In my Dell precision T7910, kernel 4.4 both cards work well.
In my precision T7920, kernel 4.15 Telsa M40 is not in nvidia-smi outputing list.
minglei@minglei-Precision-7920-Tower:~$ sudo lshw -c display
[sudo] password for minglei:
*-display
description: VGA compatible controller
product: GP106GL [Quadro P2000]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:42 memory:a2000000-a2ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:1000(size=128) memory:c0000-dffff
*-display UNCLAIMED
description: 3D controller
product: GM200GL [Tesla M40]
physical id: 0
bus info: pci@0000:b3:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:a7000000-a7ffffff
Precision-7920-Tower:~$ lspci -k | grep -A 2 -E “(VGA|3D)”
03:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2000] (rev a1)
Subsystem: Dell Device 11b3
Kernel driver in use: nvidia
b3:00.0 3D controller: NVIDIA Corporation GM200GL [Tesla M40] (rev a1)
Subsystem: NVIDIA Corporation GM200GL [Tesla M40]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Precision-7920-Tower:~$ dmesg |grep nvidia
[ 18.095594] nvidia: loading out-of-tree module taints kernel.
[ 18.095602] nvidia: module license ‘NVIDIA’ taints kernel.
[ 18.101256] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 18.108406] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 18.108753] nvidia 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 18.108875] nvidia 0000:b3:00.0: enabling device (0100 → 0102)
[ 18.108941] nvidia: probe of 0000:b3:00.0 failed with error -1
[ 18.110475] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 384.130 Wed Mar 21 02:59:49 PDT 2018
[ 18.111278] [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
[ 18.111279] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:03:00.0 on minor 0
[ 19.069915] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 239
[ 19.782670] caller os_map_kernel_space.part.2+0x6d/0x80 [nvidia] mapping multiple BARs
[ 21.141326] caller os_map_kernel_space.part.2+0x6d/0x80 [nvidia] mapping multiple BARs
[ 21.420157] nvidia-modeset: Allocated GPU:0 (GPU-b3740e00-0d89-fd9a-9a77-396e1bc17e7a) @ PCI:0000:03:00.0
[ 1814.278799] nvidia-modeset: Freed GPU:0 (GPU-b3740e00-0d89-fd9a-9a77-396e1bc17e7a) @ PCI:0000:03:00.0
[ 1984.399010] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 1984.446293] [drm] [nvidia-drm] [GPU ID 0x00000300] Unloading driver
[ 1984.487992] nvidia-modeset: Unloading
[ 1984.527949] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 2001.630546] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 2001.631132] nvidia 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2001.731089] nvidia: probe of 0000:b3:00.0 failed with error -1
[ 2001.744559] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 235
[ 2001.747988] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 418.40.04 Fri Mar 15 00:50:21 CDT 2019
[ 2001.751461] [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
[ 2001.751464] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:03:00.0 on minor 0
[ 2001.753794] [drm] [nvidia-drm] [GPU ID 0x00000300] Unloading driver
[ 2001.792312] nvidia-modeset: Unloading
[ 2001.817120] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 2001.860391] nvidia-nvlink: Unregistered the Nvlink Core, major device number 237
[ 2016.815377] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 2016.815879] nvidia 0000:03:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2016.916337] nvidia: probe of 0000:b3:00.0 failed with error -1
[ 2016.921069] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 418.40.04 Fri Mar 15 00:50:21 CDT 2019
[ 2016.922813] [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
[ 2016.922817] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:03:00.0 on minor 0
[ 2060.506297] caller os_map_kernel_space.part.6+0x6d/0x80 [nvidia] mapping multiple BARs
nvidia-bug-report.log.gz (1020 KB)
[ 16.833153] pci 0000:b2:00.0: BAR 15: no space for [mem size 0xc00000000 64bit pref]
[ 16.833154] pci 0000:b2:00.0: BAR 15: failed to assign [mem size 0xc00000000 64bit pref]
[ 16.833156] pci 0000:b2:00.0: BAR 14: assigned [mem 0xa7000000-0xa7ffffff]
[ 16.833159] pci 0000:b3:00.0: BAR 1: no space for [mem size 0x800000000 64bit pref]
[ 16.833161] pci 0000:b3:00.0: BAR 1: failed to assign [mem size 0x800000000 64bit pref]
[ 16.833163] pci 0000:b3:00.0: BAR 3: no space for [mem size 0x02000000 64bit pref]
[ 16.833164] pci 0000:b3:00.0: BAR 3: failed to assign [mem size 0x02000000 64bit pref]
it’s a bug in newer kernels. Please check if ‘above 4G decoding’ is enabled in bios if available, otherwise, you can only try downgrading the kernel to e.g. 4.14.
I enabled the about 4G setting and degrade the kernel version to 4.4 as the same as my another workstation, the problem still exists.
nvidia-bug-report.log.gz (133 KB)
