• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.5
• TensorRT Version 8.2.1
error when run deepstream_test_1.py
after complete Deepstream 6.0.1 installation
and successful to run demo
deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
then move to Python bindings installation
completed to do:
Dependencies installation
sudo apt install -y git python-dev python3 python3-pip python3.6-dev python3.8-dev cmake g++ build-essential libglib2.0-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev librdkafka1=0.11.3-1build1
sudo apt install -y libgstrtspserver-1.0-0 gstreamer1.0-rtsp libgirepository1.0-dev gobject-introspection gir1.2-gst-rtsp-server-1.0
sudo apt install python-gi-devexport GST_LIBS=“-lgstreamer-1.0 -lgobject-2.0 -lglib-2.0"export GST_CFLAGS=”-pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
Gst-python installation installation
git clone GitHub - GStreamer/gst-python: GStreamer Python binding overrides (complementing the bindings provided by python-gi). This module has been merged into the main GStreamer repo for further development.
**./autogen.sh PYTHON=python3./**configure PYTHON=python3
make && sudo make install
Python bindings installation & sample applications download
git clone** GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications
Downloads and install
so final, i try to run this command
python3** deepstream_test_1.py ../../../../samples/streams/sample_qHD.h264
the error is
“jetson@waveshare:/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-test1$ python3 deepstream_test_1.py ../../../../samples/streams/sample_qHD.h264
File “deepstream_test_1.py”, line 26, in
from common.platform_info import PlatformInfo
File “../common/platform_info.py”, line 21, in
from cuda import cudart
ModuleNotFoundError: No module named ‘cuda’”
Please kindly suggest how to solve this issue.
Thank you in advance
