deviceQuery freezes computer on Ubuntu 22.04
I have a freshly installed Ubuntu 22.04 system with two RTX Titans (with bridge installed), one of which is also used a display GPU. Any call to software using cuda (deviceQuery, bandwidthTest, a CuDNN example, or loading tensorflow in python) causes the system to freeze for 1-2 minutes and often the display driver to seemingly reset. Is this expected behavior? Can i avoid it? I’d like to able to just load tensorflow of course. It happens both with CUDA 12 and 11.8.
Thanks a lot!
nvidia kernel module 520.61.05
Nvlink Core is being initialized, major device number 234
Initialized nvidia-drm 0.0.0 20160202 for 0000:1a:00.0 on minor 0
Initialized nvidia-drm 0.0.0 20160202 for 0000:68:00.0 on minor 1
Loaded the UVM driver, major device number 510
some messages in dmesg around times of freeze:
[ 1466.575694] NVRM: GPU at PCI:0000:68:00: GPU-05840d2e-94e5-7d79-fa44-67c47673d015
[ 1466.575703] NVRM: GPU Board Serial Number: <removed>
[ 1466.575706] NVRM: Xid (PCI:0000:68:00): 109, pid=1391, name=Xorg, Ch 00000008, errorString CTX SWITCH TIMEOUT, Info 0x4c002
[ 1559.557808] NVRM: Xid (PCI:0000:68:00): 109, pid=1391, name=Xorg, Ch 0000000a, errorString CTX SWITCH TIMEOUT, Info 0x4c002
[ 1754.619915] NVRM: Xid (PCI:0000:68:00): 109, pid=1626, name=gnome-shell, Ch 00000010, errorString CTX SWITCH TIMEOUT, Info 0x2c004
[ 3600.075508] NVRM: Xid (PCI:0000:68:00): 109, pid=1626, name=gnome-shell, Ch 00000010, errorString CTX SWITCH TIMEOUT, Info 0x7c004
kernel:
5.19.0-38-generic #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 17 21:16:15 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
nvidia-smi output:
| NVIDIA-SMI 520.61.05    Driver Version: 520.61.05    CUDA Version: 11.8     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA TITAN RTX    On   | 00000000:1A:00.0 Off |                  N/A |
| 40%   40C    P8    36W / 280W |      5MiB / 24576MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA TITAN RTX    On   | 00000000:68:00.0  On |                  N/A |
| 41%   42C    P8    27W / 280W |    324MiB / 24576MiB |      5%      Default |
|                               |                      |                  N/A |
