• Hardware (L40s)
• Network Type (Detectnet_v2)
• TLT Version (5.3.0)
• How to reproduce the issue ?
Using the same settings as in the documentation results in an error.
coco_config {
root_directory_path: "/workspace/tao-experiments/data/coco"
image_dir_names: ["val2017", "train2017"]
annotation_files: ["annotations/instances_val2017.json", "annotations/instances_train2017.json"]
num_partitions: 2
num_shards: [32, 256]
image_directory_path: "/workspace/tao-experiments/data/coco"
tao model detectnet_v2 dataset_convert -d [coco_config] -o tfrecord
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/dataset_convert.py", line 168, in <module>
raise e
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/dataset_convert.py", line 137, in <module>
main()
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/dataset_convert.py", line 129, in main
merge_text_proto(f.read(), dataset_export_config)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 719, in Merge
return MergeLines(
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 793, in MergeLines
return parser.MergeLines(lines, message)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 818, in MergeLines
self._ParseOrMerge(lines, message)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 837, in _ParseOrMerge
self._MergeField(tokenizer, message)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 967, in _MergeField
merger(tokenizer, message, field)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 1042, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File "/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py", line 932, in _MergeField
raise tokenizer.ParseErrorPreviousToken(
google.protobuf.text_format.ParseError: 3:3 : Message type "COCOConfig" has no field named "image_dir_names".
