MULTIURIBIN_PROP_GPU_DEVICE_ID, g_param_spec_uint ("gpu-id",
"Set GPU Device ID", "Set GPU Device ID", 0, G_MAXUINT,
DEFAULT_GPU_DEVICE_ID,
MULTIURIBIN_PROP_CUDADEC_MEM_TYPE, g_param_spec_enum ("cudadec-memtype",
"Memory type for cuda decoder buffers",
"Set to specify memory type for cuda decoder buffers",
GST_TYPE_V4L2_VID_CUDADEC_MEM_TYPE, DEFAULT_CUDADEC_MEM_TYPE,
MULTIURIBIN_PROP_DROP_FRAME_INTERVAL,
g_param_spec_uint ("drop-frame-interval",
"Set decoder drop frame interval",
"Interval to drop the frames,ex: value of 5 means every 5th frame will be given by decoder, rest all dropped",
0, 30, DEFAULT_DROP_FRAME_INTERVAL,
MULTIURIBIN_PROP_EXTRACT_SEI_TYPE5_DATA_DEC,
g_param_spec_boolean ("extract-sei-type5-data-dec",
"Extract SEI data for decoder",
"Set to extract and attach SEI type5 unregistered data on output buffer for decoder",
DEFAULT_SEI_EXTRACT_DATA,
MULTIURIBIN_PROP_LOW_LATENCY_MODE,
g_param_spec_boolean ("low-latency-mode", "low-latency-mode",
"Set low latency mode for bitstreams having I and IPPP frames on decoder",
DEFAULT_LOW_LATENCY_MODE,
MULTIURIBIN_PROP_DEC_SKIP_FRAMES, g_param_spec_enum ("dec-skip-frames",
"Type of frames to skip during decoding",
GST_TYPE_NVDSURI_SKIP_FRAMES, DEFAULT_DEC_SKIP_FRAME_TYPE,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_RTP_PROTOCOL,
g_param_spec_enum ("select-rtp-protocol",
"Transport Protocol to use for RTP",
"Transport Protocol to use for RTP", GST_TYPE_NVDSURI_RTP_PROTOCOL,
DEFAULT_RTP_PROTOCOL,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_FILE_LOOP,
g_param_spec_boolean ("file-loop",
"Loop file sources after EOS",
"Loop file sources after EOS. Src type must be source-type-uri and uri starting with 'file:/'",
DEFAULT_FILE_LOOP,
MULTIURIBIN_PROP_RTSP_RECONNECT_INTERVAL,
g_param_spec_uint ("rtsp-reconnect-interval", "RTSP Reconnect Interval",
"Timeout in seconds to wait since last data was received from an RTSP source before forcing a reconnection. 0=disable timeout",
0, G_MAXUINT, DEFAULT_RTSP_RECONNECT_INTERVAL,
MULTIURIBIN_PROP_RTSP_RECONNECT_ATTEMPTS,
g_param_spec_int ("rtsp-reconnect-attempts", "Set RTSP Reconnect attempts",
"Set RTSP reconnect attempts ",
G_MININT, G_MAXINT, DEFAULT_RTSP_RECONNECT_ATTEMPTS,
MULTIURIBIN_PROP_LATENCY,
g_param_spec_uint ("latency", "Latency",
"Jitterbuffer size in milliseconds; applicable only for RTSP streams.",
0, G_MAXUINT, DEFAULT_LATENCY,
MULTIURIBIN_PROP_UDP_BUFFER_SIZE,
g_param_spec_uint ("udp-buffer-size", "UDP Buffer Size",
"UDP Buffer Size in bytes; applicable only for RTSP streams.",
0, G_MAXUINT, DEFAULT_UDP_BUFFER_SIZE,
g_object_class_install_property (gobject_class, MULTIURIBIN_PROP_SMART_RECORD,
g_param_spec_enum ("smart-record",
"Enable Smart Record",
"Enable Smart Record and choose the type of events to respond to. Sources must be of type source-type-rtsp",
GST_TYPE_NVDSURI_SMART_RECORD_TYPE, DEFAULT_SMART_RECORD_MODE,
MULTIURIBIN_PROP_SMART_RECORD_DIR_PATH,
g_param_spec_string ("smart-rec-dir-path",
"Path of directory to save the recorded file",
"Path of directory to save the recorded file.", NULL,
MULTIURIBIN_PROP_SMART_RECORD_FILE_PREFIX,
g_param_spec_string ("smart-rec-file-prefix",
"Prefix of file name for recorded video",
"By default, Smart_Record is the prefix. For unique file names every source must be provided with a unique prefix",
DEFAULT_SMART_RECORD_PREFIX,
MULTIURIBIN_PROP_SMART_RECORD_VIDEO_CACHE,
g_param_spec_uint ("smart-rec-video-cache",
"Size of video cache in seconds.",
"Size of video cache in seconds. DEPRECATED: Use 'smart-rec-cache' instead",
0, G_MAXUINT, DEFAULT_SMART_RECORD_CACHE,
MULTIURIBIN_PROP_SMART_RECORD_CACHE, g_param_spec_uint ("smart-rec-cache",
"Size of cache in seconds, applies to both audio and video cache",
"Size of cache in seconds, applies to both audio and video cache", 0,
MULTIURIBIN_PROP_SMART_RECORD_CONTAINER,
g_param_spec_enum ("smart-rec-container",
"Container format of recorded video",
"Container format of recorded video. MP4 and MKV containers are supported. Sources must be of type source-type-rtsp",
GST_TYPE_NVDSURI_SMART_RECORD_CONTAINER,
DEFAULT_SMART_RECORD_CONTAINER,
MULTIURIBIN_PROP_SMART_RECORD_MODE, g_param_spec_enum ("smart-rec-mode",
"Smart record mode", "Smart record mode",
GST_TYPE_NVDSURI_SMART_RECORD_MODE, DEFAULT_SMART_RECORD_MODE,
MULTIURIBIN_PROP_SMART_RECORD_DEFAULT_DURATION,
g_param_spec_uint ("smart-rec-default-duration",
"In case a Stop event is not generated. This parameter will ensure the recording is stopped after a predefined default duration.",
0, G_MAXUINT, DEFAULT_SMART_RECORD_DEFAULT_DURATION,
/** @} For nvurisrcbin */
/** @{ For nvstreammux */
g_object_class_install_property (gobject_class, PROP_BATCHED_PUSH_TIMEOUT,
g_param_spec_int ("batched-push-timeout",
"(nvstreammux) Batched Push Timeout",
"Timeout in microseconds to wait after the first buffer is available\n"
"\t\t\tto push the batch even if the complete batch is not formed.\n"
"\t\t\tSet to -1 to wait infinitely", -1, G_MAXINT,
DEFAULT_BATCHED_PUSH_TIMEOUT,
g_object_class_install_property (gobject_class, PROP_WIDTH,
g_param_spec_uint ("width", "(nvstreammux) Width",
"Width of each frame in output batched buffer. This property MUST be set.",
0, G_MAXUINT, DEFAULT_WIDTH,
g_object_class_install_property (gobject_class, PROP_HEIGHT,
g_param_spec_uint ("height", "(nvstreammux) Height",
"Height of each frame in output batched buffer. This property MUST be set.",
0, G_MAXUINT, DEFAULT_HEIGHT,
g_object_class_install_property (gobject_class, PROP_ENABLE_PADDING,
g_param_spec_boolean ("enable-padding", "(nvstreammux) Enable Padding",
"Maintain input aspect ratio when scaling by padding with black bands.",
FALSE, (GParamFlags) (G_PARAM_READWRITE)));
g_object_class_install_property (gobject_class, PROP_NUM_SURFACES_PER_FRAME,
g_param_spec_uint ("num-surfaces-per-frame",
"(nvstreammux) Max number of surfaces per frame",
"Max number of surfaces per frame", 1, 4, 1,
g_object_class_install_property (gobject_class, PROP_LIVE_SOURCE,
g_param_spec_boolean ("live-source", "(nvstreammux) live source",
"Boolean property to inform muxer that sources are live.",
DEFAULT_LIVE_SOURCE,
g_object_class_install_property (gobject_class, PROP_SYNC_INPUTS,
g_param_spec_boolean ("sync-inputs", "(nvstreammux) Synchronize Inputs",
"Boolean property to force sychronization of input frames.",
0, (GParamFlags) (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
g_object_class_install_property (gobject_class, PROP_BUFFER_POOL_SIZE,
g_param_spec_uint ("buffer-pool-size", "Buffer Pool Size",
"Maximum number of buffers from muxer's output pool",
DEFAULT_BUFFER_POOL_SIZE, MAX_POOL_BUFFERS, DEFAULT_BUFFER_POOL_SIZE,
g_object_class_install_property (gobject_class, PROP_MAX_LATNECY,
g_param_spec_uint ("max-latency", "maximum lantency",
"Additional latency in live mode to allow upstream to take longer to produce buffers for the current position (in nanoseconds)",
0, G_MAXUINT, 0 /*200000000 */ ,
g_object_class_install_property (gobject_class, PROP_ATTACH_SYS_TIME_STAMP,
g_param_spec_boolean ("attach-sys-ts",
"Set system timestamp as ntp timestamp",
