Depth estimation with deepstream
• Hardware Platform (GPU) : GTX1660
• DeepStream Version 7.0
Hi sir
sir iam have a python deepstream pipeline for the object detection using yolov9 and thats working i need to integerate any depth estimation models like midas model as a secondary gie and i need to calculate the depth to each object detected from the yolov9 model how i can do that
iam attaching my deepstream python file
import sys
import threading
sys.path.append(‘…/’)
import os
import gi
import configparser
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import GLib, Gst
from common.platform_info import PlatformInfo
from common.bus_call import bus_call
import pyds
import numpy as np
import cv2
from os import path
PGIE_CLASS_ID_PERSON = 1
PGIE_CLASS_ID_BICYCLE = 2
PGIE_CLASS_ID_CAR = 3
MUXER_BATCH_TIMEOUT_USEC = 33000
def osd_src_pad_buffer_probe(pad,info,u_data):
frame_number=0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
    print("Unable to get GstBuffer ")
    return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
    try:
        # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
        # The casting is done by pyds.NvDsFrameMeta.cast()
        # The casting also keeps ownership of the underlying memory
        # in the C code, so the Python garbage collector will leave
        # it alone.
    except StopIteration:
        break
    #Intiallizing object counter with 0.
    obj_counter = {
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_CAR:0,
    frame_number=frame_meta.frame_num
    num_rects = frame_meta.num_obj_meta
    l_obj=frame_meta.obj_meta_list
    save_image = False
    while l_obj is not None:
        try:
            # Casting l_obj.data to pyds.NvDsObjectMeta
            obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
            break
        if obj_meta.class_id in obj_counter:
            obj_counter[obj_meta.class_id] += 1
        left = obj_meta.detector_bbox_info.org_bbox_coords.left
        top = obj_meta.detector_bbox_info.org_bbox_coords.top
        width = obj_meta.detector_bbox_info.org_bbox_coords.width
        height = obj_meta.detector_bbox_info.org_bbox_coords.height
        print(f"bbox left: {left}, top: {top}, width: {width}, height: {height}")
        if frame_number % 300 == 0:
            # Getting Image data using nvbufsurface
            # the input should be address of buffer and batch_id
            n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
            frame_copy = np.array(n_frame, copy=True, order='C')
            # convert the array into cv2 default color format
            frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
            if platform_info.is_integrated_gpu():
                # If Jetson, since the buffer is mapped to CPU for retrieval, it must also be unmapped
                pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) # The unmap call should be made after operations with the original array are complete.
        #  The original array cannot be accessed after this call.
            save_image = True
        obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.8) #0.8 is alpha (opacity)
        try:
            l_obj=l_obj.next
            break
    # Acquiring a display meta object. The memory ownership remains in
    # the C code so downstream plugins can still access it. Otherwise
    # the garbage collector will claim it when this probe function exits.
    display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
    display_meta.num_labels = 1
    py_nvosd_text_params = display_meta.text_params[0]
    # Setting display text to be shown on screen
    # Note that the pyds module allocates a buffer for the string, and the
    # memory will not be claimed by the garbage collector.
    # Reading the display_text field here will return the C address of the
    # allocated string. Use pyds.get_string() to get the string content.
    py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_CAR], obj_counter[PGIE_CLASS_ID_PERSON])
    # Now set the offsets where the string should appear
    py_nvosd_text_params.x_offset = 10
    py_nvosd_text_params.y_offset = 12
    # Font , font-color and font-size
    py_nvosd_text_params.font_params.font_name = "Serif"
    py_nvosd_text_params.font_params.font_size = 10
    # set(red, green, blue, alpha); set to White
    py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
    # Text background color
    py_nvosd_text_params.set_bg_clr = 1
    # set(red, green, blue, alpha); set to Black
    py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
    # Using pyds.get_string() to get display_text as string
    print(pyds.get_string(py_nvosd_text_params.display_text))
    pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
    if save_image:
        img_path = f"{folder_name}/frame_{frame_number}.jpg"
        print(f"Saving frame {frame_number} to {img_path}")
        cv2.imwrite(img_path, frame_copy)
    try:
        l_frame=l_frame.next
        break
return Gst.PadProbeReturn.OK
def main(args):
# Check input arguments
if len(args) < 2:
sys.stderr.write(“usage: %s \n” % args[0])
sys.exit(1)
global folder_name
folder_name = args[-1]
if path.exists(folder_name):
    sys.stderr.write("The output folder %s already exists. Please remove it first.\n" % folder_name)
    sys.exit(1)
os.mkdir(folder_name)
print("Frames will be saved in ", folder_name)
global platform_info
platform_info = PlatformInfo()
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
    sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from the file
print("Creating Source \n ")
source = Gst.ElementFactory.make("filesrc", "file-source")
if not source:
    sys.stderr.write(" Unable to create Source \n")
# Since the data format in the input file is elementary h264 stream,
# we need a h264parser
print("Creating H264Parser \n")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
if not h264parser:
    sys.stderr.write(" Unable to create h264 parser \n")
# Use nvdec_h264 for hardware accelerated decode on GPU
print("Creating Decoder \n")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
if not decoder:
    sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
    sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on decoder's output,
# behaviour of inferencing is set through config file
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
    sys.stderr.write(" Unable to create pgie \n")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
    sys.stderr.write(" Unable to create tracker \n")
sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
if not sgie1:
    sys.stderr.write(" Unable to make sgie1 \n")
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
    sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating filter1 \n ")
caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
if not filter1:
    sys.stderr.write(" Unable to get the caps filter1 \n")
filter1.set_property("caps", caps1)
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
    sys.stderr.write(" Unable to create nvosd \n")
# Finally render the osd output
    print("Creating nv3dsink \n")
    sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
    if not sink:
        sys.stderr.write(" Unable to create nv3dsink \n")
else:
    if platform_info.is_platform_aarch64():
    else:
        print("Creating EGLSink \n")
        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        sink.set_property('sync', True)
    if not sink:
        sys.stderr.write(" Unable to create egl sink \n")
print("Playing file %s " %args[1])
source.set_property('location', args[1])
if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
streammux.set_property('batch-size', 1)
pgie.set_property('config-file-path', "config_pgie_yolov9_det.txt")
sgie1.set_property('config-file-path', "dstest2_sgie1_config.txt")
 #Set properties of tracker
config = configparser.ConfigParser()
config.read('dstest2_tracker_config.txt')
config.sections()
for key in config['tracker']:
    if key == 'tracker-width' :
        tracker_width = config.getint('tracker', key)
        tracker.set_property('tracker-width', tracker_width)
    if key == 'tracker-height' :
        tracker_height = config.getint('tracker', key)
        tracker.set_property('tracker-height', tracker_height)
    if key == 'gpu-id' :
        tracker_gpu_id = config.getint('tracker', key)
        tracker.set_property('gpu_id', tracker_gpu_id)
    if key == 'll-lib-file' :
        tracker_ll_lib_file = config.get('tracker', key)
        tracker.set_property('ll-lib-file', tracker_ll_lib_file)
    if key == 'll-config-file' :
        tracker_ll_config_file = config.get('tracker', key)
        tracker.set_property('ll-config-file', tracker_ll_config_file)
if not platform_info.is_integrated_gpu():
    # Use CUDA unified memory in the pipeline so frames
    # can be easily accessed on CPU in Python.
    mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    streammux.set_property("nvbuf-memory-type", mem_type)
    nvvidconv.set_property("nvbuf-memory-type", mem_type)
print("Adding elements to Pipeline \n")
pipeline.add(source)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(sgie1)
pipeline.add(nvvidconv)
pipeline.add(filter1)
pipeline.add(nvosd)
pipeline.add(sink)
# we link the elements together
# file-source -> h264-parser -> nvh264-decoder ->
# nvinfer -> nvvidconv -> nvosd -> video-renderer
print("Linking elements in the Pipeline \n")
source.link(h264parser)
h264parser.link(decoder)
sinkpad = streammux.request_pad_simple("sink_0")
if not sinkpad:
    sys.stderr.write(" Unable to get the sink pad of streammux \n")
srcpad = decoder.get_static_pad("src")
if not srcpad:
    sys.stderr.write(" Unable to get source pad of decoder \n")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(tracker)
tracker.link(sgie1)
sgie1.link(nvvidconv)
nvvidconv.link(filter1)
filter1.link(nvosd)
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
osdsrcpad = nvosd.get_static_pad("src")
if not osdsrcpad:
    sys.stderr.write(" Unable to get src pad of nvosd \n")
osdsrcpad.add_probe(Gst.PadProbeType.BUFFER, osd_src_pad_buffer_probe, 0)
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
    loop.run()
except:
    pass
# cleanup
pipeline.set_state(Gst.State.NULL)
if name == ‘main’:
sys.exit(main(sys.argv))
and the config file of pgie and sgie are
config_pgie_yolov9_det.txt (661 Bytes)
dstest2_sgie1_config.txt (449 Bytes)
in sgie the mentioned midas model can be downloaded from
wget https://github.com/intel-isl/MiDaS/releases/download/v2_1/model-small.onnx
the pgie is working i want to pass main frame to sgie and using the bounding box coordinates from the pgie i want to take the mid point of that bounding box and i want to pass to sgie depth model and want to get the depth value then i want to print that in the top of bounding of pgie output frame
and i like to get the pgie and sgie output as 2 tiled display
please help me sir
Please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2 for how to configure PGIE and SGIEs.
The PGIE and SGIE should not have the same “gie-unique-id”.
Your SGIE need “operate-on-gie-id” parameter to identify
which GIE it wants to work with. Gst-nvinfer — DeepStream documentation 6.4 documentation
And please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2 for other PGIE and SGIE settings.
The “output-tensor-meta=1” should be used together with “network-type=100”, please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-infer-tensor-meta-test and deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com) for how to customize the postprocessing with tensor output.
nework-type=100
how 100 comes
in Gst-nvinfer documentation
|network-type|Type of network|Integer
0: Detector
1: Classifier
2: Segmentation
3: Instance Segmentation|network-type=1|All
Both|
is opticalflow is depth estimation
i made above change but no change iam only getting the output of pgie
gst-nvinfer is open source, please read the source code.
Please check the other parameters and your customization postprocessing by yourself.
Any resolution on this? I am curious if it is possible to run monocular depth estimation models on Deepstream?
still now only solution i found is to integrate opticalflow with other models
but still iam facing lot of errors in it iam trying to fix it
If you can figure it out please let me know. Or if maybe a mod can confirm this is do-able?
