190 sec ! but running other things in //
attached the .json - faster with comfuy comparing to docker !
but trellis 2> hunyan3d in terme of rendering
“10”: {
“inputs”: {
“model”: “hunyuan3d-dit-v2-mv-fp16.safetensors”,
“attention_mode”: “sdpa”,
“cublas_ops”: false
“class_type”: “Hy3DModelLoader”,
“_meta”: {
“title”: “Hy3DModelLoader”
“17”: {
“inputs”: {
“filename_prefix”: “3D/Hy3D”,
“file_format”: “glb”,
“save_file”: true,
“trimesh”: [
“203”,
0
“class_type”: “Hy3DExportMesh”,
“_meta”: {
“title”: “Hy3DExportMesh”
“28”: {
“inputs”: {
“model”: “hunyuan3d-delight-v2-0”
“class_type”: “DownloadAndLoadHy3DDelightModel”,
“_meta”: {
“title”: “(Down)Load Hy3D DelightModel”
“35”: {
“inputs”: {
“steps”: 75,
“width”: 512,
“height”: 512,
“cfg_image”: 1,
“seed”: 0,
“delight_pipe”: [
“28”,
0
“image”: [
“64”,
0
“scheduler”: [
“148”,
0
“class_type”: “Hy3DDelightImage”,
“_meta”: {
“title”: “Hy3DDelightImage”
“45”: {
“inputs”: {
“images”: [
“35”,
0
“class_type”: “PreviewImage”,
“_meta”: {
“title”: “Preview Image”
“52”: {
“inputs”: {
“width”: 512,
“height”: 512,
“interpolation”: “lanczos”,
“method”: “pad”,
“condition”: “always”,
“multiple_of”: 2,
“image”: [
“157”,
0
“class_type”: “ImageResize+”,
“_meta”: {
“title”: “🔧 Image Resize”
“55”: {
“inputs”: {
“mode”: “base”,
“use_jit”: true
“class_type”: “TransparentBGSession+”,
“_meta”: {
“title”: “🔧 InSPyReNet TransparentBG”
“56”: {
“inputs”: {
“rembg_session”: [
“55”,
0
“image”: [
“52”,
0
“class_type”: “ImageRemoveBackground+”,
“_meta”: {
“title”: “🔧 Image Remove Background”
“61”: {
“inputs”: {
“camera_azimuths”: “0, 90, 180, 270, 0, 180”,
“camera_elevations”: “0, 0, 0, 0, 90, -90”,
“view_weights”: “1, 0.1, 0.5, 0.1, 0.05, 0.05”,
“camera_distance”: 1.45,
“ortho_scale”: 1.2
“class_type”: “Hy3DCameraConfig”,
“_meta”: {
“title”: “Hy3D Camera Config”
“64”: {
“inputs”: {
“x”: 0,
“y”: 0,
“resize_source”: false,
“destination”: [
“184”,
0
“source”: [
“166”,
1
“mask”: [
“166”,
2
“class_type”: “ImageCompositeMasked”,
“_meta”: {
“title”: “ImageCompositeMasked”
“79”: {
“inputs”: {
“render_size”: 2048,
“texture_size”: 2048,
“normal_space”: “world”,
“trimesh”: [
“83”,
0
“camera_config”: [
“61”,
0
“class_type”: “Hy3DRenderMultiView”,
“_meta”: {
“title”: “Hy3D Render MultiView”
“83”: {
“inputs”: {
“trimesh”: [
“203”,
0
“class_type”: “Hy3DMeshUVWrap”,
“_meta”: {
“title”: “Hy3D Mesh UV Wrap”
“85”: {
“inputs”: {
“model”: “hunyuan3d-paint-v2-0”
“class_type”: “DownloadAndLoadHy3DPaintModel”,
“_meta”: {
“title”: “(Down)Load Hy3D PaintModel”
“88”: {
“inputs”: {
“view_size”: 512,
“steps”: 25,
“seed”: 1024,
“denoise_strength”: 1,
“pipeline”: [
“85”,
0
“ref_image”: [
“35”,
0
“normal_maps”: [
“79”,
0
“position_maps”: [
“79”,
1
“camera_config”: [
“61”,
0
“scheduler”: [
“149”,
0
“class_type”: “Hy3DSampleMultiView”,
“_meta”: {
“title”: “Hy3D Sample MultiView”
“90”: {
“inputs”: {
“images”: [
“79”,
0
“_meta”: {