"If set to TRUE, system timestamp will be attached as ntp timestamp.\n"
"\t\t\tIf set to FALSE, ntp timestamp from rtspsrc, if available, will be attached.",
DEFAULT_ATTACH_SYS_TIME_STAMP,
g_object_class_install_property (gobject_class, PROP_CONFIG_FILE_PATH,
g_param_spec_string ("config-file-path", "Set config file path",
"Configuation file path (applicable for new nvstreammux)", DEFAULT_CONFIG_FILE_PATH,
PROP_NVBUF_MEMORY_TYPE_INSTALL (gobject_class);
PROP_COMPUTE_HW_INSTALL (gobject_class);
g_object_class_install_property (gobject_class, PROP_INTERPOLATION_METHOD,
g_param_spec_enum ("interpolation-method", "Interpolation-method",
"Set interpolation methods",
GST_TYPE_INTERPOLATION_METHOD, NvBufSurfTransformInter_Bilinear,
GST_PARAM_CONTROLLABLE | G_PARAM_CONSTRUCT)));
g_object_class_install_property (gobject_class, PROP_FRAME_NUM_RESET_ON_EOS,
g_param_spec_boolean ("frame-num-reset-on-eos",
"Frame Number Reset on EOS",
"Reset frame numbers to 0 for a source from which EOS is received (For debugging purpose only)",
FALSE, (GParamFlags) (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
PROP_FRAME_NUM_RESET_ON_STREAM_RESET,
g_param_spec_boolean ("frame-num-reset-on-stream-reset",
"Frame Number Reset on stream reset",
"Reset frame numbers to 0 for a source which needs to be reset. (For debugging purpose only)\n"
"Needs to be paired with tracking-id-reset-mode=1 in the tracker config.",
g_object_class_install_property (gobject_class, PROP_FRAME_DURATION,
g_param_spec_int ("frame-duration", "Frame duration",
"Duration of input frames in milliseconds for use in NTP timestamp correction based on frame rate.\n"
"\t\t\tIf set to 0, frame duration is inferred automatically from PTS values (default).\n"
"\t\t\tIf set to -1, disables frame rate based NTP timestamp correction.",
-1, G_MAXINT, DEFAULT_FRAME_DURATION,
g_object_class_install_property (gobject_class, PROP_ASYNC_PROCESS,
g_param_spec_boolean ("async-process",
"(nvstreammux) Asynchronous Process",
"Boolean property to enable/disable asynchronous processing of input frames for performance.",
DEFAULT_ASYNC_PROCESS,
g_object_class_install_property (gobject_class, PROP_NO_PIPELINE_EOS,
g_param_spec_boolean ("drop-pipeline-eos",
"(nvstreammux) No Pipeline EOS",
"Boolean property so that EOS is not propagated downstream when all source pads are at EOS.",
DEFAULT_NO_PIPELINE_EOS,
PROP_EXTRACT_SEI_TYPE5_DATA_MUX,
g_param_spec_boolean ("extract-sei-type5-data",
"Extract SEI data for Muxer",
"Set to extract and attach SEI type5 unregistered data on output buffer for Mux",
gst_element_class_set_details_simple (gstelement_class,
"NvMultiUri Bin", "NvMultiUri Bin",
"Nvidia DeepStreamSDK NvMultiUri Bin",
"NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries "
"@ https://devtalk.nvidia.com/default/board/209/");
static void
gst_ds_nvmultiurisrc_bin_set_property (GObject * object, guint prop_id,
const GValue * value, GParamSpec * pspec)
GstDsNvMultiUriBin *nvmultiurisrcbin = GST_DS_NVMULTIURISRC_BIN (object);
GstDsNvUriSrcConfig *config = nvmultiurisrcbin->config;
GstDsNvStreammuxConfig *muxConfig = nvmultiurisrcbin->muxConfig;
switch (prop_id) {
case MULTIURIBIN_PROP_URI_LIST:
if (nvmultiurisrcbin->uriList) {
g_free (nvmultiurisrcbin->uriList);
nvmultiurisrcbin->uriList = NULL;
if (nvmultiurisrcbin->uriListV) {
g_strfreev (nvmultiurisrcbin->uriListV);
nvmultiurisrcbin->uriListV = NULL;
nvmultiurisrcbin->uriList = g_value_dup_string (value);
g_strsplit (nvmultiurisrcbin->uriList, ",", -1);
break;
case MULTIURIBIN_PROP_SENSOR_ID_LIST:
if (nvmultiurisrcbin->sensorIdList) {
g_free (nvmultiurisrcbin->sensorIdList);
nvmultiurisrcbin->sensorIdList = NULL;
if (nvmultiurisrcbin->sensorIdListV) {
g_strfreev (nvmultiurisrcbin->sensorIdListV);
nvmultiurisrcbin->sensorIdListV = NULL;
nvmultiurisrcbin->sensorIdList = g_value_dup_string (value);
g_strsplit (nvmultiurisrcbin->sensorIdList, ",", -1);
break;
case MULTIURIBIN_PROP_SENSOR_NAME_LIST:
if (nvmultiurisrcbin->sensorNameList) {
g_free (nvmultiurisrcbin->sensorNameList);
nvmultiurisrcbin->sensorNameList = NULL;
if (nvmultiurisrcbin->sensorNameListV) {
g_strfreev (nvmultiurisrcbin->sensorNameListV);
nvmultiurisrcbin->sensorNameListV = NULL;
nvmultiurisrcbin->sensorNameList = g_value_dup_string (value);
g_strsplit (nvmultiurisrcbin->sensorNameList, ",", -1);
break;
case MULTIURIBIN_PROP_MODE:
nvmultiurisrcbin->mode = (NvDsMultiUriMode) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_HTTP_IP:
if (nvmultiurisrcbin->httpIp) {
g_free (nvmultiurisrcbin->httpIp);
nvmultiurisrcbin->httpIp = g_value_dup_string (value);
break;
case MULTIURIBIN_PROP_HTTP_PORT:
if (nvmultiurisrcbin->httpPort) {
g_free (nvmultiurisrcbin->httpPort);
nvmultiurisrcbin->httpPort = g_value_dup_string (value);
break;
case MULTIURIBIN_PROP_MAX_BATCH_SIZE:
muxConfig->maxBatchSize = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_RTSP_RECONNECT_INTERVAL:
config->rtsp_reconnect_interval_sec = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_RTSP_RECONNECT_ATTEMPTS:
config->rtsp_reconnect_attempts = g_value_get_int (value);
break;
case MULTIURIBIN_PROP_NUM_EXTRA_SURF:
config->num_extra_surfaces = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_DEC_SKIP_FRAMES:
config->skip_frames_type =
(NvDsUriSrcBinDecSkipFrame) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_GPU_DEVICE_ID:
config->gpu_id = g_value_get_uint (value);
muxConfig->gpu_id = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_CUDADEC_MEM_TYPE:
config->cuda_memory_type = g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_DROP_FRAME_INTERVAL:
config->drop_frame_interval = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_EXTRACT_SEI_TYPE5_DATA_DEC:
config->extract_sei_type5_data = g_value_get_boolean (value);
break;
case MULTIURIBIN_PROP_RTP_PROTOCOL:
config->rtp_protocol =
(NvDsUriSrcBinRtpProtocol) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_FILE_LOOP:
config->loop = g_value_get_boolean (value);
break;
case MULTIURIBIN_PROP_LATENCY:
config->latency = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_UDP_BUFFER_SIZE:
config->udp_buffer_size = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD:
config->smart_record = (NvDsUriSrcBinSRType) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_DIR_PATH:
config->smart_rec_dir_path = g_value_dup_string (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_FILE_PREFIX:
config->smart_rec_file_prefix = g_value_dup_string (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_VIDEO_CACHE:
g_warning
("%s: Deprecated property 'smart-rec-video-cache' set. Set property 'smart-rec-cache' instead.",
GST_ELEMENT_NAME (nvmultiurisrcbin));
break;
case MULTIURIBIN_PROP_SMART_RECORD_CACHE:
config->smart_rec_cache_size = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_CONTAINER:
config->smart_rec_container =
(NvDsUriSrcBinSRCont) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_MODE:
config->smart_rec_mode = (NvDsUriSrcBinSRMode) g_value_get_enum (value);
break;
case MULTIURIBIN_PROP_SMART_RECORD_DEFAULT_DURATION:
config->smart_rec_def_duration = g_value_get_uint (value);
