When I upgraded from cuda, cuda libraries, and nvcc V11.6.55 to V11.6.124, I ran into errors with static linking. Specifically, I get many undefined references from within libcublasLt_static.a. Here is the first one:
linking test_gpu_matrix
nvcc -m64 -ccbin icpc -o …/test_gpu_matrix obfil/test_gpu_matrix.o …/gpu_hub.a …/…/hub/hub.a /home/intel/mkl/2021.4.0/lib/intel64/libmkl_intel_ilp64.a /home/intel/mkl/2021.4.0/lib/intel64/libmkl_core.a /home/intel/mkl/2021.4.0/lib/intel64/libmkl_intel_thread.a /home/intel/compiler/2021.4.0/linux/compiler/lib/intel64_lin/libiomp5.a -lpthread -lm -lcublas_static -lcublasLt_static -lculibos -lcusolver_static -lcusparse_static -lmetis_static -llapack_static -lcudart_static -lcublas_static -lcublasLt_static -lculibos -lcusolver_static -lcusparse_static -lmetis_static -llapack_static -lcudart_static /home/intel/compiler/2021.4.0/linux/compiler/lib/intel64_lin/libifcore.a
/usr/local/cuda/bin/…/targets/x86_64-linux/lib/libcublasLt_static.a(cublas_zzz_matmul_factory.cu.o): In function gemm_matmulAlgo_sass<double2, double2, double2, double2, 1049601ul, &cuBLASLt::sass::cfp64_cfp64_gemm_cfp64, &cuBLASLt::sass::cfp64_cfp64_gemm_cfp64>::~gemm_matmulAlgo_sass()': tmpxft_000069d0_00000000-6_cublas_zzz_matmul_factory.compute_86.cudafe1.cpp:(.text._ZN20gemm_matmulAlgo_sassI7double2S0_S0_S0_Lm1049601EXadL_ZN8cuBLASLt4sass22cfp64_cfp64_gemm_cfp64EEEXadL_ZNS2_22cfp64_cfp64_gemm_cfp64EEEED0Ev[_ZN20gemm_matmulAlgo_sassI7double2S0_S0_S0_Lm1049601EXadL_ZN8cuBLASLt4sass22cfp64_cfp64_gemm_cfp64EEEXadL_ZNS2_22cfp64_cfp64_gemm_cfp64EEEED5Ev]+0x6): undefined reference to operator delete(void*, unsigned long)’
Has there been some change in how to accomplish static linking? I see no mention of it in the documentation, but will admit that getting static linking working has always been challenging.
