Thanks for your reply.
I did try to run trtexec also failed to execute. Here is the output error.
&&&& RUNNING TensorRT.trtexec # ./trtexec --onnx=/home/tomo/Desktop/thinh/pose-net/densefusion_training/Conversion/dense-estimator.onnx
[11/25/2020-13:48:36] [I] === Model Options ===
[11/25/2020-13:48:36] [I] Format: ONNX
[11/25/2020-13:48:36] [I] Model: /home/tomo/Desktop/thinh/pose-net/densefusion_training/Conversion/dense-estimator.onnx
[11/25/2020-13:48:36] [I] Output:
[11/25/2020-13:48:36] [I] === Build Options ===
[11/25/2020-13:48:36] [I] Max batch: 1
[11/25/2020-13:48:36] [I] Workspace: 16 MB
[11/25/2020-13:48:36] [I] minTiming: 1
[11/25/2020-13:48:36] [I] avgTiming: 8
[11/25/2020-13:48:36] [I] Precision: FP32
[11/25/2020-13:48:36] [I] Calibration:
[11/25/2020-13:48:36] [I] Safe mode: Disabled
[11/25/2020-13:48:36] [I] Save engine:
[11/25/2020-13:48:36] [I] Load engine:
[11/25/2020-13:48:36] [I] Builder Cache: Enabled
[11/25/2020-13:48:36] [I] NVTX verbosity: 0
[11/25/2020-13:48:36] [I] Inputs format: fp32:CHW
[11/25/2020-13:48:36] [I] Outputs format: fp32:CHW
[11/25/2020-13:48:36] [I] Input build shapes: model
[11/25/2020-13:48:36] [I] Input calibration shapes: model
[11/25/2020-13:48:36] [I] === System Options ===
[11/25/2020-13:48:36] [I] Device: 0
[11/25/2020-13:48:36] [I] DLACore:
[11/25/2020-13:48:36] [I] Plugins:
[11/25/2020-13:48:36] [I] === Inference Options ===
[11/25/2020-13:48:36] [I] Batch: 1
[11/25/2020-13:48:36] [I] Input inference shapes: model
[11/25/2020-13:48:36] [I] Iterations: 10
[11/25/2020-13:48:36] [I] Duration: 3s (+ 200ms warm up)
[11/25/2020-13:48:36] [I] Sleep time: 0ms
[11/25/2020-13:48:36] [I] Streams: 1
[11/25/2020-13:48:36] [I] ExposeDMA: Disabled
[11/25/2020-13:48:36] [I] Spin-wait: Disabled
[11/25/2020-13:48:36] [I] Multithreading: Disabled
[11/25/2020-13:48:36] [I] CUDA Graph: Disabled
[11/25/2020-13:48:36] [I] Skip inference: Disabled
[11/25/2020-13:48:36] [I] Inputs:
[11/25/2020-13:48:36] [I] === Reporting Options ===
[11/25/2020-13:48:36] [I] Verbose: Disabled
[11/25/2020-13:48:36] [I] Averages: 10 inferences
[11/25/2020-13:48:36] [I] Percentile: 99
[11/25/2020-13:48:36] [I] Dump output: Disabled
[11/25/2020-13:48:36] [I] Profile: Disabled
[11/25/2020-13:48:36] [I] Export timing to JSON file:
[11/25/2020-13:48:36] [I] Export output to JSON file:
[11/25/2020-13:48:36] [I] Export profile to JSON file:
Input filename: /home/tomo/Desktop/thinh/pose-net/densefusion_training/Conversion/dense-estimator.onnx
ONNX IR version: 0.0.6
Opset version: 11
Producer name: pytorch
Producer version: 1.7
Domain:
Model version: 0
Doc string:
[11/25/2020-13:48:38] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[11/25/2020-13:48:38] [I] [TRT] ModelImporter.cpp:135: No importer registered for op: GatherElements. Attempting to import as plugin.
[11/25/2020-13:48:38] [I] [TRT] builtin_op_importers.cpp:3659: Searching for plugin: GatherElements, plugin_version: 1, plugin_namespace:
[11/25/2020-13:48:38] [E] [TRT] INVALID_ARGUMENT: getPluginCreator could not find plugin GatherElements version 1
ERROR: builtin_op_importers.cpp:3661 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
[11/25/2020-13:48:38] [E] Failed to parse onnx file
[11/25/2020-13:48:38] [E] Parsing model failed
[11/25/2020-13:48:38] [E] Engine creation failed
[11/25/2020-13:48:38] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # ./trtexec --onnx=/home/tomo/Desktop/thinh/pose-net/densefusion_training/Conversion/dense-estimator.onnx