break;
case MULTIURIBIN_PROP_DISABLE_PASSTHROUGH:
config->disable_passthrough = g_value_get_boolean (value);
break;
case MULTIURIBIN_PROP_LOW_LATENCY_MODE:
config->low_latency_mode = g_value_get_boolean (value);
break;
case MULTIURIBIN_PROP_SEI_UUID:
config->sei_uuid = g_value_dup_string (value);
break;
case MULTIURIBIN_PROP_DISABLE_AUDIO:
config->disable_audio = g_value_get_boolean (value);
break;
case PROP_BATCH_SIZE:
muxConfig->batch_size = g_value_get_uint (value);
break;
case PROP_BATCHED_PUSH_TIMEOUT:
muxConfig->batched_push_timeout = g_value_get_int (value);
break;
case PROP_WIDTH:
muxConfig->pipeline_width = g_value_get_uint (value);
break;
case PROP_HEIGHT:
muxConfig->pipeline_height = g_value_get_uint (value);
break;
case PROP_NUM_SURFACES_PER_FRAME:
muxConfig->num_surfaces_per_frame = g_value_get_uint (value);
break;
case PROP_LIVE_SOURCE:
muxConfig->live_source = g_value_get_boolean (value);
break;
case PROP_SYNC_INPUTS:
muxConfig->sync_inputs = g_value_get_boolean (value);
break;
case PROP_ATTACH_SYS_TIME_STAMP:
muxConfig->attach_sys_ts_as_ntp = g_value_get_boolean (value);
break;
case PROP_CONFIG_FILE_PATH:
muxConfig->config_file_path = g_value_dup_string (value);
break;
case PROP_ENABLE_PADDING:
muxConfig->enable_padding = g_value_get_boolean (value);
break;
case PROP_COMPUTE_HW:
muxConfig->compute_hw = g_value_get_enum (value);
break;
case PROP_NVBUF_MEMORY_TYPE:
muxConfig->nvbuf_memory_type = g_value_get_enum (value);
break;
case PROP_INTERPOLATION_METHOD:
muxConfig->interpolation_method = g_value_get_enum (value);
break;
case PROP_BUFFER_POOL_SIZE:
muxConfig->buffer_pool_size = g_value_get_uint (value);
break;
case PROP_MAX_LATNECY:
muxConfig->max_latency = g_value_get_uint (value);
break;
case PROP_FRAME_NUM_RESET_ON_EOS:
muxConfig->frame_num_reset_on_eos = g_value_get_boolean (value);
break;
case PROP_FRAME_NUM_RESET_ON_STREAM_RESET:
muxConfig->frame_num_reset_on_stream_reset = g_value_get_boolean (value);
break;
case PROP_ASYNC_PROCESS:
muxConfig->async_process = g_value_get_boolean (value);
break;
case PROP_NO_PIPELINE_EOS:
muxConfig->no_pipeline_eos = g_value_get_boolean (value);
break;
case PROP_FRAME_DURATION:
gint ms_value = g_value_get_int (value);
if (ms_value < 0) {
muxConfig->frame_duration = GST_CLOCK_TIME_NONE;
} else {
muxConfig->frame_duration = (GstClockTime) ms_value *GST_MSECOND;
break;
case PROP_EXTRACT_SEI_TYPE5_DATA_MUX:
muxConfig->extract_sei_type5_data = g_value_get_boolean (value);
break;
default:
G_OBJECT_WARN_INVALID_PROPERTY_ID (object, prop_id, pspec);
break;
static void
gst_ds_nvmultiurisrc_bin_get_property (GObject * object, guint prop_id,
switch (prop_id) {
g_value_set_string (value, nvmultiurisrcbin->uriList);
break;
g_value_set_string (value, nvmultiurisrcbin->sensorIdList);
break;
g_value_set_string (value, nvmultiurisrcbin->sensorNameList);
break;
g_value_set_enum (value, (guint) nvmultiurisrcbin->mode);
break;
g_value_set_string (value, nvmultiurisrcbin->httpIp);
break;
g_value_set_string (value, nvmultiurisrcbin->httpPort);
break;
g_value_set_uint (value, muxConfig->maxBatchSize);
break;
g_value_set_uint (value, config->num_extra_surfaces);
break;
g_value_set_enum (value, config->skip_frames_type);
break;
//Note: config->gpu_id will be same as muxConfig->gpu_id
g_value_set_uint (value, config->gpu_id);
break;
g_value_set_enum (value, config->cuda_memory_type);
break;
g_value_set_string (value, config->sei_uuid);
break;
g_value_set_uint (value, config->drop_frame_interval);
break;
g_value_set_boolean (value, config->extract_sei_type5_data);
break;
g_value_set_enum (value, config->rtp_protocol);
break;
g_value_set_boolean (value, config->loop);
break;
g_value_set_uint (value, config->rtsp_reconnect_interval_sec);
break;
g_value_set_int (value, config->rtsp_reconnect_attempts);
break;
g_value_set_uint (value, config->latency);
break;
g_value_set_uint (value, config->udp_buffer_size);
break;
g_value_set_enum (value, config->smart_record);
break;
g_value_set_string (value, config->smart_rec_dir_path);
break;
g_value_set_string (value, config->smart_rec_file_prefix);
break;
g_value_set_uint (value, config->smart_rec_cache_size);
break;
g_value_set_enum (value, config->smart_rec_container);
break;
g_value_set_enum (value, config->smart_rec_mode);
break;
g_value_set_uint (value, config->smart_rec_def_duration);
break;
g_value_set_boolean (value, config->disable_passthrough);
break;
g_value_set_boolean (value, config->low_latency_mode);
break;
g_value_set_boolean (value, config->disable_audio);
break;
g_value_set_uint (value, muxConfig->batch_size);
break;
g_value_set_int (value, muxConfig->batched_push_timeout);
break;
case PROP_WIDTH:
g_value_set_uint (value, muxConfig->pipeline_width);
break;
case PROP_HEIGHT:
g_value_set_uint (value, muxConfig->pipeline_height);
break;
g_value_set_uint (value, muxConfig->num_surfaces_per_frame);
break;
g_value_set_boolean (value, muxConfig->enable_padding);
break;
g_value_set_boolean (value, muxConfig->live_source);
break;
g_value_set_boolean (value, muxConfig->sync_inputs);
break;
g_value_set_boolean (value, muxConfig->attach_sys_ts_as_ntp);
break;
g_value_set_string (value, muxConfig->config_file_path);
break;
g_value_set_enum (value, muxConfig->compute_hw);
break;
g_value_set_enum (value, muxConfig->nvbuf_memory_type);
break;
g_value_set_enum (value, muxConfig->interpolation_method);
break;
g_value_set_uint (value, muxConfig->buffer_pool_size);
break;
g_value_set_uint (value, muxConfig->max_latency);
break;
g_value_set_boolean (value, muxConfig->frame_num_reset_on_eos);
break;
g_value_set_boolean (value, muxConfig->frame_num_reset_on_stream_reset);
break;
gint ms_value = -1;
ms_value = muxConfig->frame_duration / GST_MSECOND;
g_value_set_int (value, ms_value);
break;
g_value_set_boolean (value, muxConfig->async_process);
break;
g_value_set_boolean (value, muxConfig->no_pipeline_eos);
break;
g_value_set_boolean (value, muxConfig->extract_sei_type5_data);
break;
default:
break;
static void
gst_ds_nvmultiurisrc_bin_init (GstDsNvMultiUriBin * nvmultiurisrcbin)
g_object_set (G_OBJECT (nvmultiurisrcbin), "async-handling", TRUE, nullptr);
nvmultiurisrcbin->config =
(GstDsNvUriSrcConfig *) g_malloc0 (sizeof (GstDsNvUriSrcConfig));
nvmultiurisrcbin->muxConfig =
(GstDsNvStreammuxConfig *) g_malloc0 (sizeof (GstDsNvStreammuxConfig));
nvmultiurisrcbin->muxConfig->nvbuf_memory_type = DEFAULT_NVBUF_MEM_TYPE;
/** Note: Using max-batch-size config to workaround
* the pipeline slow-down caused by add/remove without this
* Issue tracked for next release
nvmultiurisrcbin->muxConfig->maxBatchSize = DEFAULT_MAX_BATCH_SIZE;
nvmultiurisrcbin->muxConfig->async_process = DEFAULT_ASYNC_PROCESS;
nvmultiurisrcbin->muxConfig->no_pipeline_eos = DEFAULT_NO_PIPELINE_EOS;
nvmultiurisrcbin->muxConfig->attach_sys_ts_as_ntp =
DEFAULT_ATTACH_SYS_TIME_STAMP;
nvmultiurisrcbin->muxConfig->config_file_path = g_strdup (DEFAULT_CONFIG_FILE_PATH);
nvmultiurisrcbin->config->uri = NULL;
nvmultiurisrcbin->config->sei_uuid = DEFAULT_SEI_UUID;
nvmultiurisrcbin->config->num_extra_surfaces = DEFAULT_NUM_EXTRA_SURFACES;
