My NVIDIA DGX Spark reproducibly hard-freezes under sustained GPU inference.
DGX OS 7.5.0
Kernel 6.17.0-1029-nvidia
Driver 580.173.02
EC 3.5.8; current firmware; fwupdmgr reports no updates
Original 240 W adapter verified
Display manager and internal airflow verified
GpuStress passes
PowerStress fails with MODS-020000610139: acceptable temperature limits exceeded or thermal sensor broken/miscalibrated
MiniMax-H3 864×480/5-second inference hard-freezes the complete system, without OOM, NVIDIA Xid, kernel panic, or application exception
ACPI temperature reached approximately 91–93°C
Idle temperatures were normal: GPU 47°C and hottest ACPI zone 49.8°C at approximately 4 W. During MiniMax-H3 inference at 96% GPU utilization and approximately 70–83 W, the GPU reached 84°C and the hottest ACPI/SoC zone reached 93.1°C within roughly two minutes. The system subsequently hard-froze.
I’m not sure if my experience will be helpful, but I had similar symptoms and resolved the issue by downgrading the firmware to an earlier version and locking the maximum clock speed to 2000 MHz.
However, since this doesn’t solve the root cause, I think I’ll have to send it in for an RMA if the problem occurs again.
i have been thinking about downgrading, but it is supposed to be running long-sustained sessions like this without crashing, and managing the clock speed based on its load and temp. that should be fixed.
I have basically same specs (kernel,driver…) on asus , the 91+ temps just anecdotally seems high , Im testing MiniMax-H3 so I;ll drop a quick smoke test and monitor acpi…
$ echo "=== DGX Spark (GB10) — H3 T2V render thermal report ==="
echo ""
echo "Model: MiniMax H3 T2V (NVFP4), 864×480, 16 steps, 3s clip"
echo "Render time: 101s on single DGX Spark"
echo ""
echo "Temperatures:"
echo " Idle Under load (101s) Delta"
echo "GPU (die) 45°C 58°C +13°C"
echo "ACPI (SoC) 47°C 62°C +15°C"
echo "ConnectX-7 NICs 48°C 62°C +14°C"
echo ""
echo "GPU power draw: 15.17W (under load)"
echo "GPU memory: ~24 GB (diffusion) + 15 GB (TE) + 5 GB (VAE) ≈ 44GB"
echo ""
echo "Output: 721 KB mp4, 3.0s, H.264 + AAC stereo audio (native)"
echo ""
echo "ACPI sensors report 7 thermal zones (Tdie, Tccd0, Tccd1, etc.)"
echo "All well below throttling thresholds; fan curve not aggressive enough"
echo "to recover to idle temps within 30s post-render — sustained workloads"
echo "would benefit from the PD wedge fix (see cheatsheet)."
Temperatures:
Just some info , hope it could be useful. Good luck.
The diagnostic takes approximately 30 minutes and will produce a clear PASS/FAIL result. If it reports a FAIL, that qualifies your unit for an RMA. Post the result here and we’ll authorize RMA via this thread, which you can then reference in an NVIDIA consumer support case.
Quick note: Something caught my eye after posting that I missed at first pass, if “PowerStress fails with MODS-020000610139: acceptable temperature limits exceeded or thermal sensor broken/miscalibrated” was the result of a field diagnostic output, can you please share the full output here for RMA approval?
Also, can you elaborate on “support portal unavailable”?
