DGX Spark Users unable to pull from nvcr.io
I am Spark user in China.
Docker unable to pull containers from nvcr.io.
I have API token.
docker run --rm --gpus all nvcr.io/nvidia/tensorrt-llm/release:spark-single-gpu-dev nvidia-smi
Seem like it is blocked in China.
Are there any mirror sites I can use?
Mark
What is the error you get? You may need to add your user to the docker group first.
If you see an error when running docker ps then
sudo usermod -aG docker $USER
newgrp docker
Make sure to login first with
export NGC_API_KEY="<YOUR_NGC_API_KEY>"
echo "$NGC_API_KEY" | docker login nvcr.io --username '$oauthtoken' --password-stdin
I am a DGX Spark user in the United States and am also experiencing this issue. Docker is configured to run appropriately and I have been running other containers without issue.
docker login ncvr.io
Username: $oauthtoken
Password:
Error response from daemon: Get “https://ncvr.io/v2/”: dial tcp: lookup ncvr.io on 127.0.0.53:53: no such host
At first I thought that this was a name server issue, but IP address lookup for ncvr.io appears to work as expected.
nslookup nvcr.io
Server:		127.0.0.53
Address:	127.0.0.53#53
Address: 54.183.242.120
When I ping the IP address, it appears to hang, though.
ping nvcr.io
PING nvcr.io (54.183.242.120) 56(84) bytes of data.
^C
— nvcr.io ping statistics —35 packets transmitted, 0 received, 100% packet loss, time 34819ms
Any suggestions to resolve this problem would be appreciated.
Hi, I tried
export NGC_API_KEY=“<YOUR_NGC_API_KEY>”
echo “$NGC_API_KEY” | docker login nvcr.io --username ‘$oauthtoken’ --password-stdin
what I received is 403 error.
However when I use my singapore SIM card as roaming internet I can log into nvcr.io. But due to the size of the images I cannot afford to use my roaming data to download the images.