nvmultiurisrcbin->config->gpu_id = DEFAULT_GPU_DEVICE_ID;
nvmultiurisrcbin->config->cuda_memory_type = DEFAULT_CUDADEC_MEM_TYPE;
nvmultiurisrcbin->config->drop_frame_interval = DEFAULT_DROP_FRAME_INTERVAL;
nvmultiurisrcbin->config->extract_sei_type5_data = DEFAULT_SEI_EXTRACT_DATA;
nvmultiurisrcbin->config->low_latency_mode = DEFAULT_LOW_LATENCY_MODE;
nvmultiurisrcbin->muxConfig->extract_sei_type5_data = DEFAULT_NO_PIPELINE_EOS;
nvmultiurisrcbin->config->skip_frames_type =
(NvDsUriSrcBinDecSkipFrame) DEFAULT_DEC_SKIP_FRAME_TYPE;
nvmultiurisrcbin->config->rtp_protocol =
(NvDsUriSrcBinRtpProtocol) DEFAULT_RTP_PROTOCOL;
nvmultiurisrcbin->config->rtsp_reconnect_interval_sec =
DEFAULT_RTSP_RECONNECT_INTERVAL;
nvmultiurisrcbin->config->rtsp_reconnect_attempts =
DEFAULT_RTSP_RECONNECT_ATTEMPTS;
nvmultiurisrcbin->config->latency = DEFAULT_LATENCY;
nvmultiurisrcbin->config->disable_passthrough = DEFAULT_DISABLE_PASSTHROUGH;
nvmultiurisrcbin->config->disable_audio = DEFAULT_DISABLE_AUDIO;
nvmultiurisrcbin->config->udp_buffer_size = DEFAULT_UDP_BUFFER_SIZE;
nvmultiurisrcbin->config->sock_fd = DEFAULT_SOCK_FD;
nvmultiurisrcbin->mode = NVDS_MULTIURISRCBIN_MODE_VIDEO;
nvmultiurisrcbin->sourceIdCounter = 0;
nvmultiurisrcbin->bin_src_pad =
gst_ghost_pad_new_no_target_from_template ("src",
gst_static_pad_template_get (&gst_nvmultiurisrc_bin_src_template));
gst_element_add_pad (GST_ELEMENT (nvmultiurisrcbin),
nvmultiurisrcbin->bin_src_pad);
nvmultiurisrcbin->restServer = NULL;
nvmultiurisrcbin->httpIp = g_strdup (DEFAULT_HTTP_IP);
nvmultiurisrcbin->httpPort = g_strdup (DEFAULT_HTTP_PORT);
g_mutex_init (&nvmultiurisrcbin->bin_lock);
GST_OBJECT_FLAG_SET (nvmultiurisrcbin, GST_ELEMENT_FLAG_SOURCE);
/* Free resources allocated during init. */
static void
g_free (nvmultiurisrcbin->config);
if (nvmultiurisrcbin->muxConfig->config_file_path) {
g_free (nvmultiurisrcbin->muxConfig->config_file_path);
G_OBJECT_CLASS (parent_class)->finalize (object);
GstDsNvMultiUriBin *nvmultiurisrcbin = GST_DS_NVMULTIURISRC_BIN (element);
GstStateChangeReturn ret;
if (transition == GST_STATE_CHANGE_NULL_TO_READY) {
GST_DEBUG_OBJECT (nvmultiurisrcbin,
"GST_STATE_CHANGE_NULL_TO_READY %s %d\n", __func__, __LINE__);
gboolean is_rtsp = nvmultiurisrcbin->config->uri
&& g_str_has_prefix (nvmultiurisrcbin->config->uri, "rtsp://");
(void) is_rtsp;
guint binNameForCreatorLen =
strlen (GST_ELEMENT_NAME ((GstElement *) nvmultiurisrcbin));
gchar *binNameForCreator =
g_strndup (GST_ELEMENT_NAME ((GstElement *) nvmultiurisrcbin),
binNameForCreatorLen + 10);
if ( g_strlcat (binNameForCreator, (const gchar *) "_creator",
binNameForCreatorLen + 10) < binNameForCreatorLen + 10 ) {
"Unable to append string \"_creator\" to the bin name %s %d\n", __func__, __LINE__);
/** Initialize the Bin Manipulation API for stream add/remove */
nvmultiurisrcbin->nvmultiurisrcbinCreator =
gst_nvmultiurisrcbincreator_init (binNameForCreator,
nvmultiurisrcbin->mode, nvmultiurisrcbin->muxConfig);
g_free (binNameForCreator);
if (!nvmultiurisrcbin->nvmultiurisrcbinCreator) {
GST_ERROR_OBJECT (nvmultiurisrcbin,
"Failed to create nvmultiurisrcbin handler\n");
return GST_STATE_CHANGE_FAILURE;
gst_bin_add (GST_BIN (nvmultiurisrcbin),
gst_nvmultiurisrcbincreator_get_bin (nvmultiurisrcbin->
nvmultiurisrcbinCreator));
/** Add the initial list of sources from uri-list */
guint i = 0;
guint sensorIdListVLen =
nvmultiurisrcbin->sensorIdListV ? g_strv_length (nvmultiurisrcbin->
sensorIdListV) : 0;
guint sensorNameListVLen =
nvmultiurisrcbin->sensorNameListV ? g_strv_length (nvmultiurisrcbin->
sensorNameListV) : 0;
/** Add the initial sources from uri-list */
for (i = 0; nvmultiurisrcbin->uriListV[i] != NULL; i++) {
/** Add the source */
nvmultiurisrcbin->config->uri = nvmultiurisrcbin->uriListV[i];
if (i < sensorIdListVLen && nvmultiurisrcbin->sensorIdListV[i]) {
nvmultiurisrcbin->config->sensorId =
nvmultiurisrcbin->sensorIdListV[i];
if (i < sensorNameListVLen && nvmultiurisrcbin->sensorNameListV[i]) {
nvmultiurisrcbin->config->sensorName =
nvmultiurisrcbin->sensorNameListV[i];
nvmultiurisrcbin->config->source_id = 0;
g_mutex_lock (&nvmultiurisrcbin->bin_lock);
gboolean ret =
gst_nvmultiurisrcbincreator_add_source (nvmultiurisrcbin->
nvmultiurisrcbinCreator, nvmultiurisrcbin->config);
g_mutex_unlock (&nvmultiurisrcbin->bin_lock);
if (ret == FALSE) {
GST_WARNING_OBJECT (nvmultiurisrcbin, "Failed to add uri [%s]\n",
nvmultiurisrcbin->uriListV[i]);
} else {
GST_DEBUG_OBJECT (nvmultiurisrcbin, "Successfully added uri [%s]\n",
/** clean the config place-holders that we change for each source */
nvmultiurisrcbin->config->sensorId = NULL;
nvmultiurisrcbin->config->sensorName = NULL;
gst_nvmultiurisrcbincreator_sync_children_states (nvmultiurisrcbin->
nvmultiurisrcbinCreator);
gst_element_call_async (GST_ELEMENT (nvmultiurisrcbin),
(GstElementCallAsyncFunc) gst_bin_sync_children_states, NULL, NULL);
/** Link the internal bin's proxy src pad with the outer bin's src pad
* Note: This is done even if uri-list was NULL
* to allow streams to be added later runtime
gboolean ret =
gst_ghost_pad_set_target (GST_GHOST_PAD (nvmultiurisrcbin->
bin_src_pad),
gst_nvmultiurisrcbincreator_get_source_pad (nvmultiurisrcbin->
if (ret == FALSE) {
"Failed to set nvstreammux src pad as bin src pad\n");
} else {
"Successfully set nvstreammux src pad as bin src pad\n");
/** Initialize the HTTP server for REST API */
if (g_strcmp0 (nvmultiurisrcbin->httpPort, "0") != 0) {
//Valid HTTP port passed; start REST API server
rest_api_server_start (nvmultiurisrcbin);
} else {
"Not starting REST Server as port was passed \"0\"; "
"Users may still have all sources mentioned with uri-list in the pipeline\n");
if (transition == GST_STATE_CHANGE_PLAYING_TO_PAUSED) {
"GST_STATE_CHANGE_PLAYING_TO_PAUSED %s %d\n", __func__, __LINE__);
if (transition == GST_STATE_CHANGE_READY_TO_PAUSED) {
"GST_STATE_CHANGE_READY_TO_PAUSED %s %d\n", __func__, __LINE__);
if (transition == GST_STATE_CHANGE_PAUSED_TO_PLAYING) {
"GST_STATE_CHANGE_PAUSED_TO_PLAYING %s %d\n", __func__, __LINE__);
if (transition == GST_STATE_CHANGE_PAUSED_TO_READY) {
"GST_STATE_CHANGE_PAUSED_TO_READY %s %d\n", __func__, __LINE__);
if (transition == GST_STATE_CHANGE_READY_TO_NULL) {
"GST_STATE_CHANGE_READY_TO_NULL %s %d\n", __func__, __LINE__);
if (nvmultiurisrcbin->nvmultiurisrcbinCreator) {
gst_nvmultiurisrcbincreator_deinit (nvmultiurisrcbin->
nvmultiurisrcbin->nvmultiurisrcbinCreator = NULL;
if (nvmultiurisrcbin->restServer) {
nvds_rest_server_stop ((NvDsRestServer *) nvmultiurisrcbin->restServer);
ret = GST_ELEMENT_CLASS (parent_class)->change_state (element, transition);
return ret;
gpointer
GThreadFuncRemoveSource (gpointer data)
DsNvMultiUriBinSourceInfo *sourceInfo = (DsNvMultiUriBinSourceInfo *) data;
GstDsNvMultiUriBin *ubin = sourceInfo->ubin;
gboolean ret;
* revoking the use of gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change()
* All test cases in gsttest PASS with this change
* Note: Multiple calls to gst_nvmultiurisrcbincreator_remove_source() is handled now in the API.
