I’ll let you know in advance that I’m not a programmer, but I’m developing an application to automatically collect weights with a scale. The issue I’ve encountered is that with the same Python source code, when reading data from the serial port in Windows, I correctly read the data even if it’s in a binary string. However, on the Jetson Nano running Ubuntu, it returns the following value. Same source code.
CODE:
import serial
ser = serial.Serial(
port='COM4', # in Jetson nano '/dev/ttyUSB0'
baudrate=9600,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS,
while True:
x=ser.readline()
print(x)
OUTPUT WINDOWS:
b'\\x0cN: 3.344g \\r\\n'
OUTPUT JETSON NANO:
b'\\x08\\x01\\x0c\\x0e\\t\\x02\\x02\\x02\\x02\\x02\\x02\\x02\\x02\\x02\\x1a\\x12\\t\\x13\\x13\\x16\\x02\\n
How can I convert output jetson nano in a output windows?
