I didnt get as far as to torch and torchvision. I still get the error of cuda.
Running below does the trick of fixing cuda error. Seems like SDK Manager does not set a library path to the correct cuda. Below installs cuda 12 something and then removes it.
pip3 install cuda-python
pip3 uninstall cuda-python
I get all sorts of Warnings and I dont know what it does with the model. When running the script it starts shortly after:
This was all I captured:
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Is it Integrated GPU? : 1
Creating nv3dsink
Playing file /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Opening in BLOCKING MODE
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine open error
0:00:05.319049995 6922 0xaaab09debe90 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2083> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine failed
0:00:05.597416529 6922 0xaaab09debe90 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2188> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine failed, try rebuild
0:00:05.597470891 6922 0xaaab09debe90 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2109> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
WARNING: [TRT]: Missing scale and zero-point for tensor output_bbox/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_1b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_2b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_3b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4a_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_2/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_2/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_2/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_shortcut/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_conv_shortcut/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor block_4b_bn_shortcut/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor output_bbox/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor output_cov/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor output_cov/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine opened error
0:01:50.188480074 3964 0xaaab04e27e90 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2136> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:01:50.532145996 3964 0xaaab04e27e90 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Frame Number=0 Number of Objects=14 Vehicle_count=9 Person_count=5
Frame Number=1 Number of Objects=15 Vehicle_count=9 Person_count=6