ret = gst_nvmultiurisrcbincreator_remove_source
(ubin->nvmultiurisrcbinCreator, sourceInfo->sourceId);
if (ret == FALSE) {
GST_WARNING_OBJECT (ubin,
"Failed to remove sensor; the sensor might have gotten removed already\n");
} else {
GST_DEBUG_OBJECT (ubin, "Successfully removed sensor\n");
g_free (sourceInfo);
return NULL;
static void
GstDsNvMultiUriBin *ubin = (GstDsNvMultiUriBin *) bin;
(void) ubin;
if (GST_MESSAGE_TYPE (message) == GST_MESSAGE_ERROR) {
gchar *debug = NULL;
GError *error = NULL;
gst_message_parse_error (message, &error, &debug);
g_printerr ("nvmultiurisrcbin ERROR from element %s: %s\n",
GST_OBJECT_NAME (message->src), error->message);
gboolean didSourceElemError = FALSE;
if ((g_strcmp0 (GST_OBJECT_NAME (message->src), "source") == 0
|| g_strcmp0 (GST_OBJECT_NAME (message->src), "src") == 0)
&& g_strrstr (error->message, "GStreamer error:")) {
didSourceElemError = TRUE;
} else if (g_strrstr (error->message, "Invalid URI")) {
} else if (g_strrstr (error->message, "No URI handler implemented for")) {
} else if (g_strrstr (error->message, "Resource not found")) {
} else if (g_strrstr (error->message, "Could not open resource for")) {
} else if (g_strrstr (error->message, "No supported authentication protocol was found")) {
} else if (g_strrstr (error->message, "Could not get/set settings from/on resource")) {
if (didSourceElemError) {
"Converting ERROR to WARNING; We need to be able to continue adding valid streams\n");
GST_MESSAGE_TYPE (message) = GST_MESSAGE_WARNING; // Change error to warning, so app can continue running
// Retrieve the nvurisrcbin corresponding to the source so that we may get the source id and remove the broken stream
GstDsNvUriSrcBin *nvurisrcbin = NULL;
// If the source of the message is named "source", this is the filesrc of the uridecodebin of the nvurisrcbin. So, the nvurisrcbin will be the src->parent->parent
if (g_strcmp0 (GST_OBJECT_NAME (message->src), "source") == 0) {
nvurisrcbin = (GstDsNvUriSrcBin *) message->src->parent->parent;
// "nvurisrc_bin_src_elem" is the uridecodebin of the nvurisrcbin. "src" is the rtspsrc of the nvurisrcbin. In either case, the nvurisrcbin will be the src->parent
else if (g_strcmp0 (GST_OBJECT_NAME (message->src),
"nvurisrc_bin_src_elem") == 0
|| g_strcmp0 (GST_OBJECT_NAME (message->src), "src") == 0) {
nvurisrcbin = (GstDsNvUriSrcBin *) message->src->parent;
// Remove the stream
if (nvurisrcbin != NULL && GST_IS_OBJECT (nvurisrcbin)
&& nvurisrcbin->config) {
g_mutex_lock (&ubin->bin_lock);
GST_DEBUG_OBJECT (ubin, "removing source %d\n",
nvurisrcbin->config->source_id);
g_malloc0 (sizeof (DsNvMultiUriBinSourceInfo));
sourceInfo->ubin = ubin;
sourceInfo->sourceId = nvurisrcbin->config->source_id;
sourceInfo->didSourceElemError = didSourceElemError;
/** Remove the stream from a separate short lived thread */
g_thread_new (NULL, GThreadFuncRemoveSource, sourceInfo);
g_mutex_unlock (&ubin->bin_lock);
g_error_free (error);
g_free (debug);
GST_BIN_CLASS (parent_class)->handle_message (bin, message);
static int UnixSocketConnect(const char *socket_name) {
int sock_fd = -1;
struct sockaddr_un sock_addr;
int wait_loop = 0;
sock_fd = socket(PF_UNIX, SOCK_STREAM, 0);
if (sock_fd < 0) {
g_printerr("%s: socket create failed.\n", __func__);
return -1;
memset(&sock_addr, 0, sizeof(struct sockaddr_un));
sock_addr.sun_family = AF_UNIX;
strncpy(sock_addr.sun_path, socket_name, sizeof(sock_addr.sun_path) - 1);
while (connect(sock_fd, (const struct sockaddr *)&sock_addr,
sizeof(struct sockaddr_un))) {
/* wait loop runs 10 times after sleep of 100ms each */
if (wait_loop < 10) {
g_print("Waiting for producer count %d\n", wait_loop);
usleep(100000);
wait_loop++;
} else {
g_printerr("\n%s: Waiting timed out\n", __func__);
close (sock_fd);
sock_fd = -1;
return -1;
return sock_fd;
static void
s_stream_api_impl (NvDsServerStreamInfo * stream_info, void *ctx)
GstDsNvMultiUriBin *nvmultiurisrcbin = (GstDsNvMultiUriBin *) ctx;
(void) nvmultiurisrcbin;
if (stream_info->uri.find ("/api/v1/") != std::string::npos) {
/** check stream_info->value_change to identify stream add/remove */
if (g_strrstr (stream_info->value_change.c_str (), "add")
|| g_strrstr (stream_info->value_change.c_str (), "streaming")) {
GstDsNvUriSrcConfig **sourceConfigs = NULL;
guint numSourceConfigs = 0;
/** Check if we can accomodate more sources */
if (gst_nvmultiurisrcbincreator_get_active_sources_list (nvmultiurisrcbin->
nvmultiurisrcbinCreator, &numSourceConfigs, &sourceConfigs)) {
gst_nvmultiurisrcbincreator_src_config_list_free (nvmultiurisrcbin->
nvmultiurisrcbinCreator, numSourceConfigs, sourceConfigs);
if (numSourceConfigs >= nvmultiurisrcbin->muxConfig->maxBatchSize) {
GST_WARNING_OBJECT (nvmultiurisrcbin, "Failed to add sensor id=[%s]; "
"We have [%d] active sources and max-batch-size is configured to [%d]\n",
stream_info->value_camera_id.c_str (),
numSourceConfigs, nvmultiurisrcbin->muxConfig->maxBatchSize);
stream_info->status = STREAM_ADD_FAIL;
stream_info->stream_log = "STREAM_ADD_FAIL, Active sources exceded max-batch-size of nvstreammux";
stream_info->err_info.code = StatusInternalServerError;
return;
/** Check if sensor id already exist */
GstDsNvUriSrcConfig *sourceConfig = NULL;
if ((sourceConfig =
gst_nvmultiurisrcbincreator_get_source_config_by_sensorid
(nvmultiurisrcbin->nvmultiurisrcbinCreator,
stream_info->value_camera_id.c_str ()))) {
"Failed to add sensor id=[%s]; Already added\n",
stream_info->value_camera_id.c_str ());
stream_info->stream_log = "STREAM_ADD_FAIL, Duplicate Camera id, unable to add stream";
gst_nvmultiurisrcbincreator_src_config_free (sourceConfig);
return;
(gchar *) stream_info->value_camera_url.c_str ();
(gchar *) stream_info->value_camera_id.c_str ();
(gchar *) stream_info->value_camera_name.c_str ();
gboolean is_ipc = nvmultiurisrcbin->config->uri
&& g_str_has_prefix (nvmultiurisrcbin->config->uri, "ipc://");
if (is_ipc) {
const char *prefix = "ipc://";
const char *socket_path = nvmultiurisrcbin->config->uri + strlen(prefix);
int sock_fd = UnixSocketConnect(socket_path);
if (sock_fd == -1) {
"Failed to add sensor id=[%s]; Connection Failed\n",
stream_info->stream_log = "STREAM_ADD_FAIL, Connection failed, unable to add stream";
return;
g_print("IPC socket path = %s and socket fd = %d\n", socket_path, sock_fd);
nvmultiurisrcbin->config->sock_fd = sock_fd;
gboolean ret =
if (ret == FALSE) {
"Failed to add sensor id=[%s] uri=[%s]\n",
nvmultiurisrcbin->config->sensorId, nvmultiurisrcbin->config->uri);
stream_info->stream_log = "STREAM_ADD_FAIL, Failed to add source stream";
} else {
"Successfully added sensor id=[%s] uri=[%s]\n",
stream_info->status = STREAM_ADD_SUCCESS;
stream_info->stream_log = "STREAM_ADD_SUCCESS";
stream_info->err_info.code = StatusOk;
