CPU - AMD EPYC 7272
GPU - RTX 3080 Ti
OS - Ubuntu 20.04
I started with a clean Ubuntu 20.04 build and the system stayed awake for ~12hrs. Then I proceeded to download CUDA 11.6.1, using the deb (local) method, following the instructions at Installation Guide Linux :: CUDA Toolkit Documentation. Upon installing CUDA 11.6.1, I now see the system freezing up after about 10 minutes. If the system is power cycled, it comes back.
Is there a way to determine what is causing the system to freeze?
I attached the nvidia bug report.
Thanks,
Kevin
