/dev/nvhost* documentation
This might be a dumb question. I have trouble adding local resources of TX2 to AWS Greengrass (basically a container). If I do “ls /dev/nvhost*”, the terminal prints out a lot of GPU resources. I wonder if there is a documentation explaining what they are and what they do so that I can choose the right combination of them.
Could you check this comment first?
[url]jetson nano aws greengrass - Jetson Nano - NVIDIA Developer Forums
I have used Greengrass before. I am trying to activate Kinesis Video Stream with Greengrass. This requires GPU resources from TX2. So I need some documentation about nvhost*.
To enable GPU, you will need to add the access of these device nodes:
/dev/nvhost-ctrl
/dev/nvhost-ctrl-gpu
/dev/nvhost-prof-gpu
/dev/nvmap
/dev/nvhost-gpu
/dev/nvhost-as-gpu
Check this wiki to get more information: https://elinux.org/Jetson_Zoo#Docker
Thank you for replying!
These do not seem to be enough. Maybe the issue is non-GPU-related. T_T
