I used this web(jetson-inference/digits-setup.md at master · dusty-nv/jetson-inference · GitHub) to install Nvidia Digit with docker.But I used this command line(nvidia-docker run --name digits -d -p 8888:5000 -v /home/bmw/data:/data:ro-v /home/bmw/digits-jobs:/workspace/jobs nvcr.io/nvidia/digits:18.05) on terminal is not working. How can I solve it?
And if want to train googlenet with pytorch on DIGIT, how can I do?
Do you run the command on a desktop device?
Please noticed that this tutorial is for the host. It cannot be used on the Jetson Nano.
Yes, I used PC to login docker.
Hi @andy8902, when you docker login nvcr.io
, you don’t input your normal NGC username/password. You will use $oauthtoken
as the username and your API key as the password.
To generate your API key, see here:
If you want to train with PyTorch, see this part of the tutorial: GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
Note that the DIGITS part of the tutorial is now deprecated in lieu of using PyTorch directly.
I have logged in to docker for the first time. Every time I log in, do I have to enter the same name and password as the first time?
Yes, please.
If the API key is somehow missed, you can also regenerate a new key via the link shared above.
When I use this web to login docker sucessfully, I want to use docker to enter DIGIT. When I inputed command line on top picture,it appeared information on buttom picture. How to solve it?
Are the command line shows that “/home/username/data” and “/home/username/digits-jobs” file paths?
Please remember the space between ... 8888:5000 \
and -v ...
$ nvidia-docker run --name digits -d -p 8888:5000 \
-v /home/username/data:/data:ro
-v /home/username/digits-jobs:/workspace/jobs nvcr.io/nvidia/digits:18.05
Or you can concatenate them into one line command:
$ nvidia-docker run --name digits -d -p 8888:5000 -v /home/username/data:/data:ro -v /home/username/digits-jobs:/workspace/jobs nvcr.io/nvidia/digits:18.05
I use this web(jetson-inference/imagenet-custom.md at master · dusty-nv/jetson-inference · GitHub)to download the network on Jetson nano. I encounter a problem below picture. Do I need to install Caffe on Jetson? or how to solve the problem? Thanks for your help.
The command indicates to export the corresponding path to the $NET
environment variable.
It should look like this:
$ export NET=/home/bmw/jetson-inference/Goo
You can check if the variable is correctly set via this command:
$ echo $NET
When I use this web(jetson-inference/imagenet-custom.md at master · dusty-nv/jetson-inference · GitHub) to detect object with camera(logitech C270) on jetson nano, it can’t attach camera below the picture. How can I solve the problem?
I use this command line :
./imagenet-camera.py /dev/video0
–prototxt=$NET/deploy.prototxt
–model=$NET/snapshot_iter_120.caffemodel
–labels=$NET/labels.txt
–input_blob=data
–output_blob=softmax
You will need to check which node the camera is mounted first.
The simplest way is to run following command before/after the camera is attached.
$ ll /dev/video*
The please update the camera node of this command:
–input_blob=data
Based on the log, the video node is correct but the camera type is wrong.
The default camera is set to the nvarguscamerasrc which targets for the on-board camera.
For USB camera, please use v4l2src instead.
Not sure which jetson-inference source do you use.
If you clone it over 2 weeks ago, it’s recommended to update the source to the latest first.
The camera can automatically choose via /dev/video0
or csi://0
recently so you don’t need to manually update it.
https://elinux.org/Jetson_Nano#Cameras
But I used Logitech C270 on Jetson Nano. I want to ask a question what driver didn’t on Jetson nano?
For kuanching USB cameras, please refer to