} else if (g_strrstr (stream_info->value_change.c_str (), "remove")) {
/** Remove the source */
/** First, find the GstDsNvUriSrcConfig object from nvmultiurisrcbinCreator
* for the provided sensorId and uri */
GstDsNvUriSrcConfig const *sourceConfig =
gst_nvmultiurisrcbincreator_get_source_config (nvmultiurisrcbin->
stream_info->value_camera_url.c_str (),
if (sourceConfig) {
gboolean ret =
gst_nvmultiurisrcbincreator_remove_source (nvmultiurisrcbin->
sourceConfig->source_id);
//Note: after call to gst_nvmultiurisrcbincreator_remove_source, sourceConfig will be invalid
gst_nvmultiurisrcbincreator_src_config_free((GstDsNvUriSrcConfig*)sourceConfig);
if (ret == FALSE) {
GST_WARNING_OBJECT (nvmultiurisrcbin, "Failed to remove sensor\n");
stream_info->status = STREAM_REMOVE_FAIL;
stream_info->stream_log = "STREAM_REMOVE_FAIL,Failed to remove source stream";
} else {
GST_DEBUG_OBJECT (nvmultiurisrcbin, "Successfully removed sensor\n");
stream_info->status = STREAM_REMOVE_SUCCESS;
stream_info->stream_log = "STREAM_REMOVE_SUCCESS";
} else {
"No record found; Failed to remove sensor id=[%s] uri=[%s]\n",
} else {
"Sensor API change string not supported\n");
stream_info->stream_log = "Sensor API change string not supported";
stream_info->err_info.code = StatusBadRequest;
} else {
g_print ("Unsupported REST API version \n");
return;
static void
s_roi_api_impl (NvDsServerRoiInfo * roi_info, void *ctx)
guint sourceId = std::stoi (roi_info->stream_id);
if (roi_info->uri.find ("/api/v1/") != std::string::npos) {
if (!find_source (nvmultiurisrcbin->nvmultiurisrcbinCreator, sourceId)) {
roi_info->status = ROI_UPDATE_FAIL;
roi_info->err_info.code = StatusInternalServerError;
roi_info->roi_log = "ROI_UPDATE_FAIL, Unable to find stream id for ROI updation";
} else {
RoiDimension roi_dim[roi_info->roi_count];
for (int i = 0; i < (int) roi_info->roi_count; i++) {
if ( g_strlcpy (roi_dim[i].roi_id, roi_info->vect[i].roi_id,
sizeof (roi_dim[i].roi_id)) < sizeof (roi_dim[i].roi_id) ){
GST_DEBUG_OBJECT (nvmultiurisrcbin, "Failed to copy roi id(s) \n");
roi_dim[i].left = roi_info->vect[i].left;
roi_dim[i].top = roi_info->vect[i].top;
roi_dim[i].width = roi_info->vect[i].width;
roi_dim[i].height = roi_info->vect[i].height;
GstEvent *nvevent =
gst_nvevent_new_roi_update ((char *) roi_info->stream_id.c_str (),
roi_info->roi_count, roi_dim);
if (!nvevent) {
roi_info->roi_log = "ROI_UPDATE_FAIL, nv-roi-update event creation failed";
if (!gst_pad_push_event ((GstPad *) (nvmultiurisrcbin->bin_src_pad),
nvevent)) {
switch (roi_info->roi_flag) {
case ROI_UPDATE:
g_print ("[WARN] nv-roi-update event not pushed downstream.. !! \n");
roi_info->roi_log = "ROI_UPDATE_FAIL, nv-roi-update event not pushed";
break;
default:
break;
} else {
case ROI_UPDATE:
roi_info->status = ROI_UPDATE_SUCCESS;
roi_info->roi_log = "ROI_UPDATE_SUCCESS";
roi_info->err_info.code = StatusOk;
break;
default:
break;
} else {
static void
s_dec_api_impl (NvDsServerDecInfo * dec_info, void *ctx)
guint sourceId = std::stoi (dec_info->stream_id);
if (dec_info->uri.find ("/api/v1/") != std::string::npos) {
if (!set_nvuribin_dec_prop (nvmultiurisrcbin->nvmultiurisrcbinCreator,
sourceId, dec_info)) {
switch (dec_info->dec_flag) {
case DROP_FRAME_INTERVAL:
g_print ("[WARN] drop-frame-interval not set on decoder .. !! \n");
dec_info->status = DROP_FRAME_INTERVAL_UPDATE_FAIL;
dec_info->dec_log = "DROP_FRAME_INTERVAL_UPDATE_FAIL, drop-frame-interval not set on decoder";
dec_info->err_info.code = StatusInternalServerError;
break;
case SKIP_FRAMES:
g_print ("[WARN] skip-frame not set on decoder .. !! \n");
dec_info->status = SKIP_FRAMES_UPDATE_FAIL;
dec_info->dec_log = "SKIP_FRAMES_UPDATE_FAIL, skip-frame not set on decoder";
break;
case LOW_LATENCY_MODE:
g_print ("[WARN] low-latency-mode not set on decoder .. !! \n");
dec_info->status = LOW_LATENCY_MODE_UPDATE_FAIL;
dec_info->dec_log = "LOW_LATENCY_MODE_UPDATE_FAIL, low-latency-mode not set on decoder";
break;
default:
break;
} else {
dec_info->status =
dec_info->status !=
DROP_FRAME_INTERVAL_UPDATE_FAIL ? DROP_FRAME_INTERVAL_UPDATE_SUCCESS
: DROP_FRAME_INTERVAL_UPDATE_FAIL;
if ( dec_info->status == DROP_FRAME_INTERVAL_UPDATE_SUCCESS ){
dec_info->err_info.code = StatusOk;
dec_info->dec_log = "DROP_FRAME_INTERVAL_UPDATE_SUCCESS";
} else{
dec_info->dec_log = "DROP_FRAME_INTERVAL_UPDATE_FAIL, Error while setting drop-frame-interval property";
break;
case SKIP_FRAMES:
dec_info->status =
dec_info->status !=
SKIP_FRAMES_UPDATE_FAIL ? SKIP_FRAMES_UPDATE_SUCCESS :
if ( dec_info->status == SKIP_FRAMES_UPDATE_SUCCESS ){
dec_info->dec_log = "SKIP_FRAMES_UPDATE_SUCCESS";
} else{
dec_info->dec_log = "SKIP_FRAMES_UPDATE_FAIL, Error while setting skip-frame property";
break;
dec_info->status =
dec_info->status !=
LOW_LATENCY_MODE_UPDATE_FAIL ? LOW_LATENCY_MODE_UPDATE_SUCCESS :
if ( dec_info->status == LOW_LATENCY_MODE_UPDATE_SUCCESS ){
dec_info->dec_log = "LOW_LATENCY_MODE_UPDATE_SUCCESS";
} else{
dec_info->dec_log = "LOW_LATENCY_MODE_UPDATE_FAIL, Error while setting skip-frame property";
break;
default:
break;
} else {
g_print ("Unsupported REST API version\n");
static void
s_infer_api_impl (NvDsServerInferInfo * infer_info, void *ctx)
guint sourceId = std::stoi (infer_info->stream_id);
if (infer_info->uri.find ("/api/v1/") != std::string::npos) {
infer_info->status = INFER_INTERVAL_UPDATE_FAIL;
infer_info->err_info.code = StatusInternalServerError;
infer_info->infer_log = "INFER_INTERVAL_UPDATE_FAIL, Unable to find stream id for infer property updation";
} else {
GstEvent *nvevent =
gst_nvevent_infer_interval_update ((char *) infer_info->stream_id.
c_str (), infer_info->interval);
if (!nvevent) {
infer_info->infer_log = "INFER_INTERVAL_UPDATE_FAIL, nv-infer-interval-update event creation failed";
nvevent)) {
g_print
("[WARN] nv-infer-interval-update event not pushed downstream.. !! \n");
infer_info->infer_log = "INFER_INTERVAL_UPDATE_FAIL, nv-infer-interval-update event not pushed";
} else {
infer_info->status = INFER_INTERVAL_UPDATE_SUCCESS;
infer_info->infer_log = "INFER_INTERVAL_UPDATE_SUCCESS";
infer_info->err_info.code = StatusOk;
} else {
static void
s_inferserver_api_impl (NvDsServerInferServerInfo * inferserver_info, void *ctx)
guint sourceId = std::stoi (inferserver_info->stream_id);
if (inferserver_info->uri.find ("/api/v1/") != std::string::npos) {
if (inferserver_info->inferserver_flag == INFERSERVER_INTERVAL) {
inferserver_info->status = INFERSERVER_INTERVAL_UPDATE_FAIL;
inferserver_info->err_info.code = StatusInternalServerError;
inferserver_info->inferserver_log = "INFERSERVER_INTERVAL_UPDATE_FAIL, Unable to find stream id for infer (inferserver) property updation";
} else {
GstEvent *nvevent =
gst_nvevent_infer_interval_update ((char *) inferserver_info->stream_id.