“92”: {
“inputs”: {
“images”: [
“117”,
0
“renderer”: [
“79”,
2
“camera_config”: [
“61”,
0
“class_type”: “Hy3DBakeFromMultiview”,
“_meta”: {
“title”: “Hy3D Bake From Multiview”
“98”: {
“inputs”: {
“texture”: [
“104”,
0
“renderer”: [
“129”,
2
“class_type”: “Hy3DApplyTexture”,
“_meta”: {
“title”: “Hy3D Apply Texture”
“99”: {
“inputs”: {
“filename_prefix”: “3D/Hy3D_textured”,
“save_file”: true,
“trimesh”: [
“98”,
0
“_meta”: {
“104”: {
“inputs”: {
“inpaint_radius”: 3,
“inpaint_method”: “ns”,
“texture”: [
“129”,
0
“mask”: [
“129”,
1
“class_type”: “CV2InpaintTexture”,
“_meta”: {
“title”: “CV2 Inpaint Texture”
“111”: {
“inputs”: {
“images”: [
“88”,
0
“_meta”: {
“title”: “Preview Image: Multiview results”
“116”: {
“inputs”: {
“images”: [
“79”,
1
“_meta”: {
“117”: {
“inputs”: {
“width”: 2048,
“height”: 2048,
“method”: “stretch”,
“multiple_of”: 0,
“image”: [
“118”,
0
“_meta”: {
“118”: {
“inputs”: {
“upscale_model”: [
“119”,
0
“image”: [
“88”,
0
“class_type”: “ImageUpscaleWithModel”,
“_meta”: {
“title”: “Upscale Image (using Model)”
“119”: {
“inputs”: {
“model_name”: “4x_foolhardy_Remacri.pth”
“class_type”: “UpscaleModelLoader”,
“_meta”: {
“title”: “Load Upscale Model”
“125”: {
“inputs”: {
“images”: [
“92”,
0
“_meta”: {
“title”: “Preview Image: Initial baked texture”
“126”: {
“inputs”: {
“images”: [
“129”,
0
“_meta”: {
“title”: “Preview Image: vertex inpainted texture”
“127”: {
“inputs”: {
“images”: [
“104”,
0
“_meta”: {
“title”: “Preview Image: fully inpainted texture”
“129”: {
“inputs”: {
“texture”: [
“92”,
0
“mask”: [
“92”,
1
“renderer”: [
“92”,
2
“class_type”: “Hy3DMeshVerticeInpaintTexture”,
“_meta”: {
“title”: “Hy3D Mesh Vertice Inpaint Texture”
“132”: {
“inputs”: {
“value”: 0.8,
“width”: 512,
“height”: 512
“class_type”: “SolidMask”,
“_meta”: {
“title”: “SolidMask”
“133”: {
“inputs”: {
“mask”: [
“132”,
0
“class_type”: “MaskToImage”,
“_meta”: {
“title”: “Convert Mask to Image”
“138”: {
“inputs”: {
“mask”: [
“56”,
1
“class_type”: “MaskPreview+”,
“_meta”: {
“title”: “🔧 Mask Preview”
“140”: {
“inputs”: {
“box_v”: 1.01,
“octree_resolution”: 256,
“num_chunks”: 32000,
“mc_level”: 0,
“mc_algo”: “mc”,
“enable_flash_vdm”: true,
“force_offload”: true,
“vae”: [
“10”,
1
“latents”: [
“166”,
0
“class_type”: “Hy3DVAEDecode”,
“_meta”: {
“title”: “Hy3D VAE Decode”
“148”: {
“inputs”: {
“scheduler”: “Euler A”,
“sigmas”: “default”,
“pipeline”: [
“28”,
0
“class_type”: “Hy3DDiffusersSchedulerConfig”,
“_meta”: {
“title”: “Hy3D Diffusers Scheduler Config”
“149”: {
“inputs”: {
“pipeline”: [
“85”,
0
“_meta”: {
“154”: {
“inputs”: {
“model_file”: [
“99”,
0
“image”: “”
“class_type”: “Preview3D”,
“_meta”: {
“title”: “Preview 3D & Animation”
“157”: {
“inputs”: {
“image”: “Screenshot 2025-12-20 at 14.06.41.png”
“class_type”: “LoadImage”,
“_meta”: {
“title”: “Load Image: Front”
“159”: {
“inputs”: {
“image”: “Screenshot 2025-12-20 at 14.06.50.png”
