Difference between running the inference with trtexec and tensorrt python API
Hi all,
To reproduce the NVIDIA Jetson AGX Xavier benchmarks of Tiny YOLO V3, i’ve used the sample /usr/src/tensorrt/samples/python/yolov3_onnx but i’ve got perfs between 600 and 700 FPS with this parameters link of my recent post which contains thr details of the implemntation:
Power Mode : MAXN
Input resolution : 416x416
Precision Mode : INT8 (Calibration with 1000 images and IInt8EntropyCalibrator2 interface)
batch = 8
JetPack Version : 4.5.1
TensorRT version : 7.1.3
I’ve also run this command to maximize the perfs
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Then i tried GitHub - NVIDIA-AI-IOT/jetson_benchmarks: Jetson Benchmark to reproduce the FPS of Tiny YOLO V3 and that worked properly (i got the 1000 FPS), but i noticed that this repos use the shell trtexec and not the python API tensorrt that i’am used to use by (import tensorrt as trt)
My question is what’s the difference between this two implementations ( trtexec VS tensorrt python API) when we generate/build the TensorRT engine and when we run the inference ?
Based on the data below, please set workspace to 2048Mib and inference it with batchsize=16:
We are modifying onnx_to_tensorrt.py for YOLOv3 Tiny as an example.
Will share with you later.
We reuse the calibration cache from here and the model used in jetson-benchmark.
Be able to get 1088 fps on INT8+Batchsize16+Workspace2048.
Please check following for the instructions:
$ wget https://www.dropbox.com/s/ck9e40b57rd5o14/yolov3-tiny-416.zip
$ unzip yolov3-tiny-416.zip
$ wget https://raw.githubusercontent.com/jkjung-avt/tensorrt_demos/master/yolo/calib_cache/calib_yolov3-tiny-int8-416.bin
YOLOv3_Tiny_benchmark.patch (8.7 KB)
$ /usr/src/tensorrt/bin/trtexec --onnx=yolov3-tiny-416-bs16.onnx --best --workspace=2048 --saveEngine=yolov3-tiny-416-bs16.trt --calib=calib_yolov3-tiny-int8-416.bin
$ git apply YOLOv3_Tiny_benchmark.patch
$ python3 onnx_to_tensorrt.py
Reading engine from file yolov3-tiny-416-bs16.trt
Running inference on image dog.jpg…
FPS: 1088.407443846851
[[125.69800719 217.86413197 254.43353728 296.92521182]
[475.38425396 79.1671842 194.08492385 86.92553251]] [0.80192175 0.70910078] [16 2]
Hi @AastaLLL,
Thank you for your help, i understand now what i was doing wrong !
