DeepStream SDK: How to use Custom Multi-task (Depthmap, Semantics, Detection) tensorrt model for inference in Python?
• Hardware Platform (Jetson / GPU) dGPU (Tesla T4)
• DeepStream Version 6.1.1
• TensorRT Version 8.4.1.5
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) Question
I have a pre-trained Multi-task(Depthmap, Semantics, Detection) model in ONNX and TensorRT .engine format that can be loaded in a python script for inference.
Input: Cropped, resized fisheye image
Output: Depthmap, Semantic segmentation, Object Detection
From the documentation, it seems like I need to use Preprocessed Tensor Input mode in Gst-nvinfer.
But is there any reference document on how to use tensorrt engine directly in Deepstream SDK using Python bindings? Any suggestions would be appreciated.
The nvinfer configuration has nothing to do with python. Even with python app deepstream_python_apps/apps/deepstream-test1 at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com), the model is configurated with the nvinfer configuration file deepstream_python_apps/dstest1_pgie_config.txt at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
For the engine file, you can set “model-engine-file” parameter Gst-nvinfer — DeepStream documentation in the configuration file. Just as in this sample: deepstream_python_apps/dstest1_pgie_config.txt at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
