• Hardware Platform (Jetson / GPU) GeForce GTX 1050Ti
• DeepStream Version: 5.0.1
• TensorRT Version: 7.0.0
• NVIDIA GPU Driver Version (valid for GPU only): 450.80.02
• Issue Type( questions, new requirements, bugs) bugs
I have DeepStream 5.0.1 installed on host machine with Ubuntu 18.04 OS. I can run the test5 app with EglSink type and see the output on screen. But when I tried for MsgConvBroker sink, it gives me below errors. I have created local dockers which has link as localhost:5000/desktop_ds_test5:latest and added same in Azure portal for respective device’s module settings. But when I run the test5 app with azure config, I get below errors. I have nvmsgbroker and iotedge libs in place. I have checked the IotEdge /etc/iotegde/config.yaml is also properly formatted.
(deepstream-test5-app:19793): GLib-CRITICAL **: 16:18:26.857: g_strrstr: assertion 'haystack != NULL' failed
Error: Time:Thu Oct 29 16:18:26 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:retrieve_edge_environment_variabes Line:177 Environment IOTEDGE_AUTHSCHEME not set
Error: Time:Thu Oct 29 16:18:26 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:IoTHubClientCore_LL_CreateFromEnvironment Line:1186 retrieve_edge_environment_variabes failed
Error: Time:Thu Oct 29 16:18:26 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core.c Func:create_iothub_instance Line:924 Failure creating iothub handle
ERROR: iotHubModuleClientHandle is NULL! connect failed
** ERROR: <main:1451>: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink2: Could not configure supporting library.
Debug info: gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
unable to connect to broker library
ERROR from sink_sub_bin_sink2: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
Failed to start
App run failed
nvmsgbroker lib:
archana@archana-H310M-DS2:/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream$ ls
libgstnvvideo4linux2.so libnvdsgst_dsanalytics.so libnvdsgst_inferserver.so libnvdsgst_msgbroker.so libnvdsgst_multistreamtiler.so libnvdsgst_osd.so
libgstnvvideoconvert.so libnvdsgst_dsexample.so libnvdsgst_infer.so libnvdsgst_msgconv.so libnvdsgst_of.so libnvdsgst_segvisual.so
libnvdsgst_dewarper.so libnvdsgst_eglglessink.so libnvdsgst_jpegdec.so libnvdsgst_multistream.so libnvdsgst_ofvisual.so libnvdsgst_tracker.so
IoTEdge libs:
archana@archana-H310M-DS2:/opt/nvidia/deepstream/deepstream-5.0/lib$ ls
gst-plugins libnvds_amqp_proto.so libnvds_dsanalytics.so libnvdsinfer_custom_impl_Yolo.so libnvds_logger.so libnvds_nvtxhelper.so libnvvpi.so.0
libcuvidv4l2.so libnvds_azure_edge_proto.so libnvdsgst_bufferpool.so libnvds_infercustomparser.so libnvds_meta.so libnvds_opticalflow_dgpu.so libnvvpi.so.0.3.0
libiothub_client.so libnvds_azure_proto.so libnvdsgst_helper.so libnvds_infer_server.so libnvds_mot_iou.so libnvds_osd.so libv4l
libiothub_client.so.1 libnvds_batch_jpegenc.so libnvdsgst_meta.so libnvds_infer.so libnvds_mot_klt.so libnvds_tracker.so pkg-config
libnvbuf_fdmap.so libnvdsbufferpool.so libnvdsgst_smartrecord.so libnvds_inferutils.so libnvds_msgbroker.so libnvds_utils.so pyds.so
libnvbufsurface.so libnvds_csvparser.so libnvdsinfer_custom_impl_fasterRCNN.so libnvds_kafka_proto.so libnvds_msgconv.so libnvv4l2.so setup.py
libnvbufsurftransform.so libnvds_dewarper.so libnvdsinfer_custom_impl_ssd.so libnvds_lljpegdec.so libnvds_nvdcf.so libnvv4lconvert.so
Here is the output from sudo iotedge check
Configuration checks
√ config.yaml is well-formed - OK
√ config.yaml has well-formed connection string - OK
√ container engine is installed and functional - OK
√ config.yaml has correct hostname - OK
√ config.yaml has correct URIs for daemon mgmt endpoint - OK
√ latest security daemon - OK
√ host time is close to real time - OK
√ container time is close to host time - OK
‼ DNS server - Warning
Container engine is not configured with DNS server setting, which may impact connectivity to IoT Hub.
Please see https://aka.ms/iotedge-prod-checklist-dns for best practices.
You can ignore this warning if you are setting DNS server per module in the Edge deployment.
‼ production readiness: certificates - Warning
The Edge device is using self-signed automatically-generated development certificates.
They will expire in 72 days (at 2021-01-10 10:48:43 UTC) causing module-to-module and downstream device communication to fail on an active deployment.
After the certs have expired, restarting the IoT Edge daemon will trigger it to generate new development certs.
Please consider using production certificates instead. See https://aka.ms/iotedge-prod-checklist-certs for best practices.
‼ production readiness: container engine - Warning
Device is not using a production-supported container engine (moby-engine).
Please see https://aka.ms/iotedge-prod-checklist-moby for details.
‼ production readiness: logs policy - Warning
Container engine is not configured to rotate module logs which may cause it run out of disk space.
Please see https://aka.ms/iotedge-prod-checklist-logs for best practices.
You can ignore this warning if you are setting log policy per module in the Edge deployment.
‼ production readiness: Edge Agent's storage directory is persisted on the host filesystem - Warning
The edgeAgent module is not configured to persist its /tmp/edgeAgent directory on the host filesystem.
Data might be lost if the module is deleted or updated.
Please see https://aka.ms/iotedge-storage-host for best practices.
‼ production readiness: Edge Hub's storage directory is persisted on the host filesystem - Warning
The edgeHub module is not configured to persist its /tmp/edgeHub directory on the host filesystem.
Connectivity checks
√ host can connect to and perform TLS handshake with IoT Hub AMQP port - OK
√ host can connect to and perform TLS handshake with IoT Hub HTTPS / WebSockets port - OK
√ host can connect to and perform TLS handshake with IoT Hub MQTT port - OK
√ container on the default network can connect to IoT Hub AMQP port - OK
√ container on the default network can connect to IoT Hub HTTPS / WebSockets port - OK
√ container on the default network can connect to IoT Hub MQTT port - OK
√ container on the IoT Edge module network can connect to IoT Hub AMQP port - OK
√ container on the IoT Edge module network can connect to IoT Hub HTTPS / WebSockets port - OK
√ container on the IoT Edge module network can connect to IoT Hub MQTT port - OK
17 check(s) succeeded.
6 check(s) raised warnings. Re-run with --verbose for more details.
