Is there a way to determine programatically whether a monitor is connected to a particular GPU? In order to use Nsight on a dual-GPU machine, the client code needs to run on the headless GPU device, and I don’t know how to determine that in my program.
cudaDeviceProp deviceProp;
int dev;
if (cudaGetDeviceProperties(&deviceProp, dev)== cudaSuccess )
if( deviceProp.kernelExecTimeoutEnabled == 0 )
// this device is not timeout enabled( no monitor hooked up )
// so you can use it without worrying about the time out
cudaSetDevice(dev);
Not quite as intuitive as one might hope, but if that works then I am grateful. Thanks.
That works everywhere but Vista. I thought Nsight took care of this automatically by masking off the display GPU from CUDA enumeration.
