DeepStream + TAO tookit Facenet - App run failed
I try to run command deepstream-app -c myConfig.txt
It return this error information
0:00:01.477579254 16980     0x236a4ad0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: [TRT]: 1: [stdArchiveReader.cpp::StdArchiveReader::34] Error Code 1: Serialization (Serialization assertion safeVersionRead == safeSerializationVersion failed.Version tag does not match. Note: Current Version: 43, Serialized Engine Version: 96)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::76] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: Deserialize engine failed from file: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/./myFaceNet.engine
0:00:02.463464174 16980     0x236a4ad0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/./myFaceNet.engine failed
0:00:02.463599009 16980     0x236a4ad0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/./myFaceNet.engine failed, try rebuild
0:00:02.463631934 16980     0x236a4ad0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:02.464024823 16980     0x236a4ad0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:02.464077682 16980     0x236a4ad0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:02.464102256 16980     0x236a4ad0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:02.464145100 16980     0x236a4ad0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:02.464164970 16980     0x236a4ad0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/face_config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:658>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
Moving this topic from DS forum into TAO forum.
It should result from different tensorrt version. The device you run inference has a different trt version from where you generate trt engine.
You can comment out “model-engine-file” and let deepstream generate trt engine again.
thanks it can work
