From deepstream-plugin project I run YOLOV2 detector network with kINT8 calibration that works OK. I delete the original calibration table file (sources/lib/calibration/yolov2-calibration.table) and fill some validation sample to data/calibration_images.txt file for the yolov2 calibration table re-generation. It encountered errors and failed to build TensorRT engine.
./sources/apps/trt-yolo/trt-yolo-app
writeCalibrationCache sources/lib/calibration/yolov2-calibration.table
trt-yolo-app: NvPluginYOLO.cu:58: virtual void nvinfer1::plugin::PReLU::configure(const nvinfer1::Dims*, int, const nvinfer1::Dims*, int, int): Assertion `mBatchDim == 1' failed.
Aborted (core dumped)
-- re-launch trt-yolo-app
Building the TensorRT Engine...
readCalibrationCache from file: sources/lib/calibration/yolov2-calibration.table
Using cached calibration table to build the engine
Building complete!
Serializing the TensorRT Engine...
Serialized plan file cached at location : sources/lib/models/yolov2-kINT8-batch1.engine
Loading TRT Engine...
Loading Complete!
The TensorRT engine was generated successfully after re-launch trt-yolo-app. But the content of calibration table is difference with original. I test kIN8 mAP for model. It show 1 or 2 percent difference very calibration table re-generation. Is it a known symptom or not?
The test env: TensorRT-4.0.1.6-cuda-9.2, 1080ti, Ubuntu 16.0.4LTS with 4.15.0-43-generic kernel. Here are a sample of calibration table.
1
(Unnamed ITensor* 52): 3cdc9e53
(Unnamed ITensor* 44): 3d3ba1be
(Unnamed ITensor* 38): 3d5e9ecc
(Unnamed ITensor* 49): 3ce41530
(Unnamed ITensor* 20): 3d65bc0b
(Unnamed ITensor* 35): 3d48d9cd
(Unnamed ITensor* 55): 3cd89b86
(Unnamed ITensor* 41): 3d496fe9
(Unnamed ITensor* 33): 3d03ed95
(Unnamed ITensor* 30): 3d21ed83
(Unnamed ITensor* 5): 3cc08982
(Unnamed ITensor* 2): 3c008912
(Unnamed ITensor* 54): 3d088782
(Unnamed ITensor* 25): 3d33360b
(Unnamed ITensor* 1): 4000890a
(Unnamed ITensor* 13): 3d2c1de4
(Unnamed ITensor* 67): 3cfc4eb0
(Unnamed ITensor* 32): 3d4c2587
(Unnamed ITensor* 18): 3d30d396
(Unnamed ITensor* 23): 3d20e995
(Unnamed ITensor* 22): 3d3e3c98
(Unnamed ITensor* 16): 3d1ce3b0
(Unnamed ITensor* 46): 3d01f73f
(Unnamed ITensor* 48): 3d0b0fcc
(Unnamed ITensor* 63): 3d115915
(Unnamed ITensor* 71): 3ce024bc
(Unnamed ITensor* 64): 3cefa77f
(Unnamed ITensor* 29): 3d21ed83
(Unnamed ITensor* 26): 3d1f1ee3
data: 40000889
(Unnamed ITensor* 66): 3d1d45a7
(Unnamed ITensor* 57): 3d0419dd
(Unnamed ITensor* 60): 3d028be7
(Unnamed ITensor* 4): 3cf1d39f
(Unnamed ITensor* 61): 3cd94e6a
(Unnamed ITensor* 58): 3cd11ab5
(Unnamed ITensor* 9): 3d1432a4
(Unnamed ITensor* 51): 3d0936c4
(Unnamed ITensor* 75): 3d0973dc
(Unnamed ITensor* 19): 3d65bc0b
(Unnamed ITensor* 71) copy: 3ce024bc
(Unnamed ITensor* 67) copy: 3cfc4eb0
region_32: 3c011169
(Unnamed ITensor* 74): 3d2bdc55
(Unnamed ITensor* 70): 3ce024bc
(Unnamed ITensor* 42): 3d008114
(Unnamed ITensor* 69): 3d30262a
(Unnamed ITensor* 36): 3d04316d
(Unnamed ITensor* 28): 3d6b5bde
(Unnamed ITensor* 39): 3d004284
(Unnamed ITensor* 6): 3d3d3327
(Unnamed ITensor* 8): 3d767c7d
(Unnamed ITensor* 15): 3d30d42e
(Unnamed ITensor* 45): 3ce945a0
(Unnamed ITensor* 76): 3decdf3d
(Unnamed ITensor* 12): 3d740386
(Unnamed ITensor* 10): 3d45a2e7
