Relevant Files
Steps To Reproduce
I downloaded the pre-trained model from Tensorflow model zoo. After that I tried running tf2onnx command:
python3 -m tf2onnx.convert --saved-model models --output tf_model_op11.onnx --opset 11
This gave an onnx file with uint8 type. So I used Onnx graph surgeon tool to change the type:
graph = gs.import_onnx(onnx.load("tf_model_op11.onnx"))
for inp in graph.inputs:
inp.dtype = np.float32
After getting the onnx file, I ran the command:
trtexec --onnx=model_op11.onnx --fp16=enable --workspace=5500 --batch=1 --saveEngine=model_op11.trt --verbose
It had dynamic input so I checked this command as well to see if I get different error
trtexec --explicitBatch --optShapesCalib=:1x1024x1024x3 --optShapes=:1x1024x1024x3 --onnx=model_op11_v2.onnx --saveEngine=model_op11.trt --shapes=\'input_tensor:0\':1x1024x1024x3 --fp16=enable --workspace=5500 --useCudaGraph=enable --exportTimes=times.json --verbose
This gave me the same error as above. The suggested solution of downgrading torch won’t work as it wasn’t involved.
[06/11/2021-05:02:47] [I] === Model Options ===
[06/11/2021-05:02:47] [I] Format: ONNX
[06/11/2021-05:02:47] [I] Model: model_op11.onnx
[06/11/2021-05:02:47] [I] Output:
[06/11/2021-05:02:47] [I] === Build Options ===
[06/11/2021-05:02:47] [I] Max batch: 1
[06/11/2021-05:02:47] [I] Workspace: 5500 MB
[06/11/2021-05:02:47] [I] minTiming: 1
[06/11/2021-05:02:47] [I] avgTiming: 8
[06/11/2021-05:02:47] [I] Precision: FP32+FP16
[06/11/2021-05:02:47] [I] Calibration:
[06/11/2021-05:02:47] [I] Safe mode: Disabled
[06/11/2021-05:02:47] [I] Save engine: model_op11.trt
[06/11/2021-05:02:47] [I] Load engine:
[06/11/2021-05:02:47] [I] Builder Cache: Enabled
[06/11/2021-05:02:47] [I] NVTX verbosity: 0
[06/11/2021-05:02:47] [I] Inputs format: fp32:CHW
[06/11/2021-05:02:47] [I] Outputs format: fp32:CHW
[06/11/2021-05:02:47] [I] Input build shapes: model
[06/11/2021-05:02:47] [I] Input calibration shapes: model
[06/11/2021-05:02:47] [I] === System Options ===
[06/11/2021-05:02:47] [I] Device: 0
[06/11/2021-05:02:47] [I] DLACore:
[06/11/2021-05:02:47] [I] Plugins:
[06/11/2021-05:02:47] [I] === Inference Options ===
[06/11/2021-05:02:47] [I] Batch: 1
[06/11/2021-05:02:47] [I] Input inference shapes: model
[06/11/2021-05:02:47] [I] Iterations: 10
[06/11/2021-05:02:47] [I] Duration: 3s (+ 200ms warm up)
[06/11/2021-05:02:47] [I] Sleep time: 0ms
[06/11/2021-05:02:47] [I] Streams: 1
[06/11/2021-05:02:47] [I] ExposeDMA: Disabled
[06/11/2021-05:02:47] [I] Spin-wait: Disabled
[06/11/2021-05:02:47] [I] Multithreading: Disabled
[06/11/2021-05:02:47] [I] CUDA Graph: Disabled
[06/11/2021-05:02:47] [I] Skip inference: Disabled
[06/11/2021-05:02:47] [I] Inputs:
[06/11/2021-05:02:47] [I] === Reporting Options ===
[06/11/2021-05:02:47] [I] Verbose: Enabled
[06/11/2021-05:02:47] [I] Averages: 10 inferences
[06/11/2021-05:02:47] [I] Percentile: 99
[06/11/2021-05:02:47] [I] Dump output: Disabled
[06/11/2021-05:02:47] [I] Profile: Disabled
[06/11/2021-05:02:47] [I] Export timing to JSON file:
[06/11/2021-05:02:47] [I] Export output to JSON file:
[06/11/2021-05:02:47] [I] Export profile to JSON file:
Input filename: model_op11.onnx
ONNX IR version: 0.0.7
Opset version: 11
Producer name:
Producer version:
Domain:
Model version: 0
Doc string:
[06/11/2021-05:02:49] [V] [TRT] ModelImporter.cpp:103: Parsing node: StatefulPartitionedCall/Preprocessor/ResizeToRange/cond [If]
[06/11/2021-05:02:49] [V] [TRT] ModelImporter.cpp:119: Searching for input: StatefulPartitionedCall/Preprocessor/ResizeToRange/Less:0
[06/11/2021-05:02:49] [V] [TRT] ModelImporter.cpp:125: StatefulPartitionedCall/Preprocessor/ResizeToRange/cond [If] inputs: [StatefulPartitionedCall/Preprocessor/ResizeToRange/Less:0 → ()],
ERROR: builtin_op_importers.cpp:1554 In function importIf:
[8] Assertion failed: cond.is_weights() && cond.weights().count() == 1 && “If condition must be a initializer!”
[06/11/2021-05:02:49] [E] Failed to parse onnx file
[06/11/2021-05:02:49] [E] Parsing model failed
[06/11/2021-05:02:49] [E] Engine creation failed
[06/11/2021-05:02:49] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # trtexec --onnx=model_op11.onnx --fp16=enable --workspace=5500 --batch=1 --saveEngine=model_op11.trt --verbose
TensorRT Version: 7.1.3-1+cuda10.2
NVIDIA GPU: NVIDIA Tegra Xavier (nvgpu)/integrated
NVIDIA Driver Version: 32.4.4 Release Build
CUDA Version: 10.2
Operating System: Ubuntu 18.04
Python Version (if applicable): 3.6.9
Tensorflow Version (if applicable): 2.4
Graphics : NVIDIA Tegra Xavier (nvgpu)/integrated
Processor : ARMv8 Processor rev 0 (v8l) × 6
onnx=1.9.0
tf2onnx=1.8.5/50049d**:
In another post, the suggestion was to downgrade pytorch version but I’m not using pytorch anywhere.
