Spec file for yolo v3 not recognized
• Hardware (NVIDIA RTX 3080Ti)
• Network Type (Yolo v3)
• TLT Version (toolkit_version: 5.3.0)
• Training spec file
dataset_config {
data_sources: {
label_directory_path: “/workspace/tao-experiments/data/kitti/training/label_2”
image_directory_path: “/workspace/tao-experiments/data/kitti/training/image_2”
data_sources: {
include_difficult_in_training: true
target_class_mapping {
key: “car”
value: “car”
key: “pedestrian”
value: “pedestrian”
key: “cyclist”
value: “cyclist”
key: “van”
value: “car”
key: “person_sitting”
value: “pedestrian”
validation_data_sources: {
• How to reproduce the issue ?
tao model yolo_v3 dataset_convert -d /workspace/tao-experiments/yolov3/data_s
pec.txt -o /workspace/tao-experiments/yolov3/tfrecords
2024-09-01 17:22:12,719 [TAO Toolkit] [INFO] root 160: Registry: [‘nvcr.io’]
2024-09-01 17:22:12,773 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2024-09-01 17:22:12,842 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 288:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/quest/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
2024-09-01 17:22:12,842 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 301: Printing tty value True
Using TensorFlow backend.
2024-09-01 11:52:13.580923: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-09-01 11:52:13,608 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2024-09-01 11:52:14,366 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:14,388 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:14,390 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:15,254 [TAO Toolkit] [INFO] matplotlib.font_manager 1633: generated new fontManager
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:16,489 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:16,513 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-01 11:52:16,515 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v3/scripts/dataset_convert.py”, line 48, in
raise e
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v3/scripts/dataset_convert.py”, line 32, in
main(sys.argv[1:])
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/dataset_convert.py”, line 129, in main
merge_text_proto(f.read(), dataset_export_config)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 719, in Merge
return MergeLines(
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 793, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 818, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 837, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 932, in _MergeField
raise tokenizer.ParseErrorPreviousToken(
google.protobuf.text_format.ParseError: 1:1 : Message type “DatasetExportConfig” has no field named “dataset_config”.
Execution status: FAIL
2024-09-01 17:22:21,957 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 363: Stopping container.
Please refer to the latest example spec file. For example,
tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v3/specs/yolo_v3_train_resnet18_kitti.txt at main · NVIDIA/tao_tutorials · GitHub or YOLOv3 - NVIDIA Docs.
tao model yolo_v3 dataset_convert -d /workspace/tao-experiments/yolov3/data_spec.txt -o /workspace/tao-experiments/yolov3/tfrecords
2024-09-02 10:15:17,245 [TAO Toolkit] [INFO] root 160: Registry: [‘nvcr.io’]
2024-09-02 10:15:17,282 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2024-09-02 10:15:17,343 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 288:
terminal.
2024-09-02 10:15:17,343 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 301: Printing tty value True
2024-09-02 04:45:18.112747: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-09-02 04:45:18,140 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2024-09-02 04:45:18,876 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-02 04:45:18,899 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-02 04:45:18,901 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-02 04:45:19,728 [TAO Toolkit] [INFO] matplotlib.font_manager 1633: generated new fontManager
2024-09-02 04:45:20,916 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-02 04:45:20,942 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-09-02 04:45:20,943 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
raise e
main(sys.argv[1:])
return MergeLines(
google.protobuf.text_format.ParseError: 1:1 : Message type “DatasetExportConfig” has no field named “random_seed”.
2024-09-02 10:15:26,149 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 363: Stopping container.
random_seed: 42
yolov3_config {
big_anchor_shape: “[(114.94, 60.67), (159.06, 114.59), (297.59, 176.38)]”
mid_anchor_shape: “[(42.99, 31.91), (79.57, 31.75), (56.80, 56.93)]”
small_anchor_shape: “[(15.60, 13.88), (30.25, 20.25), (20.67, 49.63)]”
matching_neutral_box_iou: 0.7
arch: “resnet”
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 1.0
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-4
soft_start: 0.1
annealing: 0.5
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: “EXPERIMENT_DIR/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
dataset_config {
data_sources: {
key: “car”
value: “car”
key: “pedestrian”
value: “pedestrian”
key: “cyclist”
value: “cyclist”
key: “van”
value: “car”
value: “pedestrian”
I have used the same spec file still i am getting the same issue…
It is not the same error.
Find the reason. You are running dataset_convert.
Please use tfrecords_kitti_trainval.txt spec file. It is not the same as training spec file.
The tfrecords_kitti_trainval.txt spec file can be found in tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v3/specs at main · NVIDIA/tao_tutorials · GitHub.
More info can be found in tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v3/yolo_v3.ipynb at main · NVIDIA/tao_tutorials · GitHub.
will you help me out with coco tfrecords spec file
i am having a coco dataset. i need spec file for coco to tfrecords spec file. Is it possible to take up coco dataset for yolov3
Yes, you can refer to https://docs.nvidia.com/tao/tao-toolkit/text/cv_finetuning/tensorflow_1/object_detection/detectnet_v2.html#configuration-file-for-dataset-converter.
