In the deepstream-3d-action-recognition, the config file specifies the channel-scale-factors, channel-mean-offsets, stride, and subsample. However, it does not specify anything related to standard deviation. We need the standard deviation in order to normalize the pixel values. How can I set the standard deviation in the file config_preprocess_3d_custom.txt?
• DeepStream Version
• TensorRT Version
Currently gst-nvinfer pre-processing does not support
standard deviation. Gst-nvinfer — DeepStream 6.0.1 Release documentation
You may implement with nvdspreprocess by yourself.Gst-nvdspreprocess (Alpha) — DeepStream 6.0.1 Release documentation
They are all open source.
