On Win 7 x64, since drivers 190.xx were published (it was working with 185.xx/186.xx), I get the following error when I create a direct3d device from a dll (loaded by Sony Vegas Pro 9).
[codebox]Direct3D9: (INFO) :======================= Hal HWVP device selected
Direct3D9: (ERROR) :CreateDevice failed, because it is called from DllMain.
Direct3D9: (ERROR) :Failed to initialize Framework Device. CreateDeviceEx
Failed.
‘vegas90.exe’: Unloaded ‘C:\Windows\SysWOW64\powrprof.dll’
‘vegas90.exe’: Unloaded ‘C:\Windows\SysWOW64\nvd3dum.dll’
Direct3D9: (ERROR)
Direct3D9: (ERROR) :ASSERTION FAILED! File
s:\gfx_aug09\windows\directx\dxg\inactive\d3d9\d3d\fw\enum.hpp Line 133:
IsValid()
Direct3D9: (ERROR)
Direct3D9: (ERROR)
s:\gfx_aug09\windows\directx\dxg\inactive\d3d9\d3d\fw\enum.hpp Line 136:
m_bTakeCriticalSection == 1
Direct3D9: (ERROR)
[/codebox]
And here’s the code :
[codebox]
extern “C”
BOOL APIENTRY DllMain( HINSTANCE hinst,
DWORD dwReason,
LPVOID pReserved)
HRESULT hr;
IDirect3D9 *g_pD3D;
IDirect3DDevice9 *g_pD3Dev;
HWND hWnd;
D3DPRESENT_PARAMETERS d3dpp;
switch (dwReason)
case DLL_PROCESS_ATTACH:
g_pD3D = Direct3DCreate9(D3D_SDK_VERSION);
ZeroMemory(&d3dpp, sizeof(d3dpp));
d3dpp.Windowed = TRUE;
d3dpp.BackBufferFormat = D3DFMT_X8R8G8B8;
d3dpp.BackBufferWidth = 640;
d3dpp.BackBufferHeight = 480;
d3dpp.BackBufferCount = 1;
d3dpp.SwapEffect = D3DSWAPEFFECT_COPY;
d3dpp.PresentationInterval = D3DPRESENT_INTERVAL_IMMEDIATE;
d3dpp.Flags =
D3DPRESENTFLAG_VIDEO;//D3DPRESENTFLAG_LOCKABLE_BACKBUFFER;
hWnd = GetDesktopWindow();
logextrastatus(“CreateDevice()…”);
hr = g_pD3D->CreateDevice(0,
D3DDEVTYPE_HAL,
hWnd,
D3DCREATE_MULTITHREADED |
D3DCREATE_HARDWARE_VERTEXPROCESSING,
&d3dpp,
&g_pD3Dev);
…[/codebox]
Have you seen this error message before ? ("CreateDevice failed, because it
is called from …")
I don’t have this error when the device is created from a stand-alone application (.exe, not from a dll).
What can I do ?
