我尝试将自己的训练的yolov5模型部署在deepstream上,然后自己写了配置文件和运行文件,但是在运行的时候出现了下面的错误,这是怎么回事呢?
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:966 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:799 failed to build network.
0:00:01.222521731 2545 0x559067ae9e30 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:01.223474126 2545 0x559067ae9e30 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:01.223491229 2545 0x559067ae9e30 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
• DeepStream Version
• TensorRT Version
• The pipeline being used
What is your model type?
if uff type, How about your input and output bindings setting in config file?
uff-input-blob-name=
output-blob-names=
If caffee model, you need to set output-blob-names properly.
我更改了创建engine文件的方法,但是在创建engine的时候出现了如下的错误是怎么回事呢?
Number of unused weights left: 18446744073709368220
deepstream-app: yolo.cpp:410: NvDsInferStatus Yolo::buildYoloNetwork(std::vector&, nvinfer1::INetworkDefinition&): Assertion `0’ failed.
Aborted (core dumped)
Please get more debug log by gdb.
