when i ran command ./giexec --deploy=dilation_test.prototxt --output=Conv1 it can work
but when I ran ./giexec --deploy=dilation_test.prototxt --output=Conv1 --half2=true, it cannot work
Dilated convolutions are not supported by TensorRT 3.
You can find this information in our document:
> 2.3.1.3. NvCaffeParser
Caffe features not currently supported by TensorRT include:
‣ Deconvolution groups
<b>‣ Dilated convolutions</b>
‣ parametric rectified linear unit (PReLU)
I have read the TensorRT 3.0 developer guide, it said that
NVCaffefeatures not currently supported by TensorRT include:
‣parametric rectified linear unit (PReLU)
‣leaky rectified linear unit (Leaky ReLU)
‣Scale (other than per-channel scaling)
‣ElementWise (Eltwise) with more than two inputs
Not exactly same as you posted. Could you please tell the link of your document?
Also, I have done the experiment, when I change the pad and dilation to 2, not 6, it worked.
We have doubled checked the document in JetPack3.2 DP, Dilated convolutions are not supported.
In /usr/share/doc/tensorrt/TensorRT-3-User-Guide.pdf.gz:
* Deconvolution groups
<b>* Dilated convolutions</b>
* parametric rectified linear unit (PReLU)