c_str (), inferserver_info->interval);
if (!nvevent) {
"INFERSERVER_INTERVAL_UPDATE_FAIL, nv-infer-interval-update event (inferserver) creation failed";
nvevent)) {
g_print
("[WARN] nv-infer-interval-update (inferserver) event not pushed downstream.. !! \n");
"INFERSERVER_INTERVAL_UPDATE_FAIL, nv-infer-interval-update event not pushed";
} else {
inferserver_info->status = INFERSERVER_INTERVAL_UPDATE_SUCCESS;
inferserver_info->inferserver_log = "INFERSERVER_INTERVAL_UPDATE_SUCCESS";
inferserver_info->err_info.code = StatusOk;
} else {
g_print("Unsupported REST API version\n");
static void
s_conv_api_impl (NvDsServerConvInfo * conv_info, void *ctx)
guint sourceId = std::stoi (conv_info->stream_id);
if (conv_info->uri.find ("/api/v1/") != std::string::npos) {
if (!set_nvuribin_conv_prop (nvmultiurisrcbin->nvmultiurisrcbinCreator,
sourceId, conv_info)) {
switch (conv_info->conv_flag) {
case SRC_CROP:
g_print ("[WARN] source-crop update failed .. !! \n");
conv_info->conv_log = "SRC_CROP_UPDATE_FAIL, source-crop update failed";
conv_info->status = SRC_CROP_UPDATE_FAIL;
conv_info->err_info.code = StatusInternalServerError;
break;
case DEST_CROP:
conv_info->conv_log = "DEST_CROP_UPDATE_FAIL, dest-crop update failed";
conv_info->status = DEST_CROP_UPDATE_FAIL;
break;
case FLIP_METHOD:
g_print ("[WARN] flip-method update failed .. !! \n");
conv_info->conv_log = "FLIP_METHOD_UPDATE_FAIL, flip-method update failed";
conv_info->status = FLIP_METHOD_UPDATE_FAIL;
break;
case INTERPOLATION_METHOD:
g_print ("[WARN] interpolation-method update failed .. !! \n");
conv_info->conv_log = "INTERPOLATION_METHOD_UPDATE_FAIL, interpolation-method update failed";
conv_info->status = INTERPOLATION_METHOD_UPDATE_FAIL;
break;
default:
break;
} else {
case SRC_CROP:
conv_info->status =
conv_info->status !=
SRC_CROP_UPDATE_FAIL ? SRC_CROP_UPDATE_SUCCESS :
if ( conv_info->status == SRC_CROP_UPDATE_SUCCESS ){
conv_info->err_info.code = StatusOk;
conv_info->conv_log = "SRC_CROP_UPDATE_SUCCESS";
} else{
conv_info->conv_log = "SRC_CROP_UPDATE_FAIL, Error while setting src-crop property";
break;
case DEST_CROP:
conv_info->status =
DEST_CROP_UPDATE_FAIL ? DEST_CROP_UPDATE_SUCCESS :
if ( conv_info->status == DEST_CROP_UPDATE_SUCCESS ){
conv_info->conv_log = "DEST_CROP_UPDATE_SUCCESS";
} else{
conv_info->conv_log = "DEST_CROP_UPDATE_FAIL, Error while setting dest-crop property";
break;
case FLIP_METHOD:
conv_info->status =
FLIP_METHOD_UPDATE_FAIL ? FLIP_METHOD_UPDATE_SUCCESS :
if ( conv_info->status == FLIP_METHOD_UPDATE_SUCCESS ){
conv_info->conv_log = "FLIP_METHOD_UPDATE_SUCCESS";
} else{
conv_info->conv_log = "FLIP_METHOD_UPDATE_FAIL, Error while setting flip-method property";
break;
conv_info->status =
INTERPOLATION_METHOD_UPDATE_FAIL ?
INTERPOLATION_METHOD_UPDATE_SUCCESS :
if ( conv_info->status == INTERPOLATION_METHOD_UPDATE_SUCCESS ){
conv_info->conv_log = "INTERPOLATION_METHOD_UPDATE_SUCCESS";
} else{
conv_info->conv_log = "INTERPOLATION_METHOD_UPDATE_FAIL, Error while setting interpolation-method property";
break;
default:
break;
} else {
static void
s_mux_api_impl (NvDsServerMuxInfo * mux_info, void *ctx)
if (mux_info->uri.find ("/api/v1/") != std::string::npos) {
if (!set_nvuribin_mux_prop (nvmultiurisrcbin->nvmultiurisrcbinCreator,
mux_info)) {
switch (mux_info->mux_flag) {
case BATCHED_PUSH_TIMEOUT:
g_print ("[WARN] batched-push-timeout update failed .. !! \n");
mux_info->mux_log = "BATCHED_PUSH_TIMEOUT_UPDATE_FAIL, batched-push-timeout value not updated";
mux_info->status = BATCHED_PUSH_TIMEOUT_UPDATE_FAIL;
mux_info->err_info.code = StatusInternalServerError;
break;
case MAX_LATENCY:
g_print ("[WARN] max-latency update failed .. !! \n");
mux_info->mux_log = "MAX_LATENCY_UPDATE_FAIL, MAX_LATENCY_UPDATE_FAIL, max-latency value not updated";
mux_info->status = MAX_LATENCY_UPDATE_FAIL;
break;
default:
break;
} else {
mux_info->status =
mux_info->status !=
BATCHED_PUSH_TIMEOUT_UPDATE_FAIL ?
BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS :
if ( mux_info->status == BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS ){
mux_info->err_info.code = StatusOk;
mux_info->mux_log = "BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS";
} else{
mux_info->mux_log = "BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS, Error while setting batched-push-timeout property";
break;
case MAX_LATENCY:
mux_info->status =
mux_info->status !=
MAX_LATENCY_UPDATE_FAIL ? MAX_LATENCY_UPDATE_SUCCESS :
if ( mux_info->status == MAX_LATENCY_UPDATE_SUCCESS ){
mux_info->mux_log = "MAX_LATENCY_UPDATE_SUCCESS";
} else{
mux_info->mux_log = "MAX_LATENCY_UPDATE_FAIL, Error while setting max-latency property";
break;
default:
break;
} else {
static void
s_enc_api_impl (NvDsServerEncInfo * enc_info, void *ctx)
guint sourceId = std::stoi (enc_info->stream_id);
GstEvent *nvevent = NULL;
if (enc_info->uri.find ("/api/v1/") != std::string::npos) {
switch (enc_info->enc_flag) {
case BITRATE:
enc_info->enc_log = "BITRATE_UPDATE_FAIL, Not able to find source id";
enc_info->status = BITRATE_UPDATE_FAIL;
enc_info->err_info.code = StatusInternalServerError;
break;
case FORCE_IDR:
enc_info->enc_log = "FORCE_IDR_UPDATE_FAIL, Not able to find source id";
enc_info->status = FORCE_IDR_UPDATE_FAIL;
break;
case FORCE_INTRA:
enc_info->enc_log = "FORCE_INTRA_UPDATE_FAIL, Not able to find source id";
enc_info->status = FORCE_INTRA_UPDATE_FAIL;
break;
case IFRAME_INTERVAL:
enc_info->enc_log = "IFRAME_INTERVAL_UPDATE_FAIL, Not able to find source id";
enc_info->status = IFRAME_INTERVAL_UPDATE_FAIL;
break;
default:
break;
} else {
case BITRATE:
nvevent =
gst_nvevent_enc_bitrate_update ((char *) enc_info->stream_id.
c_str (), enc_info->bitrate);
nvevent)) {
g_print
("[WARN] nv-enc-bitrate-update event not pushed downstream.bitrate update failed on encoder.. !! \n");
enc_info->enc_log =
!nvevent ? "BITRATE_UPDATE_FAIL, nv-enc-bitrate-update event creation failed" :
"BITRATE_UPDATE_FAIL, nv-enc-bitrate-update event not pushed";
} else {
enc_info->status = BITRATE_UPDATE_SUCCESS;
enc_info->err_info.code = StatusOk;
enc_info->enc_log = "BITRATE_UPDATE_SUCCESS";
break;
case FORCE_IDR:
nvevent =
gst_nvevent_enc_force_idr ((char *) enc_info->stream_id.c_str (),
enc_info->force_idr);
nvevent)) {
g_print
("[WARN] nv-enc-force-idr event not pushed downstream.force IDR frame failed on encoder .. !! \n");
enc_info->enc_log =
!nvevent ? "FORCE_IDR_UPDATE_FAIL, nv-enc-force-idr event creation failed" :
"FORCE_IDR_UPDATE_FAIL, nv-enc-force-idr event not pushed";
} else {
enc_info->status = FORCE_IDR_UPDATE_SUCCESS;
enc_info->enc_log = "FORCE_IDR_UPDATE_SUCCESS";
break;
case FORCE_INTRA:
nvevent =
gst_nvevent_enc_force_intra ((char *) enc_info->stream_id.c_str (),
enc_info->force_intra);
nvevent)) {
g_print
("[WARN] nv-enc-force-intra event not pushed downstream.force intra frame failed on encoder .. !! \n");
enc_info->enc_log =
!nvevent ? "FORCE_INTRA_UPDATE_FAIL, nv-enc-force-intra event creation failed" :
"FORCE_INTRA_UPDATE_FAIL, nv-enc-force-intra event not pushed";
} else {
enc_info->status = FORCE_INTRA_UPDATE_SUCCESS;
enc_info->enc_log = "FORCE_INTRA_UPDATE_SUCCESS";
break;
nvevent =
gst_nvevent_enc_iframeinterval_update ((char *) enc_info->stream_id.
