• Hardware Platform (GPU)
**• DeepStream Version 7.0
请教一下执行这个更新脚本是否是必须的
/opt/nvidia/deepstream/deepstream-7.0/update_rtpmanager.sh
然后我执行的时候报了个错,我不知道该怎么处理了,
同时也想知道,deepstream-7.0的docker是不是已经解决这个问题了,我直接从docker里面复制出来一个替换就行了
If you use rtsp camera, it is usually necessary.
This error is usually related to the operating system and gstreamer version, please check the compatibility first.
Or use Docker
No, due to GPL, you need to patch it yourself
我的环境是ubuntu22.04.4 x86,我这边是参考deepstream7.0官方文档一步一步安装的,最后就报了这个错误,而且您这个链接我没法检查兼容性啊,因为deepstream7.0好像就没出这个环境对比这一块
The link has been moved here.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Installation.html#id9
Description of update_rtpmanager.sh
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Installation.html#id3
Also, have you changed the gcc version of your system?
The default should be gcc version 11.4.0
没有修改gcc,请问我这个改怎么处理一下呢
This error seems to be a problem with your system. I don’t know why. DS-7.0 requires Ubuntu 22.04 and GStreamer 1.20.3.
It is recommended that you use Docker or reinstall the Ubuntu 22.04.
There are same errors in docker when installing update_rtpmanager.sh。
What is your Jeptpack verion and board model ? I have tested on Jetson AGX Orin with docker. There are no similar problems.
You can open a new topic to discuss this issue.
Please also share your command line to start Docker
我用的就是ubunut22.04啊,GStreamer也是1.20.3,要不deepstream7.0也安装不上呀
I know how to reproduce the problem, I’m looking into it
Try this link
说实话我真往这块猜想了,但是还没来的及尝试
已经可以了,谢谢
