Designing a Governance-Native AI Factory — Lessons from Human-GPU Orchestration, Regulated Inference, and AI Operations
Author: Edin Vučelj
Organization: BPM RED Academy
Context: NVIDIA Software Developer Kit Forum
Keywords: AI Factory, Governance-Native AI, Human-GPU Orchestration, Regulated Inference, AI Operations
  1. Context: From Experiments to Operations
    Over the past year, BPM RED Academy has explored a sequence of Human-GPU research initiatives across healthcare, defense, compliance, and orchestration systems. These efforts included:
    • human-centred fine-tuning of large models,
    • effort-based orchestration and credentialing,
    • governance-first inference workflows,
    • and real-time human-in-the-loop control as an architectural constraint.
    This post marks a transition point.
    Not the launch of a new model, and not another proof-of-concept — but the moment where those experiments converge into an operational AI Factory use case, designed to run under real regulatory, audit, and accountability conditions.
  2. What Has Been Proven So Far
    Across multiple forum contributions and internal deployments, several conclusions have stabilized:
    • Model performance alone is no longer the bottleneck.
    • Modern LLMs already exceed the requirements of many high-risk domains.
    • Inference, not training, is the operational risk surface.
    • Most failures in regulated environments occur at inference time, not during optimization.
    • Human-in-the-loop cannot remain a UX feature.
    • It must be enforced at the orchestration and protocol level.
    • Governance added “after the fact” does not scale.
    • It must be native to the system architecture.
    These insights were not derived from a single experiment, but from progressive layers of the same system, iterated across different domains and workloads.
  3. Why an “AI Factory” — Not an AI System
    In many discussions, AI Factory is treated as a branding term. Here, it is used strictly in an operational sense.
    An AI system typically optimizes:
    • model accuracy,
    • latency,
    • or cost per inference.
    An AI Factory, by contrast, is defined by:
    • repeatable inference pipelines,
    • governed decision boundaries,
    • audit-ready outputs,
    • and enforced human accountability.
    In other words:
    A model produces predictions.
    An AI Factory produces decisions that are allowed to exist.
    This distinction becomes critical in regulated, defense, healthcare, and financial environments
  4. Governance-Native Architecture Principles
    The BPM RED Academy AI Factory follows four non-negotiable architectural constraints:
    4.1 Governance at Inference Time
    Policies, legal thresholds, and operational rules are evaluated before outputs are accepted — not after.
    4.2 Human Authority Is Preserved by Design
    The system is advisory-first.
    No autonomous enforcement, blocking, or penalties are executed by the model.
    4.3 Deterministic Orchestration
    Inference flows are controlled through explicit orchestration logic (e.g. BPMN / DMN-style contracts), not emergent agent behavior.
    4.4 Auditability as a First-Class Output
    Every inference produces:
    • rationale,
    • referenced constraints,
    • and traceable decision context.
  5. The First BPM RED Academy AI Factory Use Case
    The upcoming use case represents the first operational deployment of this architecture.
    Scope
    High-risk, regulated decision support
    Advisory-only inference
    Human decision authority retained
    Audit-ready outputs by default
    Factory Components
    Fine-tuned LLM inference services
    Orchestration intelligence layer (Human-GPU coordination)
    Governance logic enforcing decision boundaries
    Logging and traceability pipelines suitable for review and oversight
    What Happens in Production
    Inference is computed only within predefined policy envelopes
    Non-compliant outputs are rejected or downgraded
    Human intervention is mandatory at defined checkpoints
    Responsibility remains explicitly human — always
    This is not an experimental sandbox.
    It is an operational pattern designed to scale.
  6. Why This Matters Now
    As AI systems move from experimentation into infrastructure, the industry is approaching a critical inflection point:
    The next frontier of AI is not more intelligence.
    It is enforceable responsibility at inference time
    AI Factories that cannot:
    • stop themselves,
    • explain themselves,
    • or defer to humans
    will not survive contact with real regulatory environments.
    Governance-native design is no longer optional.
  7. What Comes Next
    This post precedes:
    • the public setup of the first BPM RED Academy AI Factory use case,
    controlled pilot deployments,
    • and deeper technical disclosures around orchestration and governance patterns.
    This is not a product announcement.
    It is an invitation to the developer and research community to:
    • examine governance-native AI architectures,
    • discuss inference-time responsibility,
    • and collaborate on AI Factory design patterns suitable for regulated operations.
    Closing
    The transition from AI systems to AI Factories is already underway.
    The open question is whether governance will be added later — or designed in from the start.
    This work takes the latter path.
    — Edin Vučelj
    BPM RED ACADEMY
