Hi, there, below is a sample code that illustrates the problem I’m about describe.
When using the cublas primitives, the cuda device can’t be found during execution; the cuda error is 100.
However, when I link with the static version, the code works fine. BTW, python code also works just fine in my setup.
Compile parameter that work. If you remove the _static, it doesn’t work.
nvcc -O3 -I …/…/utils --use_fast_math cublas_amin_example.cu -lcublas_static -lcublasLt_static -lculibos -o a.out
include <stdio.h>
include <cublas_v2.h>
include <cuda_runtime.h>
using data_type = double;
define CUBLAS_CHECK(x) {int y = (x) ; printf(“%s : %d\n”, #x, y);}
define CUDA_CHECK(x) {int y = (x) ; printf(“%s : %d\n”, #x, y);}
int main(int argc, char *argv) {
cublasHandle_t cublasH = NULL;
cudaStream_t stream = NULL;
* A = | 1.0 2.0 3.0 4.0 |
double A[] = {1.0, 2.0, 3.0, 4.0};
const int incx = 1;
int result = 0.0;
data_type *d_A = NULL;
printf("A\n");
/* step 1: create cublas handle, bind a stream */
CUBLAS_CHECK(cublasCreate(&cublasH));
CUDA_CHECK(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
CUBLAS_CHECK(cublasSetStream(cublasH, stream));
/* step 2: copy data to device */
CUDA_CHECK(cudaMalloc(&d_A, sizeof(data_type) * 4));
CUDA_CHECK(cudaMemcpyAsync(d_A, A, sizeof(data_type) * 4, cudaMemcpyHostToDevice, stream));
/* step 3: compute */
CUBLAS_CHECK(cublasIdamax(cublasH, 4, d_A, incx, &result));
CUDA_CHECK(cudaStreamSynchronize(stream));
* result = 1
printf("result\n");
printf("%d\n", result);
printf("=====\n");
/* free resources */
CUDA_CHECK(cudaFree(d_A));
CUBLAS_CHECK(cublasDestroy(cublasH));
CUDA_CHECK(cudaStreamDestroy(stream));
CUDA_CHECK(cudaDeviceReset());
return EXIT_SUCCESS;
My environment:
Linux xxxx 5.15.146.1-microsoft-standard-WSL2 #1 SMP Thu Jan 11 04:09:03 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
| NVIDIA-SMI 535.120 Driver Version: 537.58 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 … On | 00000000:01:00.0 Off | N/A |
| N/A 39C P0 16W / 60W | 0MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