“_meta”: {
“title”: “Load Image: Back”
“160”: {
“inputs”: {
“_meta”: {
“title”: “Load Image: Left”
“162”: {
“inputs”: {
“model_file”: [
“17”,
0
“image”: “”
“_meta”: {
“163”: {
“inputs”: {
“render_type”: “normal”,
“render_size”: 1024,
“camera_type”: “orth”,
“pan_x”: 0,
“pan_y”: 0,
“ortho_scale”: 1.2,
“azimuth”: 146.666748046875,
“elevation”: 0,
“bg_color”: “128, 128, 255”,
“trimesh”: [
“203”,
0
“class_type”: “Hy3DRenderSingleView”,
“_meta”: {
“title”: “Hy3D Render SingleView”
“166”: {
“inputs”: {
“guidance_scale”: 5.5,
“steps”: 30,
“seed”: 416935455784444,
“scheduler”: “FlowMatchEulerDiscreteScheduler”,
“pipeline”: [
“10”,
0
“front”: [
“195”,
0
“left”: [
“196”,
0
“right”: [
“197”,
0
“back”: [
“198”,
0
“class_type”: “Hy3DGenerateMeshMultiView”,
“_meta”: {
“title”: “Hy3DGenerateMeshMultiView”
“167”: {
“inputs”: {
“_meta”: {
“title”: “Load Image: Right”
“170”: {
“inputs”: {
“rembg_session”: [
“55”,
0
“image”: [
“171”,
0
“_meta”: {
“171”: {
“inputs”: {
“width”: 512,
“height”: 512,
“method”: “pad”,
“multiple_of”: 2,
“image”: [
“160”,
0
“_meta”: {
“172”: {
“inputs”: {
“width”: 512,
“height”: 512,
“method”: “pad”,
“multiple_of”: 2,
“image”: [
“167”,
0
“_meta”: {
“173”: {
“inputs”: {
“rembg_session”: [
“55”,
0
“image”: [
“172”,
0
“_meta”: {
“174”: {
“inputs”: {
“mask”: [
“170”,
1
“_meta”: {
“175”: {
“inputs”: {
“mask”: [
“173”,
1
“_meta”: {
“176”: {
“inputs”: {
“width”: 512,
“height”: 512,
“method”: “pad”,
“multiple_of”: 2,
“image”: [
“159”,
0
“_meta”: {
“177”: {
“inputs”: {
“rembg_session”: [
“55”,
0
“image”: [
“176”,
0
“_meta”: {
“178”: {
“inputs”: {
“mask”: [
“177”,
1
“_meta”: {
“182”: {
“inputs”: {
“images”: [
“166”,
1
“_meta”: {
“183”: {
“inputs”: {
“mask”: [
“166”,
2
“_meta”: {
“184”: {
“inputs”: {
“amount”: [
“185”,
0
“image”: [
“133”,
0
“class_type”: “RepeatImageBatch”,
“_meta”: {
“title”: “RepeatImageBatch”
“185”: {
“inputs”: {
“batch”: [
“166”,
1
“class_type”: “BatchCount+”,
“_meta”: {
“title”: “🔧 Batch Count”
“195”: {
“inputs”: {
“image”: [
“52”,
0
“alpha”: [
“202”,
0
“class_type”: “JoinImageWithAlpha”,
“_meta”: {
“title”: “Join Image with Alpha”
“196”: {
“inputs”: {
“image”: [
“171”,
0
“alpha”: [
“199”,
0
“_meta”: {
“197”: {
“inputs”: {
“image”: [
“172”,
0
“alpha”: [
“200”,
0
“_meta”: {
“198”: {
“inputs”: {
“image”: [
“176”,
0
“alpha”: [
“201”,
0
“_meta”: {
“199”: {
“inputs”: {
“mask”: [
“170”,
1
“class_type”: “InvertMask”,
“_meta”: {
“title”: “InvertMask”
“200”: {
“inputs”: {
“mask”: [
“173”,
1
“_meta”: {
“201”: {
“inputs”: {
“mask”: [
“177”,
1
“_meta”: {
“202”: {
“inputs”: {
“mask”: [
“56”,
1
“_meta”: {
“203”: {
“inputs”: {
“remove_floaters”: true,
“remove_degenerate_faces”: true,
“reduce_faces”: true,
“max_facenum”: 50000,
“smooth_normals”: false,
“trimesh”: [
“140”,
0
“class_type”: “Hy3DPostprocessMesh”,
“_meta”: {
“title”: “Hy3D Postprocess Mesh”
“207”: {
“inputs”: {},
“_meta”: {