c_str (), enc_info->iframeinterval);
nvevent)) {
g_print
("[WARN] nv-enc-iframeinterval-update event not pushed downstream.iframe interval update failed on encoder .. !! \n");
enc_info->enc_log =
!nvevent ? "IFRAME_INTERVAL_UPDATE_FAIL, nv-enc-iframeinterval-update event creation failed" :
"IFRAME_INTERVAL_UPDATE_FAIL, nv-enc-iframeinterval-update event not pushed";
} else {
enc_info->status = IFRAME_INTERVAL_UPDATE_SUCCESS;
enc_info->enc_log = "IFRAME_INTERVAL_UPDATE_SUCCESS";
break;
default:
break;
} else {
static void
s_osd_api_impl (NvDsServerOsdInfo * osd_info, void *ctx)
guint sourceId = std::stoi (osd_info->stream_id);
if (osd_info->uri.find ("/api/v1/") != std::string::npos) {
if (osd_info->osd_flag == PROCESS_MODE) {
osd_info->status = PROCESS_MODE_UPDATE_FAIL;
osd_info->err_info.code = StatusInternalServerError;
osd_info->osd_log = "PROCESS_MODE_UPDATE_FAIL, Unable to find stream id for osd property updation";
} else {
GstEvent *nvevent =
gst_nvevent_osd_process_mode_update ((char *) osd_info->stream_id.
c_str (), osd_info->process_mode);
if (!nvevent) {
osd_info->osd_log = "PROCESS_MODE_UPDATE_FAIL, nv-osd-process-mode-update event creation failed";
nvevent)) {
g_print
("[WARN] nv-osd-process-mode-update event not pushed downstream.. !! \n");
osd_info->osd_log = "PROCESS_MODE_UPDATE_FAIL, nv-osd-process-mode-update event not pushed";
} else {
osd_info->status = PROCESS_MODE_UPDATE_SUCCESS;
osd_info->err_info.code = StatusOk;
osd_info->osd_log = "PROCESS_MODE_UPDATE_SUCCESS";
} else {
static void
s_appinstance_api_impl (NvDsServerAppInstanceInfo * appinstance_info, void *ctx)
if (appinstance_info->uri.find ("/api/v1/") != std::string::npos) {
if (!s_force_eos_handle (nvmultiurisrcbin->nvmultiurisrcbinCreator,
appinstance_info)) {
if (appinstance_info->appinstance_flag == QUIT_APP) {
appinstance_info->app_log =
"QUIT_FAIL, Unable to handle force-pipeline-eos nvmultiurisrcbin";
appinstance_info->status = QUIT_FAIL;
appinstance_info->err_info.code = StatusInternalServerError;
else{
appinstance_info->status = QUIT_SUCCESS;
appinstance_info->err_info.code = StatusOk;
appinstance_info->app_log = "QUIT_SUCCESS";
} else {
void free_sensor_info(gpointer data) {
NvDsSensorInfo* sensorInfo = (NvDsSensorInfo*)data;
if (sensorInfo) {
g_free((char*)sensorInfo->sensor_name);
g_free((char*)sensorInfo->uri);
g_free(sensorInfo);
static void
s_get_request_api_impl (NvDsServerGetRequestInfo * get_request_info, void *ctx)
if (get_request_info->uri.find ("/api/v1/") != std::string::npos) {
GList *stream_info_list = NULL;
if (gst_nvmultiurisrcbincreator_get_source_info_list (
nvmultiurisrcbin->nvmultiurisrcbinCreator, &stream_info_list)) {
// Create a JSON object to store the stream information
Json::Value root;
root["stream-count"] = g_list_length(stream_info_list);
// Create a JSON array to store stream info
Json::Value streamInfo(Json::arrayValue);
if (get_request_info->get_request_flag == GET_LIVE_STREAM_INFO) {
get_request_info->status = GET_LIVE_STREAM_INFO_SUCCESS;
get_request_info->err_info.code = StatusOk;
get_request_info->get_request_log = "GET_LIVE_STREAM_INFO_SUCCESS";
// Log information from the retrieved list
for (GList *temp = stream_info_list; temp; temp = g_list_next (temp)) {
NvDsSensorInfo *sensor_info = (NvDsSensorInfo *) temp->data;
//Create Json stream info objects for each active stream
Json::Value stream;
if (sensor_info->sensor_id)
stream["camera_id"] = std::string(sensor_info->sensor_id);
else
stream["camera_id"] = std::string("");
if (sensor_info->sensor_name)
stream["camera_name"] = std::string(sensor_info->sensor_name);
else
stream["camera_name"] = std::string("");
stream["source_id"] = sensor_info->source_id;
if (sensor_info->uri)
stream["camera_url"] = std::string(sensor_info->uri);
else
stream["camera_url"] = std::string("");
//Add the stream info objects into stream info JSON array
streamInfo.append(stream);
// Add the stream info JSON array to the root object
root["stream-info"] = streamInfo;
get_request_info->stream_info = root;
} else {
get_request_info->status = GET_LIVE_STREAM_INFO_FAIL;
get_request_info->err_info.code = StatusInternalServerError;
get_request_info->get_request_log = "Unable to fetch the live stream data";
// Free the allocated memory when it's no longer needed
g_list_free_full (stream_info_list, (GDestroyNotify)free_sensor_info);
static void
NvDsServerCallbacks server_cb = { };
server_cb.stream_cb =
[nvmultiurisrcbin] (NvDsServerStreamInfo * stream_info, void *ctx) {
s_stream_api_impl (stream_info, (void *) nvmultiurisrcbin);
server_cb.roi_cb =[nvmultiurisrcbin] (NvDsServerRoiInfo * roi_info, void *ctx) {
s_roi_api_impl (roi_info, (void *) nvmultiurisrcbin);
server_cb.dec_cb =[nvmultiurisrcbin] (NvDsServerDecInfo * dec_info, void *ctx) {
s_dec_api_impl (dec_info, (void *) nvmultiurisrcbin);
server_cb.infer_cb =[nvmultiurisrcbin] (NvDsServerInferInfo * infer_info, void *ctx) {
s_infer_api_impl (infer_info, (void *) nvmultiurisrcbin);
server_cb.inferserver_cb =
[nvmultiurisrcbin] (NvDsServerInferServerInfo * inferserver_info, void *ctx) {
s_inferserver_api_impl (inferserver_info, (void *) nvmultiurisrcbin);
server_cb.conv_cb =[nvmultiurisrcbin] (NvDsServerConvInfo * conv_info, void *ctx) {
s_conv_api_impl (conv_info, (void *) nvmultiurisrcbin);
server_cb.enc_cb =[nvmultiurisrcbin] (NvDsServerEncInfo * enc_info, void *ctx) {
s_enc_api_impl (enc_info, (void *) nvmultiurisrcbin);
server_cb.mux_cb =[nvmultiurisrcbin] (NvDsServerMuxInfo * mux_info, void *ctx) {
s_mux_api_impl (mux_info, (void *) nvmultiurisrcbin);
server_cb.osd_cb =[nvmultiurisrcbin] (NvDsServerOsdInfo * osd_info, void *ctx) {
s_osd_api_impl (osd_info, (void *) nvmultiurisrcbin);
server_cb.appinstance_cb =
[nvmultiurisrcbin] (NvDsServerAppInstanceInfo * appinstance_info, void *ctx) {
s_appinstance_api_impl (appinstance_info, (void *) nvmultiurisrcbin);
server_cb.get_request_cb =
[nvmultiurisrcbin] (NvDsServerGetRequestInfo * get_request_info, void *ctx) {
s_get_request_api_impl (get_request_info, (void *) nvmultiurisrcbin);
NvDsServerConfig server_conf = { };
server_conf.ip = std::string (nvmultiurisrcbin->httpIp);
server_conf.port = std::string (nvmultiurisrcbin->httpPort);
(void *) nvds_rest_server_start (&server_conf, &server_cb);
#ifdef ENABLE_GST_NVMULTIURISRCBIN_UNIT_TESTS
#ifndef PACKAGE
#define PACKAGE "nvdsbins"
#endif
#define VERSION "1.0"
#define LICENSE "MIT"
#define DESCRIPTION "NVIDIA Multiurisrcbin"
#define BINARY_PACKAGE "NVIDIA DeepStream Bins"
#define URL "http://nvidia.com/"
extern "C" gboolean
plugin_init_2 (GstPlugin * plugin)
if (!gst_element_register (plugin, "nvmultiurisrcbin", GST_RANK_PRIMARY,
GST_TYPE_DS_NVMULTIURISRC_BIN))
return FALSE;
return TRUE;
extern "C" gboolean gGstNvMultiUriSrcBinStaticInit ();
gboolean
return gst_plugin_register_static (GST_VERSION_MAJOR, GST_VERSION_MINOR,
"nvdsgst_deepstream_bins2",
DESCRIPTION, plugin_init_2, "7.0", LICENSE, BINARY_PACKAGE, PACKAGE,
URL);
#endif
For reference:
The REST ROI update handler and main logic for dynamic addition is implemented in:
/deepstream/gst-plugins/gst-nvmultiurisrcbin/gstdsnvmultiurisrcbin.cpp -
The code for counting objects crossing the lines is in: occupancy-analytics/deepstream/configs/deepstream_nvdsanalytics_meta.cpp
What changes should I make to fully integrate both dynamic drawing and counting of ROIs on the OSD, in accordance with DeepStream’s nvdsanalytics config and methods?
